Question about Emerson Pool & Spa
Hello, I have an Emerson Spa Pump Motor ( 2 HP, 230v, 3450 rpm). The motor has model R610867, cat 7610, sf 1.3 on it. It also has "1081 motor" on the label. I am tring to find a replacement start capacitor for it. Unfortunately, the part number on the old capacitor is rusted and unreadable for the most part. Do you have any information to identify this pump or can you identify a capacitor that will work with it based on it's specs? Appreciate your help!!
  • Emerson Master
  • 1,338 Answers
Should be a 30, you can have the old one tested it might be good ? I write the value on the back and side for future reference to avoid this problem as the value is normally not stated on the motor's label like is done on air conditioning motors. search your area for your LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING
Posted on Jun 07, 2017
  • 1383 Answers
SOURCE: rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Posted on Dec 14, 2008
rowdy45176
  • 2176 Answers
SOURCE: Motor has started t0 smoke and trips circuit breaker
On the motors I deal with there is a series of numbers that identify the shaft size, hp and all other requirements. I would try and contact a local Grainger and see if they can help, if not try in the yellow pages for a motor repair shop in your area and sometimes they can get you one. Good luck
Posted on Jul 18, 2009
john224
  • 1378 Answers
SOURCE: Motor has died, how to disconnect from pump. 2
The thru-bolts hold it to the seal plate and the impeller is threaded onto the shaft.
Posted on Aug 10, 2009
john224
  • 1378 Answers
SOURCE: Wiring up Emerson 1081 pool pump. Using 230V. Is
Thank you for posting your question here on Fixya.com.
There is no polarity associated with the leads in an AC system. You simply have 2 hot wires and you can hook either one to either Line 1 or Line 2. Motor rotation is not dictated by the connection arrangement of these leads. Ground the motor with the grounding wire and again with the bond wire if one is present.
You can remove the riser that is positioned under the motor to allow for a 56 size stator to fit in place of the 48 size stator the original Hayward (AOSmith) motor was.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Nov 02, 2010
  • 990 Answers
SOURCE: I HAVE A 5PXG3 SPA
You may need to break an air lock. The pump is at the bottom of the system so you can bleed the air out by just opening the drain valve till you get water out of it, just a few seconds. That should get you going.
Posted on Dec 04, 2010
I have a 220 volt gfi breaker tripping its new install how does the gfi wire up
The bi-metal motor overheat protection switch is internal and it is activating probably with or without the ground fault interrupt they prevent electrocution and other devastation, do not modify anything. Do not hesitate, seek a very experienced pool electrician, NOW.
Jun 01, 2015 | Century B2859 2 HP Centurion 230/115 Volt...
Leak from motor
We need the make and model of the pump (ex. Hayward Super ll, Pentair WhisperFlow), and where the leak is. Your motor will fit a lot of different pumps. Thanks.
Feb 23, 2014 | AO Smith Pool & Spa
Emerson pool spa pump leaking water-how to change gaskets
Emerson is not the name of the pump, that's the brand of the motor attached to the wet end, and the two together make a pump.
1081/1563 only means that it meets the standards for a pool motor.
provide make and model, for your pump.
Jan 23, 2014 | Emerson Pool & Spa
Trouble 3 hp motor
What kind of problems are you having with this motor?
Rod
US Parts Center
May 03, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
Capacitor type
take capacitor to electric supply store to match up
Apr 20, 2012 | Century New Magnetek Pool Spa Pump Motor...
I have a Century 1081 115v, 2 speed pump for my waterfeature. The motor runs fine in low and high spped, the pump impeller is spinning but it dies not pump water.It is a 3/4 horse. The waterfall reservoir...
I don't know the answer to this ... your pool service company can advise you. To my way of thinking, you are asking a lot of a 3/4 horse. I have a 1 1/2 horse lifting water in a two inch pipe about 4 feet to my water feature with no reservoir.
Since you have a two inch pipe, why not run a bigger motor? I have two HP on all my filtered lines which are 2" suction and 2" discharge.
Are you absolutely sure you have suction? ... and no air leaks on the suction side?
Apr 24, 2011 | Century New Magnetek Pool Spa Pump Motor...
Wiring up Emerson 1081 pool pump. Using 230V. Is L1 terminal the one for the positive and the L2 terminal is for the negative? Replacing 1HP Hayward pump with .75HP Emerson motor which turns out to be...
John
Nov 01, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
I need to purchase a Emerson 1563 spa motor. Cat. 9352-9303 Model K55MYGRD-8367 hp 1/15 and 230 volts. Can you help me?
This place has them:
http://www.affordablespasandparts.com/Aqua-Flo-CMCP-R0-1-15-hp-230v-1-spd-02593001-2010GK.htm
Jun 27, 2010 | Pool & Spa
Pool & Spa Logo
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Ian Kime
Ian Kime
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
