Question about Dishwashers
Hotpoint Auqarius dishwasher. I have resentley moved house and reconnected the machine. it works through programme fine but is sometimes leaving dishes gritty and not quite clean. I have cleaned filters, arms etc dont know what else to do?
  • 108 Answers
It sounds like there could be a gritty deposit in the bottom of the system. At the start of the cycle the unit takes in a set amount of water and recycles it around to the drying phase.
Try and run the diswasher a few times with no items in it - this will may help to flush it out.
If the gritty deposit coloured white this could be that your new home has more limescale in its supply. Try getting dishwasher tablets with limescale protection to see if that helps.
Finally, please ensure the spray arms free to rotate on each cycle. Failure to do this leaves grit on certain items and not others.
Please dont forget to rate.
Posted on Jul 07, 2008
Bosch S9G1B dishwasher doesn't fill with water
The valve will not energize if the float is up at the limit. Sometimes a bit of soapscum can leave the float in the up position. When this happens no water is allowed into the chamber. Move the float up and down and clean the travel using a bleach spray.
Jan 18, 2015 | Bosch Dishwashers
Hotpoint Aquarius FDW60 won't take in water. Suspected airlock after house move?!?
Try checking the inlet solinoid , should be 1 for hot & cold, sometimes the solinoid will freeze up due to alkaline buildup .try soaking it in CRL , alkaline deposit desolving liquid .
Mar 13, 2012 | Hotpoint 24 in. FDW60 Free-standing...
FDW60P dishwasher. Hotpoint Aquarius Control panel not working
I phoned Hotpoint. Was told to switch everything off and take the plug out for ten minutes - I didnt do that before, I just plugged it straight back in. I did this and was able to run the machine during the night on the programme I wanted. At least if it happens again I know what to do.. This solution will cost you nothing.
Jun 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint dishwasher
Switch the machine off and unplug at the mains. Leave for ten minutes, then plug in and switch on. My dishwasher control panel had a mind of its own and did what it wanted including leaving water in the bottom of the machine. The electrics sometimes need re-booting! Hotpoint suggested the solution and it worked for me. Saved me £99 call out charge. Good luck.
Jun 04, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius dishwashers keeps stopping half way through wash flashing between the 40 and 60 temp light. How can I fix this please
Control panel is sensitive on this model. Mine did the same and machine would not wash to the programme, stopped half way or would not set at all. Switch off machine and unplug from the mains. Leave for 10 minutes. Plug back in and switch the machine to your required programme. You should find this solves the problem. It worked for me.
Failing that, go to the Hotpoint website, find the customer service number and ask if there is anything else you can do to solve the problem yourself. That is what I did and I followed their advice. It saved me the cost of a service call out and they were very helpful. Good luck
Apr 20, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
Jan 26, 2008 | Dishwashers
Dishwasher pumps water in and out, but does not wash
Try tilting the machine back 45 degrees for one minute 7 then try one of the programmes. Serousely outr Bosch diswasher was firstly not draining water then not taking in water & another forum suggested this odd manouvre & all is fine now
Nov 06, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Aug 21, 2006 | Hotpoint 23 in. BF50 Built-in Dishwasher
Dishwashers Logo
188 people viewed this question
Top Dishwashers Experts
