Question about Kenmore Refrigerators
My kenmore refrigerator model #56163500 stop producing ice even though the filter is new
SOURCE: Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Posted on Apr 16, 2009
  • 415 Answers
SOURCE: Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Posted on Aug 20, 2009
arikrom
  • 528 Answers
SOURCE: I have a Kenmore side by side refrigerator model
on this model the ice machine go bad and the only way to fix it is to get new ice maker unit :(
Posted on Jan 02, 2010
toolkits
  • 1099 Answers
SOURCE: Kenmore refrigerator model 2535466940A, stop
ICEMAKERS OFTEN STOP DUE TO A WARMER THAN USUAL FREEZER TEMPERATURE. MEASURE THE TEMP AND IF IT IS UNDER 10 DEGREES F. IT SHOULD BE DUMPING ICE. (IT WOULD HAVE FASTER PRODUCTION IF SET TO O DEGREES.) IF IT HAS A "NO WATER" PROBLEM YOU WILL HEAR IT HUM FROM TIME TO TIME AS IT CYCLES BUT DOESN'T DUMP ICE. THE EASY WAY TO CHECK FOR A 'NO WATER' PROBLEM IS TO TIE A 10 INCH OR SO PIECE OF LIGHT TWINE ONTO THE SHAFT AND CHECK IN A FEW HOURS TO SEE IF THE SHAFT IS WINDING THE TWINE UP ONE TURN PER CYCLE. IF TEMP IS COLD ENOUGH AND IT IS CYCLING THEN THERE IS NO WATER GETTING TO THE ICEMAKER. POUR A CHARGE OF WATER IN THE TRAY/MOLD AND IT MAKES ICE AND DUMPS ONLY THE ONE LOAD IS ANOTHER WAY OF CHECKING. THE NEXT MOST LIKELY PROBLEMS MIGHT BE A WATER LINE FROZEN DUE TO A SUPER COLD FREEZER OR A BAD SOLENOID VALVE. I HAVE NOT SEEN IT BUT I WOULD CHECK THE WATER FILTER ALSO. IF THIS DOES NOT SOLVE THE PROBLEM-YOU NEED TO GET THE MODEL NO. AND SERIAL NO. OFF OF THE NAMEPLATE. I BELIEVE YOU HAVE TAKEN IT FROM THE BOOKLET AND YOU ARE SHORT SOME DIGITS.
HOPE THIS HELPOUT , GOOD LUCK IN SOLVING THE PROBLEM
Posted on Aug 02, 2010
markfreedman
  • 312 Answers
SOURCE: my refrigerator stop producing ice even though the
Check the tube that goes to the Ice maker mold tray from the back of the freezer compartment.If this tube is filled with ice, then the fill valve for the ice maker is not sealing completely. The very slow flow of water freezes in that tube. It requires that you replace this with a new valve. The valve is located in the bottom section of the rear of the fridge. You will need to remove the cardboard cover to get to it.
The valve assembly on side-by-sides is a combination part that also has the valve to the ice water dispenser on the door. When doing this repair yourself, make sure that replace the cardboard backing on the fridge, as it will not cool properly without it.
Hope this helps,
Best, Mark
Posted on Dec 28, 2010
Kenmore icemaker model 795.7102 not producing ice
is the metal arm in the lowered position or raised?.. needs to be down..
Feb 02, 2014 | Kenmore Refrigerators
Have Kenmore side by side refrigerator model 55251, 55271, 56261 that the ice maker has stopped producing ice. What should I look for to fix it.
The most common issue, or occurrence is that the arm in the ice tray has been set to off, simply put it in the down position and it should work. If that is to no avail, then I would change the filter as it is probably clogged. You can replace it and you should be good.
Mar 16, 2011 | Kenmore Refrigerators
My refrigerator stop producing ice even though the filter is new.
Hope this helps,
Best, Mark
Dec 28, 2010 | Kenmore 57029 Side by Side Refrigerator
MODEL # 59673504203 DRAWER IS ALWAYS FREEZING EVERYTHING IN IT. NOW NO ICE IS BEING PRODUCED
I had the same problem. I pulled the drawer all the way out. In the back is a vent flap. Ice had formed on it keeping it open. I chipped off the ice so the flap can move. This stopped the freezing veggies.
My ice maker stopped working. It was suggested I change the water filter as it may be clogged preventing water moving to the ice maker. As I am getting a new refrigerator I all not be buying a new filter.
This message is little late for the original poster but may help someone else.
Aug 04, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
I have a Kenmore side by side refrigerator model 106.5778*700. All of a sudden it stopped producing ice. Any suggestions?
Dec 29, 2009 | Kenmore Refrigerators
Kenmore refrigerator-model#59582998 serial#514037483 I would like to operate my refrigerator without a filter due to the taste of the water by using filters. Is it permissable to remove the filter and not...
I would suggest , home depot , or , a hardware store , which supplys a filter , with replaceable cartridges . Usually runs about $ 50.00 . This filter , will mount to the wall , and not the appliance itself . If you " bypass " the filter , it may stop the dispensor flow , and / or , the ice maker water flow .
With the new filter , you can use , calcium filter , charcoal filter , or calcium filter replacements . Even lime , I believe , is available .
As far as removing the filter , I suggest , trying , to see if the water / ice maker still works , after removing .
Dec 15, 2009 | Kenmore Refrigerators
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Apr 14, 2009 | Kenmore Refrigerators
Kenmore Side By Side Refrigrator ICe Make Not working
Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
