Question about Vizio GV42L 42 in. LCD Television
My gv42 l turns on, says no signal and then shuts off. Whats wrong?
  • 2 more comments
  • John Lefebvre
    John Lefebvre Dec 28, 2010
    It wont stay on long enough to change the input and it doesnt seem to matter.
  • John Lefebvre
    It wont stay on long enough to change the input and even when I try to change the input it doesnt do any good.
  • John Lefebvre
    Simply changing the input button didnt work but removing the power for 40min helped . Havent tried the hdmi input yet but hope thgis fixes it. Thanks.
  • Dawn peters Oct 10, 2011
    If the TV goes black after how am I to orrect the Input i don't get the screen to do so.
  • 8,197 Answers
The reason why the tv says no signal is because it is on the wrong input. Turn the tv on and chang the input to find the right one. My vizio does the same thing if it is on the wrong input.
Posted on Dec 28, 2010
  • Jyackle5
    Jyackle5 Dec 28, 2010
    You need to turn the tv on at the tv and use the input button on the tv to do it. Do not use the remote it will not give u enough time to do it
  • Jyackle5
    As soon as you turn the power on press the input button to change it
    President:
  • Vizio Master
  • 775 Answers
You can send the main board to us to get it fixed.
We are 99.9% successful (for this particular problem) and do not charge any service fees if we see a problem and fail to resolve.
You will always pay shipping to and from us ($11 or so in each direction) and as I said if we fail to fix the board that is all you will pay, if you want the board back, of course.
if successful it's about $60 total.
Go http://www.coppelltvrepair.com and search for the TV model or, better yet, for the board number which is on a white label somewhere on the board and usually starts with "3642", e.g.
http://www.coppelltvrepair.com/p/447/vizio-l42hdtv10a-main-board-3642-0062-0150-repair-service-for-not-powering-on-problem
If you can't find a listing for repair of your board contact us - I am positive we service those.
Hope that helps!
Posted on May 23, 2014
    Genius:
  • 1,126 Answers
It is possible that it was hit by a small power surge and has some garbage in the processor and if you unplug the set from the wall for 40 MIN.,then it should reset back to normal,if it still doing the same thing then you have power supply problems, and the easiest way to fix that is buy a new power supply.
The rear brake lights come on when I turn on the left turn signal. ideas on whats wrong?
Could be the flasher is no good for that side or you have a bulb burned out front or back
Oct 18, 2014 | 2001 Chevrolet Chevrolet Blazer
My turn signal won't go off, it constantly stays on
there is whats called a cancel cam inside the steering column it is a metal ring that hits a plastic tab inside the wheel as it turns if its broke it wont hit the tab and wont shut off the turn signals
May 05, 2011 | Mazda Protege Cars & Trucks
No power to the tail light, horn, tac ometer, speed ometer turn signal...tell me whats wrong
Typically your Signal fuse supplies all the above mentioned items....go to your main fuse box and check for the Signal fuse being blown.
Mar 19, 2011 | 2008 Suzuki Boulevard
2004 Stratus: turn signal doesn't work. is it the flasher or mul...
the trans was shifting funny so we unhooked the batt to reset the computer when hooked batt back up now we have no signals or flashers whats wrong
May 17, 2010 | 2004 Dodge Stratus
My turn signals won't turn on the fuse and the relay are ok whats wrong with it?
you may have a bad turn signal flasher. If fuse, relay and bulbs are ok try replacing flasher. Good luck!
Oct 22, 2009 | 1995 Oldsmobile Cutlass Supreme
Wont start up
Your phone doesn't not wake up so you will need to have it repaired or replaced
Dec 24, 2008 | Motorola Mobility RAZR V3
Monitor signal is off
no power from the computer, replace the power supply in the computer.
Aug 06, 2008 | Gateway GT5408 PC Desktop
Whats wrong with my lanzar amp
check ur ground wire , it might not be good ground, secondly check ur fuses..
Dec 25, 2006 | Lanzar HTG264 Car Audio Amplifier
Vizio GV42L 42 in. LCD Television Logo
544 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
