Question about Classic Electronics AH3800 CD Shelf System
How to get the AUX to work on the classic stereo model ah3800 if there isnt an AUX button to press on the face of the model but there are AUX plugs?
Did you ever figure it out. Have the same problem.
Posted on Feb 06, 2011
How do I change my stereo to aux after I've plugged it in the back of stereo
Most have a selector that allows either direct access to AUX or cycling through AM, FM, CD, etc. to get to AUX by pressing the an INPUT or SOURCE button repeatedly.
If that doesn't work - what is the brand and model stereo?
May 18, 2015 | Car Audio & Video
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
Need help, got a LG 42PJ550 Plasma TV and a Bush Model CHT100DVDTB but there isnt a headphones socket so i can link it up, have you guys got any ideas or help?
Theres a simple solution
you should buy
a scart adapter
http://www.amazon.com/Scart-Composite-S-Video-Audio-Adapter/dp/B006RBMJ46/ref=sr_1_1?ie=UTF8&qid=1408100307&sr=8-1&keywords=scart+adapter
and
some rca audio cables
http://www.amazon.com/iMBAPrice%C2%AE-PREMIUM-6-Feet-Stereo-Plated/dp/B001VIYYCK/ref=sr_1_2?ie=UTF8&qid=1408100626&sr=8-2&keywords=rca+cable
plug it in
and plug the red and white cords to your auxiliary input from your Bush model (its located to the back of you home theater and writes aux) then by pressing the aux button you should hear volume from your tv
Ps the adapter switch should be at the output mode
hope that was somehow helpful
Aug 10, 2014 | LG 42LG50 42 in. LCD HDTV
Can't get aux cord to work
Try having the device(cellphone.etc..) hooked up to auxillary on its end.. then play music or whatever..then plug the stereo end in and try changing source then.. maybe the unit isnt switching because it doesnt think theres a reason to.. not kidding.. Ive seen this kindve stuff all the time from electronics..theyre so smart theyre stupid. Hoefully this works:)
Apr 11, 2014 | JVC KD-G820 CD Player
I drive a Freightliner Argosy prime mover with a kenwood tuner. Don't know what model. Can't get my ipod to work although I believe it is supported. How do I get the "AUX" function?
Press and hold B.BOOST button for at least one second. This gets you into the settings menu. Use the rotary control to go up and down until you reach the setting for AUX On/OFF and toggle to on. Now whenever you press the source button AUX should be one of the options displayed. The ipod plugs in using a 3.5mm to 3.5mm stereo cable and the input is on the bottom right of the faceplate. Cheers, Dan
Apr 28, 2011 | Kenwood KDC-138 FM / AM Receiver
Can't get auxiliary to work on Pioneer Mosfet Head unit 50x4
you have to turn the AUX input on through the function menu which can be accessed by following these steps
1. with the unit on. press and hold the source button unitl the unit turns of (or goes into demo mode, which is fine)
2. depending on the model that you have, you will have to press and hold the
(volume button or the audio button), until a menu is displayed.
3 . toggle through until you find AUX 1 and AUX 2. i would turn them both on and see which one you have plugged into, then you can go back and turn the other off.
4. once you have change it to ON. press the source button to turn on. the aux option should now be in your source options.
5. also, while on AUX, you can go into the audio settings and turn up the SLA (sound level adjustment) to +4
hope this helps
Aug 26, 2009 | Pioneer 50W x 4 MOSFET Apple iPod...
I can't select aux when I plug my ipod into my Pioneer stereo.
I think this can be done with the stereo on but you have to hold down either the e button or 1 of the buttons on the right side of face(not audio)maybe and a menu will pop up and you should run into a screen that ask off on or off you will want it on and then you should be able to access ur ipod by pressing the source button.Hope this helps.
Dec 13, 2008 | Pioneer DEH-P7800MP
Can I plug my MP3 player into the aux. socket on my car radio, with the appropriate cable and play the stored music?
You should be able to do that as long as you have the right cable.
Most of the mp3 players have a "mini-stereo" jack (3.5mm) and some car stereos have the same type of jack for "aux" input, and others car stereos have RCA jacks for the "aux" input.
Even if the jacks are not the same type, you can use an adapter cable that converts the mini-stereo jack to an RCA jack. You can find them at many places like Best Buy, Circuit City or Radio Shack.
Depending on the type of car stereo you have, you would normally press the source button to change between the tuner, cd player, aux or whatever you may have connected to the stereo. You may even have a seperate button to press for the "aux" input.
I hope this was helpful to you, if you need more information just ask, and please give more info on the type of mp3 player and the make and model number of the car stereo.
Jun 21, 2008 | Car Audio & Video
KCD-135
Make shure unit is in standby, Press menu till meny appears on screen scroll to aux and turn it on
Don
Apr 13, 2008 | Kenwood KDC-135 CD Player
Finding the AUX button
With the stereo on, hold your Source button to turn the stereo off.
The hold the function button, a menu will appear, press function repeatedly until you see the Aux setting, and you will have an option to enable it with the navigation keys.
Once done press your source button to turn the stereo back on, and then go through the varioud sources and ye shall now find Aux as an additional source ;o)
Dec 05, 2007 | Pioneer DEH-P8200r CD Player
Classic Electronics AH3800 CD Shelf System Logo
161 people viewed this question
Top Classic Electronics Audio Players & Recorders Experts
jairo sanchez
jasbo
jasbo
Robert Rankin
Are you a Classic Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
