Question about 2wire HomePortal 1100 Router (1000400124001)
Everytime I attempt to access a web page, email or anything on the web., The middle light begins to blink orange for about 10 secs then turns green and then the pages will open. Very frustrating
    Guru:
  • 2,178 Answers
Your DSL signal from your ISP (Internet Service Provider) or phone company is dropping out. Contact them to test your signal and connection.
Posted on Dec 28, 2010
After switch on, 6 sec green light, and blinking orange (yellow) light. "Cannot properl communicate with the scanner. The carriage unit may be locked ... etc "
This sounds like there is a mechanical problem inside the scanner. You may want to open the scanner to see if there is anything broken or jammed. It may need some lubrication if it has been unused for a long period of time.
Dec 12, 2014 | Epson Perfection V500 Photo Scanner...
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I cannot connect to the internet using my netgear n150 wireless router. The internet light is orange but the modem is working fine and I can connect to the router itself.
When the router is turned on, the Internet light turns amber for about 20 seconds and then turns green. If the light does not turn green, the router has a problem. If the Internet light is still amber 1 minute after turning on power to the router: a. The Internet is not accessible. Confirm that you have the correct internet setting. b. Clear the router's configuration to factory defaults. This will set the router's IP address to 192.168.1.1. c. Turn the power off and back on to see if the router recovers. If its still not working, reset to factory defaults. You can restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1. To restore the factory default configuration settings: 1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink (see "Back Panel" on page 4). 2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
Jun 06, 2011 | Computers & Internet
There is an orange "i"
The orange "i" means that the Ethernet cable connection to the modem has been detected.
The light should be blinking green for Internet connectivity.
I advise you to reset the router:
1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink .
If resetting the router does not correct the issue, you should call your ISP (Internet Provider) and check if they are having a problem.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 23, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
What are the blinking light error codes for
the interphase between the raw drive and the usb cable is faulty or blown up.
use the raw drive from the casing to power it directly to pc it would start working
Sep 19, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
I have a lexmark x6570 all in one printer. I recently restored my pc and I unistalled my printer. Then I reinstalled it again. Now the WIFI light is blinking orange.
If the printer is blinking with a orange lights means that the printer is not connected to your wireless network. Some possible solutions:
Check the wireless connections (If you've restored your computer you have to set the wireless connections again)
Check the access point
Move your computer or printer to reach the access point
Try adjusting the antennas
Make sure the Key Web keys are correct.
You will find more help here:
http://images.lexmark.com/publications/pdfs/2007/6500/v4897402_en.pdf
SEE PAGE 146
Another blinking situations (not wireless related)
If the printer is blinking in a slow mode, then the printer is in a sleep mode.
Do this:
1) Unplug the power cable from the wall outlet
2) Wait 10 seconds and plug the cable again
3) Press the power button to turn on your printer
This must be fixing the problem
Nov 18, 2008 | Lexmark Office Equipment & Supplies
Phillips FTR 9964 Blinking Green/Orange Indicator Light
PHILIPS 42 WILL NOT TURN ON,WITHE FTR9964 RECEIVER
TO BLINK ORANG /GREEN AFTER 40 SEC ORANAGE
May 23, 2007 | Philips E-Box FTR9965 DTV Receiver
2wire HomePortal 1100 Router (1000400124001) Logo
59 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
