Question about MSI Computers & Internet
HAVE AN MSI A7200 LAPTOP NEED TO FIND WIRELESS SWITCH TO TO TURN ON AND HOOK TO WIRELESS HUB
4 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: I have a Gateway 7322 laptop. I'm trying to hook
Press the Fn key down, hold it down, then press the F2 key.
Here is the download page for the Gateway Notebook User Guide,
http://support.gateway.com/s/Mobile/Gateway/7305GZ/4429ul.shtml
Posted on Aug 05, 2009
Jack_Dawson
  • 287 Answers
SOURCE: turn on wireless switch and laptop turns off and
1. It's a bad memory problem! (Blue Screen)
2. Try to close unneccessary processes / software using Task Manager before switching ON wireless!
3. Now, switch ON wireless.
4. If it don't work, reinstall the wireless driver!
5. Restart ur system.
tell me if it helps...tc! :)
Posted on Jan 04, 2010
Davethesnake
  • 689 Answers
SOURCE: how to turn on your wireless switch? on a msi u100
some netbooks use a hotkey sequence,mine is Fn-F2 on/off but most pc's differ ,you might have just one key for this function--consult manufacturers site/manual for correct key.--good luck!
Davey Snake1
Posted on Oct 25, 2010
How to turn on your wireless switch? on a msi u100 laptop
Davey Snake1
Oct 25, 2010 | MSI Wind U100-030US Laptop
Turn on wireless switch and laptop turns off and back on, internet working fine with the cable from hub but cannot turn on wireless switch, blue screen with alot of txt flashes and laptop restarts
Nov 25, 2009 | Toshiba Tecra A1 Notebook
I CANT GET CONNECTED TO BT HUB
have you typed the key exactly? viz uppercase/lowercase. The switch(hub) might have MAC address filtering on. also check if the switch(hub) has a DHCP running, which allocates IP addresses, if not you need to set your wireless connections IP address within the same range as the switch. If all else fails attempt to connect the switch via a utp network cable which should have been suplied with the switch(hub) so you can access the switch and make the necessary changes... email me on djtracer@vodamail.co.za should you need more info.
Aug 11, 2009 | Computers & Internet
Can't find the wireless antenna on my msi u100 series laptop
Not really sure what you are expecting. The wireless antenna is within the computer--you won't see it.
What you will need to do is to turn the wireless networking on. This is done in some computers with a small switch on the case (in this case, there is usually a light that comes on when you turn the switch on). In other cases, you will have to use the Fn key plus one of the special function keys at the top of the unit (has a picture representing a wireless connection on it--possibly something like an antenna).
If this fails, go into your network connections and see if the wireless connection is actually turned on. If you have Vista, this is sorta easy as you click on "connect to" and then choose "wireless network"
Apr 03, 2009 | MSI WIND U100 Notebook
MSI PR400 can't find wireless switch
On my msi u120 the switch trick is as follows:
Hold down the funcion (Blue FN button on the left bottom of the keyboard) and at the same time press F11. The blue icon, looks like a little saturn, on the front of the keyboads will light up and you will be able to connect
Mar 24, 2009 | MSI : MP54G Wiress 802.11g Mini PCI Card...
My wireless capability is turned off
How do I turn on the wireless capabilities on my MSI laptop?
Mar 21, 2009 | MSI GX630-028US Notebook
Wireless networking
the key combo is F2 + Fn key (the fn key is located on the bottom row all the to the left) a little blue light lights up that looks like this ((o)) that lets you know it's on. press the combo again to turn of wifi communications.
Nov 15, 2008 | Gateway 7330GZ Notebook
Msi pr 600 laptop (wireless problem)
Hi ppl
The problem was sorted out by my M8, he had the same problem!!!!
On the top right hand side of the laptop there are 4 buttons the one with the sat dish on it needs to be pressed between blue tooth & Internet. (Rember to switch) Hold button down for couple of seconds....
MMmmm sorted how simple was that?
thanks Andy
Aug 05, 2008 | Computers & Internet
Computers & Internet Logo
294 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
