Question about HP Photosmart C7280 Printer
My HP C7280 is not printing red, colors appear to be faded. All new hp ink catridges have been installed. Have done several maintenance tests, cleaned printheads, alignments etc. to no avail. Help!
gwbm
  • 353 Answers
SOURCE: to make my Epson printer, model "Epson stylus C42UX" work in India, with Indian ink catridges T038 & T039
This is a tricky one, but there are possibilities.
1. Buy a set of epson C42 cartridges from the cheapest source and keep refilling them - you will need a (very cheap) resetter.
2. Transfer the C42 chip to the C41 cartridge - they are only clipped in place. I don't know if this will work because I only have knowledge of C42 cartridges - the C41 cartridges may be keyed so they wont fit in a C42 cartridge carrier. You may be able to identify a clone manufacturer for which this is possible. You will also need the resetter for this solution.
3. Fit a Continuous ink system (CISS) see for example http://svp.co.uk/products-solo.php?pid=3569&prepg=1
Posted on Jan 31, 2009
hsanfor
  • 71 Answers
SOURCE: HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Posted on Jun 20, 2009
SOURCE: I have a canon i860
Bought a new printer. It was cheaper than the fix for my canon printer.
Posted on Dec 07, 2009
pineworks
  • 4041 Answers
SOURCE: even though black ink cartridge is almost full, no
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 28, 2010
  • 213 Answers
SOURCE: black not printing
Is the new cartridge genuine canon or compatible? Usually the compatible cartridges contain ink that clogs the nozzles. If the new cartridge is compatible, replace it with genuine canon and only then try maintenance clean. Sometimes this helps
Posted on Aug 01, 2010
C7280 HP Printer. Both Magenta catridges wont print. ERROR states that they need to be replaced , but have been replaced several times and still have ink. Message also says print in blak only. click on...
I have been told that HP printers have a built in program that will make printer fail after a set number of pages have printed,
and if the NV Ram is reset this will reset the page count,
page count resides in the transparent, image or drum kit.
I dont know how to find this or reset page count but if anyone knows i would like to do this on my hp printer
please any help.
May 06, 2011 | HP Photosmart C7280 Printer
How do i repair: hp Photosmart C7280 Printer ink system failure error: Oxc18a0101
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
Jul 18, 2010 | HP Photosmart C7280 Printer
Experiencing a problem with an HP Photosmart C7280 All-in-one printer, after the yellow ink cartridge was replaced a 'change the cartridge' screen comes up when trying to print, even though the printer...
You may also try this: Press and hold the '*' key on the key pad, then press the '#' key and release them both. Then enter '123' to enter maintenance mode. Then press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then press OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then power it off and back on.
May 11, 2010 | HP Photosmart C7280 Printer
Red is printing very light and streaking. The other colors print
1.clean the printer head using printer service utility
2.Buy a new catridge and fix it
note: if you are not use the printer the ink will be dry.so it cant able to print
Feb 12, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Printer has been idle for several weeks.When I came to use it the printing is broken and faded looking.How do I clean the cartridges?
HP Deskjet 5550 Printer.
The deskjet printers should not be kept idle.
At least once in two or three days, you can take one page print out.
This has to be done, otherwise, the inks both Black and colour will get frozened and sometimes it will become dry at the catridge mouth.
Black Ink is 56 and Colour is 57.
Solution :
01. Manually remove both catridges from the printer carefully.
02. Shake the catridges with full force pointing towards ground. You can find out now, that ink is coming out from the catridges which was frozen or dried up.
03. Clean the cartridge drive with a nice cloth and cleaning liquid.
04. Re install both catridges and take a test print out.
05. Recommended to have a service contract with local HP Authroized printer vendor to have a regular maintenance at least once in a month.
Jul 21, 2009 | HP DeskJet 5550 InkJet Printer
I changed my black ink and now i get the message left cartridge incorrect..how do i fix it?
HP PSC 2210 InkJet Printer. The following has to be done for checking the Blank Ink Catridge working : 01. Remove the existing Black catridge and Color Catridges from the Printer carefully. 02. Clean the location with a soft cloth with cleaning liquid to make the place dust free. 03. Put the correct black and colour cartridges recommended by HP and that too genuine one. 04. Do not use any refilled or reinked local catridges that will spoil the HP PSC 2210 printer. 05. Re-install the catridges both Black and Colour properly. 06. Take a test print out - both black and colour print outs. 07. Check the Printer status and there is no warning of Cartridges wrongly inserted. Have a Good day.
Jul 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Jun 20, 2009 | HP Photosmart Pro B8350 InkJet Printer
Replaced color cartiage, now only one color prints, red? Help
Try to check the level of your ink in your color catridge maybe is running low or empty then if its empty then remove the catridge then replace another color catridge full of ink then run your printer again. If you successfully installed new ink catridge then it will automatically reset the level of your ink monitor to full.
Jun 16, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
HP Photosmart C7280 Printer Logo
101 people viewed this question
Seeker5211
Seeker5211
