Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator model #GSS25KSWA. Bad odor. Garbage-like smell. Seems to be coming from the motor compartment of the refrigerator.Looked, can't find the source. Thanks for any help you can give. PS: Does this model have a removable drip pan? If so, maybe I could check to see if it needs emptying (maybe a dirty pan is causing the odor)
  • 833 Answers
SOURCE: Odor in GE side by side Fridge
Sounds like mold.  I'd try Lysol or one of the other products that claims to treat the odor cause in the air.  Spray a quantity into the empty fridge and freezer and turn it on.  Let the fans spread the stuff around. Try to find the internal vents which seem to pull air into the coils to spray into.
Posted on Nov 27, 2008
Boba
  • 64 Answers
SOURCE: I cannot get to the drip pan under refridgerator to empty it. It is filled with sludge and smells bad
Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
Posted on Jun 11, 2006
docjohn174
  • 943 Answers
SOURCE: refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
Posted on Sep 11, 2008
techjuli
  • 157 Answers
SOURCE: Bad Smell in Fridge
To remove odors:
1. Remove all items from refrigerator or freezer. Throw
out any spoiled foods. Take out removable parts and wash
them and door gasket with mild detergent in warm water.
Rinse well and wipe dry.
2. Wash interior walls and door liner with solution of 1-2
tablespoonsful of baking soda to 1 quart warm water, and
wipe dry. Leave door open and let it air out well, with a
fan directed toward inside, and opened windows if climate
permits.
3. If odor still remains, try one or all of the following
means of odor removal.
a. Spread baking soda out on shallow pans (like shallow
glass casseroles, pie plates, or jelly roll pans lined
with foil) and put pans on shelves to absorb odors, or on
the bottom and in baskets of chest freezer. Leave open
and unplugged.
b. Buy activated charcoal (which is specially treated to
remove odor molecules from air) at some department store
housewares sections, appliance store, or pet shop. Spread
out on shallow pans and put on shelves of refrigerator.
Turn refrigerator on low setting and run empty a few days
so odors will be absorbed.
c. Spread cat litter in shallow pan in cabinet, turn on
and run empty a few days. If odor is disappearing but is
not all gone, replace old litter with fresh litter.
d. Pour several ounces imitation vanilla (not pure
extract) in a shallow saucer, put on shelf and let run
empty a few days.
e. Put fresh ground coffee in cereal bowls inside the
refrigerator and let run empty several days. A slight
coffee odor may remain, but will disappear after washing
again with baking soda solution.
f. Pack each refrigerator shelf with crumpled newspaper.
Set a cup of water on the top shelf or sprinkle the
newspaper lightly with water. Allow refrigerator to run
for approximately 5-6 days. This method takes a bit longer
but has been effective in removal of strong odors.
g. Buy a commercial odor remover, and follow instructions
exactly. Several companies manufacture a liquid
concentrate which sells for about $3.00 for 1/4 to 1/2
ounce. A couple drops are put on a piece of cotton and
placed in the area to absorb odors, in the cabinet or
in a room.
Three of many brand names are: "Odor-Away" by Wrap-on
Co., available at hardware and hospital supply stores,
"SuperCD" IBL Household Products by Crackerbarrel Sales,
Avenal, New Jersey, available in pet supply department
or special products in grocery, or "Clean-Air" at some
appliance repair shops.
Hospital supply stores carry Dow Chemical Hospital
Disinfectant and Deodorant Spray. Spray into cabinet and
quickly shut the door. Repeat.
4. If none of these methods removes all the odor, then it
has probably penetrated into insulation. Contact an
appliance service company for an estimate on cost of
removing the liner and replacing the insulation. If cost
is too high you may prefer to get a new appliance. It
could be used for occasional cooling of soda pop where
the odor will not get into the beverage.
Posted on Dec 01, 2008
barkencoa
  • 3463 Answers
SOURCE: how to empty drip pan
At the back of the food compartment where the water collects ,there is a drainage hole, this is blocked up,poke a long thin piece of wire or similar and poke it down the hole, this should clear the blockage,
If the water does not drain away then you need to go the rear of the frig and clear the rubber or plastic hose that you will see on the top of the motor compressor. this should solve the problem.
Plz rate this solution.
Thanks. and merry xmas.
Posted on Dec 20, 2008
It has a bad smell coming out of motor area
Hello friend, thank you for your post!
I understand that you are having an odor issue with your Frigidaire refrigerator. Usually odors can stem from spills or food within the refrigerator. You can clean the interior with warm soapy water or warm water and baking soda.
Another home remedy is using a pan of charcoal (do not use the one that contains lighter fluid) or kitty litter inside the bottom of the refrigerator and that can help clear out an odors within your refrigerator. I hope this has been helpful. -Matt
Oct 19, 2014 | Frigidaire Refrigerators
Chemical smell in kitchen. is it coming from my brand new refrigerator?
the odors are normal for some new refrigerators,its due to the type of plastic used,let it cool and put coffee inside both compartments or baking soda as these 2 items will remove odors,after the odors gone continue to keep a box of baking soda in each compartment to control all food or plastic odors,this should help remove your odor problem
Feb 12, 2013 | Whirlpool Refrigerators
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
Bad Odor in Whirlpool Conquest Refrigerator
put boxes of baking soda opened in the frig. The baking soda will absorb th odor.
Sep 21, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Burnt plastic smell coming from bottom of frig
This is a sign of a short and should be looked at immediately. A smell like that is a sign of something burning. I could be the start relay and start capacitor with overload. But I would not sleep with the possibility of a fire. I will look over your model and see if I can find what this could be, Sea Breeze
Aug 28, 2009 | GE Refrigerators
I have the same problem with my Kenmore refridgerator
To completely clean a frig of bad smells you will need to remove the back cover of frig and freezer compartment to access all areas. I operated a used appliance store for years and had all manner of stinky refrigerators to deal with so what we did was take out all panels and clean out with bleach and water solution. This took care of most odors. Hope this helps.
Jul 27, 2009 | Kenmore 50522 / 50524 Side by Side...
Foul dead animal smell from kenmoore side by side refrigerator/ice maker
I'm sorry that I don't have a solution, but we have the exact same problem with an older model KitchenAid side-by-side. Did you get this problem solved? If so, can you share what you did?
May 27, 2009 | Kenmore 50522 / 50524 Side by Side...
The dishwaser has a bad smell
run unit through acycle or 2 with a bowl of vinegar on lower rack this should clear all odors from machine,does this drain into a garbage disposal?? thats where smell can be coming from if so pour some vinegar down there regularly as well
Jan 25, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Odor that smells like gas going from the refrigerator
Mold and mildew can cause problems like this. It is even possible that a small animal may have invaded your home and gotten into the box somehow. Cleaning the inside of the box with a dilute bleach solution may help. For continuing odor absorption, place an open container, say a 1/4 cup, of baking soda (bicarbonate of soda) in the compartment. Change as often as once a week. The powder will absorb the odor.
Jan 15, 2008 | Whirlpool ET1FHTXM Top Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
127 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
