Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
`I need a specific part for my Poulan 2375 chainsaw. It is attached to the choke lever and the carb, a small metal connector with double holes. What is this part number.
dennisgladx
  • 52 Answers
SOURCE: Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Posted on Nov 08, 2008
  • 132 Answers
SOURCE: Gas Oil Mixture
USE 50 TO 1 RATIO BETTER MORE OIL THAN LESS WORST OUT COME A BIT MORE SMOKE RATHER THAN SEIZURE
Posted on Nov 15, 2008
  • 14 Answers
SOURCE: 2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Posted on Nov 19, 2008
  • 97 Answers
SOURCE: routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
Posted on Mar 21, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a Poulan 2375 chainsaw. The fuel lines
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. It does show components and part numbers. Find it here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Typical fuel System:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Posted on Nov 08, 2009
How do you chage a choke knob on a poular chain saw
If the knob is attached to a cable you will need to replace the entire cable which comes with the knob attached. You can just follow the cable and determine how to route the new one and attach it the same as now to the carb.
Jun 17, 2014 | Poulan Pro 260 Chain Saw Av Springs,...
I replaced fuel and carb lines on my Poulan 2450 chain saw. I cannot seem to find the correct path/attachment for the throttle connection. Parts diagrams do not show this. Can someone provide a diagram...
It is quite difficult to explain exactly how it fits, the cable always looks too long and has to curl around on itself back to the trigger, the picture shows quite well how it goes, the end of the cable with a dog leg in it goes to the carb, as far as i remember it goes to the upper hole in the carb spindle, just push it into the hole and turn through 90%, the other end fits into the throttle trigger.adw1_9.jpg
Sep 10, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Routing fuel lenes from carb.to primer bulb to tank and back to the carb.?
moz-screenshot.gif/www.ereplacementparts.com/poulan-2375-type-gas-chainsaw-parts-c-16962_17147_17263.html this will give you a good break down. select diagram B and you will be looking at figures 6, 12 and 14
Aug 04, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My poulan will run but when I press the gas trigger, it shuts off
Sounds like it is running out of fuel supply. Pull the carb. out and part. If you disassemble one side at a time it is very simple. Spray out real well with gum cutter or carb and choke spray. Make sure the hole under the need valve located below the diaphram is clean and the needle is replaced the same way it came out.
Feb 20, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chainsaw high revs, floods, and dies when i let off the choke
its been standing all summer ,,,yes? you have a carb fault strip the carb and fit a new repair kit in it,
also clean out all the carb jets,,plus the tank filter
Dec 02, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My poulan wild thing will start but will not stay running without holding the throttle. What should I do?
Get some sta-bil fuel stabilizer. add twice the amount recommended on the bottle for storage to your mixed gas. Empty out chainsaw tank and refill with the new mix. Rub for 2 minutes, then shut off. Remove cover over carb and spray inside carb, soaking it down good and cleaning all internal surfaces visible - allow to sit overnight.
Next day
Spray down carb with carb cleaner for about 15 seconds. Start saw, allowing 2 minutes to warm up and reduce choke. If saw stalls, restart and spray inside carb as it runs with choke on - keep motor at the highest rpms you can as you spray - spray in 2 second bursts, not allowing motor to stall from spray. If it stalls, change sparkplug and try again. You have varnish build up in the carb and are trying to remove it so the carb will work without the choke. This may take some time but it is the exact procedure I used for my Poulan Team Realtree last spring - I spent about an hour spraying and staring before it ran without the choke.
Good luck!!
Nov 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I HAVE A POULAN CHAIN SAW MODEL P4018 WILD THING. THE CARB HAS 2 BRASS PLATES. THE ONE FOR THE CHOKE IS IN BUT THERE IS NONE IN THE TOP . iT HAS THE ROD BUT NO PLATE OR SCREW TO ATTACH IT. WOULD THIS KEEP...
That should be the throttle plate. If it came loose, it may/should be laying in the intake manifold or it may be on top of the piston. You need to find the parts before trying to start. A small screw that fastens the plate, when it becomes lougged in the top of the piston can destroy the cylinder.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How to set carborator adjustment on Poulan Wild Thing 2375?
hello,the starting point for adjustment screws is 2 turns out.turn in til lightly seated so as not to damage them. there are 2 or more style carbs used on saw,some have plastic caps that need to be removed(a small metal screw used as a corkscrew or pry off) or you need a special tool -splined.set high spped til runs good and back off an 1/8-1/4 turn so you dont burn it up. fine tune low spped so it accelerates when trigger squeezed and re check high speed adjustment.single screw is for idle spped-raises or lowers-if chain turns while at idle back off screw.
mowerman33@verizon.net
Oct 05, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Mcculloch 3216 starts few seconds and dies, choke must be closed.
after jerkin fingers bloody today same problem i took carb apart,,the old hoses deteorated an clogged screen on in take side/// inside of carb plate //of carb,,blew out with choke cleaner,, reassembled now runs well make sure to run same size hoses large an small,,as original other wise floods out,,,
Mar 03, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Wont stay running
take off air cleaner and spray carb with choke and carb cleaner if that doesn't help try and back off 1/4 turn at a time on fuel mixture screw
Sep 03, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
82 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
