Question about Water Rower WaterRower A1 Rower
My waterrower has a leaking seam in the plastic tank. I know its not that expensive to get it fixed, but its a big hassle...80 mile round trip in heavy traffic. Is it ok to use plastic sealant like you use in bathrooms? And maybe cover with clear plastic tape? Will that work? What type of tape?
  • 5 Answers
I sealed my tank seal permanently and also fixed cracks on the bottom with Loctite PL Marine Fast Cure Adhesive Sealant. On the inside when the tank was apart I glued a heavy plastic patch directly over the cracks in the bottom. I made the patch from a flat section of plastic cut from an old refrigerator crisper drawer. After installation with the tank laying flat and level glue the upper side of the tank to the adjacent wood for stability. Wait a few days before filling. Photos are attached. Loctite 10 fl oz PL Marine Fast Cure Adhesive Sealant 2016891 The Home...
My waterrower has a leaking seam in the plastic - waterrower-leaking-seam-in-plastic-qgfhw1xmkchszhjujwraevq5-1-0.jpg
Posted on Jan 22, 2016
  • 30 Answers
Good Afternoon:
Lawrence, you can indeed use Silicone Sealer like this one, which is aquarium (fish) safe::
http://www.amazon.com/Henkel-908570-Loctite-Silicone-Adhesive/dp/B0002BBX3U
And instead of clear plastic tape, use something like this, which is waterproof and uv resistant:
http://www.amazon.com/37-5-Blue-reflective-stripping-tape/dp/B0001YXZ7U/ref=pd_sim_auto_1
You will have plenty of extra for raingear.
Happy Rowing!
Chr
Posted on Jun 14, 2011
Gas leak on the seam of plastic gas tank
Looks like time for a new tank. There are methods for "welding plastic" you might take it to a Shop that repairs raditors and gas tanks. When you take it to the shop have as little gas in it as possible. SHOPS HATE IT WHEN THEY HAVE TO REMOVE 20 GALLONS OF GAS BEFORE REMOVING THE TANK. You might check with the dealer to see if this is a common problem if its not collision damage.
GOOD LUCK. PLEASE POST AND LET US KNOW WHAT YOU END UP DOING.
IT HELPS WHEN YOU ASK THESE QUESTIONS IF YOU TELL US THE MODEL AND YEAR OF THE CAR.
Mar 30, 2015 | Mercedes-Benz C-Class Cars & Trucks
How to fix a leaky Toro 20007 fuel tank
If the fuel tank is metal take it off and clean the seam with sandpaper and use JB weld to repair it- If plastic tank, use a glue gun.
Apr 18, 2014 | Toro Lawn Mower With Toro Power Tools
WHAT TYPE OF ADHESIVE CAN i USE TO REPAIR A LEAKING COOLANT RESIVOUR
you can try a plastic weld type epoxy they make some for plastic gas tanks as well try that remember to clean and scuff the surface
Aug 12, 2012 | 2002 Lincoln LS
Coolant surge tank on my 93 saturn SL2 has a pine hole leak on the inside seam which is leaking out coolant and causing overheating. It is a plastic tank. Is the tank by itself replaceable? I have sealed...
The tank should be easily available at any auto wrecking/used auto parts locations.
Otherwise,do you have a soldering gun or soldering iron?
Clean off the epoxy and plastic weld the tank with your soldering gun.Just melt the plastic back together carefully.
Other plastic can be added into the weld if needed.
Oct 05, 2017 | Saturn Cars & Trucks
The drum on the waterrower is leaking. WHat is the best way to fix it?
Good afternoon, Arne725:
I hope this message finds you well.
You can find clear silicone sealer here:
http://www.amazon.com/Permatex-80050-Clear-Silicone--3-Ounce/dp/B0002UEPVI/ref=sr_1_1?s=automotive&ie=UTF8&qid=1308017776&sr=1-1
and if you are feeling artistic, some pinstriping will nicely accent the tank.
Chr
May 04, 2010 | Water Rower WaterRower Natural Rowing...
Fuel filter location
The Fuel Filter is in the Fuel Tank, the Filter is considered a "lifetime" filter, that does not need to be replaced... which is not correct.... mine was clogged at 99,500 miles, and stopped my car from running all together.... I would replace the fuel pump and filter at 100K miles or 120K miles when you drop the fuel tank.. the pumps either go at 80-120K or never....
Oct 27, 2009 | 2004 Volkswagen Jetta
4.0L Northstar Engine Overheating
the useual problem with this engine is the head gasket leaking, that sounds like what is going on with your Northstar.
Aug 16, 2009 | Cadillac STS Cars & Trucks
Slow leak drips from bottom of 4 year old model
Hi
Please try and remove the cap by turning it clockwise and counter clock wise to remove it. If it doesn't come off then empty the water dispenser and use glue to fix the leak. See this link to see which type of glue should be used--- Glue Usage
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Apr 07, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Water Rower WaterRower A1 Rower Logo
5,487 people viewed this question
Top Water Rower Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Water Rower Exercise and Fitnes Expert? Answer questions, earn points and help others
