Question about Uniden BC340CRS Base Scanner
I live in the country will my scanner pick up good for how many mile range
    President:
  • 2,761 Answers
Sorry, but there is no formula that can guarantee reception. The VHF and UHF signals monitored by a scanner will normally travel more than 20 miles, but they are strictly "line-of-sight" transmissions. If there are large buildings or hills/mountains between you and the transmitter, or if you live in valley, the signals may not reach you, even with an outdoor antenna. Your best bet is to borrow a scanner from a friend and check reception before you make an investment that may or may not work for you.
Bill B.
Listening in since the 60's
Posted on Dec 29, 2010
Listen i ned help bcs i cant pickup no other frequies butwhere i live
What do you mean "Where I live" It is a receiver. It can only get channels that are broadcast within range. Only internet apps can get areas that are not where you live because they use the internet to move the signals to where you live, or you can also use high powered ham radios.
Nov 16, 2013 | Uniden BC72XLT Handheld Scanner
Tip
Good Way to Test Your Radio Scanner
If your Radio Scanner recieves Aircraft Frequencies and you live about 20 miles from an Airport you can look up the Frequency of the Automated Weather Beacon of the Airport which should be transmitting all the time.
on May 19, 2010 | Radio Communications
Why wont it pick up any of the berea ky codes when i lived in sandgap ky it worked fine with there codes but i got it programmed for berea and i dont hear anything
Hi,my name is John. Welcome to FixYa. You may be out of range. May need to reprogram. get your frequencies here. www.RadioReference.com . Thanks for choosing FixYa...John
Nov 30, 2010 | Radio Shack Pro-82 Scanner
How good is fm tuner reception? We live approx 50 miles from transmitters and have trouble getting clear signals. Is Bose just good sound quality, or does tuner provide superior reception?
I live in Vail Az about 110-120 miles from Phoenix Az I can pick up 60% of the stations decent. The power cord acts as a fm antenna. Plus this Bose Wave CD/MP3/FM
Aug 16, 2009 | Bose Wave Radio
Pro-2096 won't pick up local police
if you live out far from town you may live to far to pick it up. I have this problem because i live out of city. I can go to my mothers and she lives in town and she picks them up fine. I also know that a few months ago all frequencys went digital and some of my # had to be changed.
Feb 04, 2009 | Radio Shack Pro-2096 Base Scanner
I live in canada and my scanner won't scan .
are you using an indoor telescopic whip antenna? those only work for close stations, you might need an outdoor antenna,as high as possible to increase the range, or at least as high as the nearby obstructions.
Dec 26, 2008 | Uniden BC278CLT Base Scanner
Radio shack pro-95 scanner
Radio Shack scanners are not as sensitive as others, but the problem may be your location, especially if you're in a valley with mountains between you & the town that you're trying to receive, or if you have aluminum siding on your home, as metal blocks radio signals.
If either of these is the case, the best solution might be to erect a scanner antenna on your roof or the highest place possible (above metal siding) & connect its cable to your scanner.
Sep 21, 2008 | Radio Shack Pro-95 Handheld Scanner
Antennas Uniden Bearcat BC148XLT
Height and placement of the antenna determines range. Also, check to see you have the antenna perpendicular to the ground (straight up), and place the antenna where it has 19" clear around it. (not up against a wall or other obstruction)
Placing the existing antenna higher, or replacing it with an external antenna would give you more range. A simple test before purchasing a new connector, coax and antenna for the scanner, would be to place the scanner where you think you would place an antenna and see if it gives you the range you desire.
External antennas are available from most any radio shop. (They would need to know what type of connector you need to connect the coax to the back of the unit.)
Sep 09, 2008 | Radio Communications
Please help
The signal received on scanners depends on a number of factors. The most important is the elevation of your location. If you are in a valley or have higher ground around you, this will screen signals from you and will reduce the number of stations you can hear.
Secondly, receivers vary enormously from one to another. The one you are using may simply be less sensitive.
Thirdly, the position and type of antenna is crucial. If you are using a directional antenna it will only pick up signal from the front and some from the back. An omni-directional antenna will allow you to pick up signals through 360 degrees. The antenna must also be as high as you can get it, especially if you are in a valley.
Some emergency services use repeaters which allow you to hear signals much further away. You may not be in range of a police repeater.
Mar 08, 2008 | Radio Shack Pro-97 Handheld Scanner
New Zealand
Do you have a list of correct freq's for your area?
Make sure you have the scanner set on the correct mode (am/fm/ct/dc) for the freq's you have programmed. Each area of the country have their own individual freq. so their not stepping on each others transmission.
Jan 12, 2008 | Radio Shack Pro-84 Handheld Scanner
Uniden BC340CRS Base Scanner Logo
Top Uniden Radio Communications Experts
Jason
Robert McClure
John
John
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
