Question about Yamaha HTR-5990 Receiver
I have a Yahama HTR-5990. I did something to the
I have a Yahama HTR-5990. I did something to the settings and now I can't enable the Surround Left/Right speakers. The Auto Setup says I have 3.1 setup but it is wired for 5.1. It used to work and the hardware hasn't changed. I was messing with the zones and I can't get it working again.
SOURCE: Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
Posted on Jul 30, 2007
SOURCE: Zone 2
The above suggestion may be the cause of the problem. Zone 2 can only play analog, so if you have HDMI connection you cannot output to zone 2.
I resolved my own problem. This is a 7 channel system. Zone 2 needs 2 channels. In my case I bi-amped both front speakers (ran two speaker cables to each). So Zone 1 was using 7 channels, 5 speakers plus 2 added cables for fronts. Zone 2 could not work.
In set up 2 Speaker Settings, select first menu item then scroll to second option on this, change setting from bi-amp to Normal.
Posted on Jan 07, 2008
  • 12 Answers
SOURCE: Yamaha HTR-5990 Audio no longer works
Hi everyone:
You may reset your unit, to do so here is the procedure.
1. Depress the MASTER little Button so it has to be in the OFF position
2. press simuntaneously the A/B/C/D/E and TUNNING/CH > buttons and the press MASTER again
3. Keep the two buttons pressed until the SLEEP blinks on th display, at this point you will see a message that last for maybe 3 seconds,
4. after the message you will see the number 1 and a series of numbers on the first row and the word MARGIN on the second row.
5. Turn the PROGRAM knob until you reach tothe number 11 FAC PRESET on the first row and PRESET INH on the second row
6. press the TUNNING/CH > button once, and the message on the second row will display PRESET RSRV
7. Press the MASTER again and your unit will have the factory settings.
I Hope this solve your problem
Miguel
Posted on Feb 16, 2008
robotek
  • 1512 Answers
SOURCE: yamaha htr-5990 Reciever powers on
Hi larryavent
The unit is going into protection mode. Check you speaker cabling and connections for short circuits and frayed ends. Best way to test for speaker or related problems is to disconnect the speaker wiring from the amp and try again. If it still has the symptoms with no cables connected then it will have an internal fault. Unless you have experience with this type of gear, there is not much that is user serviceable inside. A trip to a Yamaha Service center may be in order.
regards
Graeme
Posted on Apr 07, 2008
  • 14 Answers
SOURCE: Zone 2
restore the receivers to factory settings by pressing and holding the dvr/vcr button then press the stand by button. this would erase all assignments made so you would need to redo the assignments of your sources to the receiver, then activate zone 2 by going in to the hardware setup(7.2)
Posted on Mar 04, 2009
Sorry Michael, you have a problem in the audio amp section of the receiver and unless you know how to troubleshoot solid state electronics, you will need to have this unit serviced by a pro. Good Luck
Jun 21, 2007 | Yamaha HTR-5990 Receiver
Yamaha HTR-5990 Receiver the HDMI inputs only one works is the other switchable?
according to yamaha website you have 2 hdmi inputs, and one hdmi out on that unit
Mar 07, 2013 | Yamaha HTR-5990 Receiver
Hi- I have a Yamaha htr 5990, I am trying to set up a 2nd set of speakers to run off zone 2 or 3 that will power speakers at the patio; but I cannot figure out how to get it to run. Any suggestions as...
to set up a zone 2 or zone 3 set up you need the yahama amps that receive the signal from the main amp, and from that zones amp, you can control that zone, If you check out page 102 of the manual, you will see where it shows these external amps that control that 2 nd and 3rd zone However, if you look at page 85 of the manual, you can just run the speakers off the main, and select B on the speaker selection, leaving main and B on will have sound coming from all the speakers, turn off whichever you want to cancel the sound in either room
Jul 11, 2011 | Audio Players & Recorders
No compressed audio on hdmi If I send compressed Dolby Digital to the HTR-5990 via HDMI, the indicator shows "PCM" and no audio is heard.
You probably need to take that issue up with the setup of the unnamed device originating the signal.
Mar 23, 2010 | Yamaha HTR-5990 Receiver
Audio keeps cutting out intermitenly on my Yamaha htr-5990 this will happen no matter what input is being used
Is it going into protect mode???
If so, check your speaker connections. Make sure there are no loose copper wires hanging out, and that your splices are clean at both the receiver and the speaker.
Feb 12, 2010 | Yamaha HTR-5990 Receiver
What model of remote comes with this yamaha htr 5990
The RVA350 comes with this model according to the manual.
Hope this helps
Oct 07, 2009 | Yamaha HTR-5990 Receiver
Sony strdg720 problem
Try turning off any surround mode so all you have working is the 2 front speakers. If the soundgoes away, the problem is in the digital surround processing and you are hearing the results of digital noise. Since this unit is new, return it for an exchange indicating the problem. It should not be making this sound.
Dan
Feb 18, 2009 | Yamaha HTR-5990 Receiver
No sound from Yamaha HTR-5990
You must be sure that you also have "audio" cables connected to the receiver to make this all work. As far as the TV is concerned, the same applies....accordianman
Oct 31, 2007 | Yamaha HTR-5990 Receiver
May 01, 2007 | Yamaha HTR-5990 Receiver
Yamaha HTR-5990 Receiver Logo
108 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
