Question about HP Computers & Internet
HP OFFICEJET PRO L7650 ALL-IN ONE TO DELL XP 2000 CANT GET TO INSTALL PROPERLY
    Guru:
  • 1,463 Answers
Hello jackjudy
are you trying to install with a cd ?
this could be a cd error, have you tried to download the software to pc form here select your o/s and download fresh drivers
Software & Driver downloads HP Officejet Pro L7650 Color All-in-One
riz.
Posted on Jul 07, 2008
Can I scan on HP officejet pro L7650 all-in-one
Upgrade ur drivers. Select printer icon n then rt click go to trouble shooting
Feb 13, 2015 | HP Officejet Pro L7650 Printer
Can i replace the ADF scanner optical assembly in my HP Officejet Pro L7650
It is a skilled work. After replacement may critical adjustments should be done with its alignments. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 08, 2015 | HP Officejet Pro L7650 Printer
I have an hp officejet pro L7680 printer and am having trouble finding new 88xl cartridges for it. Will the 940xl cartridges work in this printer
You cannot install HP 940 Cartriges for Officejet Pro L7650 as they are not compatible and the mechanism is different for both the cartridges,
In your printer, the HP 88 fits on the left bottom corner of the printer and the HP 940 cartridges are mounted on the Printhead inside the printer on HP Officejet 6500 AIO.
Regards,Suhail
Apr 19, 2012 | HP Officejet Pro L7680 All-In-One Printer
My HP Officejet Pro L7650 printer says "Cannot
Hi
Firstly you should check if there is any covering on the ink nozzles
Did you try to allign the print catridges after you changed the same.
Take out the catridges and clean it with a piece of cloth again put it back and check
if still it doesn't work
If you have done it perform a semi full reset:-
Unplug the power cable at the back of the printer
Press and hold down the (#) and the (6) key together pplug in back the power cable
Leave the keys it should say on the screen semi-nvm reset if it doesn't says so its not done properly .. try to do it once again after that it should align the catridges automatically
This should solve your problem if not try with a different catridge
Aug 24, 2011 | HP Officejet Pro L7650 Printer
HP Solution Center can not locate printer on network
To correct that problem better uninstall and reinstall the HP solution center and after that it should locate your working printer on your network...
Sep 15, 2009 | HP Officejet Pro L7650 Printer
Same as mentioned My HP Officejet Pro L7650 will not turn on. I a
try connecting the printer directly to wall instead of surge protector and see if that resolve the issue
Aug 17, 2009 | HP Officejet Pro L7650 Printer
Hp officejet pro L7650 will not print yellow ink
verify if you have ink in yellow cartridge
perhabs you should change it
Jul 09, 2009 | HP Officejet Pro L7650 Printer
My HP Officejet Pro L7650 prints yellow instead of black
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | HP Officejet Pro L7650 Printer
Computers & Internet Logo
228 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
