Question about Microwave Ovens
I need to replace my Kenmore slide-in electric range, model #991.4674990 and need to know if it is hardwired or plugged in. Can you help me?
    Genius:
  • 1,267 Answers
Every range I have seen has wires that extend beyond the slide in or drop in so that an electrician can run an electrical line near by. I expect that your existing range has wires that are wire nutted to an extended line from your electrical service protected by a double circuit breaker located in your service cabinet. Remember that the range takes 220V ac service or three wires at least for hook up. A trip to Best BUY or any other like store, will enable you to observe a range in its un mounted state. This way you can plan how you are going to execute the swap.
I suspect that you can slide the range part way out to where you can reach the hook up ad un wire nut the connections.
Posted on Dec 28, 2010
Why does my over the range microwave keeps shuttingoff our electricity in the kitchen
This may have a short in the high voltage side, rectifier or shorted high voltage capacitor. You may find it cheaper to replace the microwave, however you do need to call a repairman.
Aug 13, 2012 | Kenmore 1.7 cu. ft. Over the Range...
Need to know what size wire and breaker to use to install my kenmore electric range model 790
need at least #12 (12guage wire) but #10 is even better and requires 50 amp breaker
Jul 21, 2011 | Kenmore Microwave Ovens
Everythink works except the microwave will not start. Is there a fuze that can be replaced to fix this ? Model # NN-2551 I found the user manual on-line, but I can't find the product spec sheet breakdown...
I'm not sure what you mean by "everything works". do you mean that all the lights and the timer work. Could it be in the timer or clock mode? Try pushing the timerand cancel buttons together.
Try changing the time using the clock function.
I believe your model has a child lockout. Please check your manual for instructions on unlocking this function.
Is it hardwired or plugged in? If it is plugged in you can try a power reset, by unplugging it, waiting a few minutes and plugging it back in. It is completely unsafe to try to work on a hardwired Microwave.
Please let us know if this solution is helpful to you. Thank you.
Dec 20, 2010 | Panasonic NN-S255 Microwave Oven
WERE IS MODEL NUMBER ON KEMNORE RANGE?
The model numbers on most Kenmore ranges will be located on a nameplate along the oven door, or lower drawer opening. Some models may have this information on the back of the operator console.
If this question is in reference to a microwave oven, the model number will be located along the oven door opening, or inside the oven cavity along the upper portion on either the left or right hand side.
If you need further assistance, please let me know. I hope this helps you.
Oct 06, 2010 | Kenmore Microwave Ovens
Hi, MY name is Ben I have problem with my Kenmore (GE) gas range. the oven does not start up...I've replaced the igniter, but no luck. I measured the voltage across the the two wires at the inigter and...
A burner works only intermittently If one of your burner heating elements works only intermittently, it's probably because of worn or bad contacts in the receptacle that the element plugs into. On most electric ranges, you can remove the element by lifting it up several inches and firmly pulling it away from its attachment (receptacle). Read your owner's manual to learn the correct technique for your range. If, after removing the element, you see that the ends of the element that were plugged in are pitted, corroded, burned, scarred, or rusted, replace both the element and the receptacle.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 09, 2009 | Microwave Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Remove Kenmore Mod. # 5648598601 from wall.
A lot of those you can replace the bulb without taking it down. There should be screws at the top that lossen up the vent in the front. Remove the vent, might have to open the door and slide it to the left (a little latch) then you should see a filter that just comes out and behind that is the bulb. I would try that before taking it down Forgot to mention that in the other e-mail.
Mar 04, 2009 | Kenmore 80412 Microwave Oven
BRAVETTI CONVECTION OVEN MODEL K5345H
open by unscrewing screws on back and along left side bottom. this lets you swing up the cabinet showing the electrics. the red power line going to the timer is held in place by a metal wire holder that is riveted to the base. wire has a white sleeve between its insulation and the metal wire holder. slide wire and sleeve out to the side of the holder. slide sleeve to side along wire, revealing fuse. need a solder iron and an electronic parts store to get replacement fuse and solder it in. reassemble.
the fuse is a resistor that blows when unit is getting hot. use lower resistance fuse or just hardwire the power line straight through, no fuse, but watch for overheating (not likely) and maybe use breaker outlet
Oct 15, 2008 | Microwave Ovens
Microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
But please reply back with your full model number so we can help you.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Sep 15, 2008 | Kenmore 63672 Convection/Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
