During post I get the message " Alert! failed to detect one or more drives" How do I turn this alert OFF?
    Brigadier General:
  • 10,406 Answers
Turn your computer off.
Turn your computer on.
When you see: press <blah> to enter BIOS SETUP,
press the <blah> key.
Use the arrow-keys to navigate through the BIOS SETUP menu
to the "DISK DRIVES" (or something like that) item, and press ENTER to select that item.
You probably have one disk-drive "manually" defined that either:
* no longer physically is present or connected,
* no longer is responding to queries
Set that device to 'AUTO' or 'NONE'.
Save/Exit from BIOS SETUP, and restart your computer.
The message should be gone.
Posted on Dec 28, 2010
HOW DO I TURN ON THE AUTO MUTE ON A COBRA ESD 8285
When changing the Settings on your detector, please keep in mind: Each time the unit is turned On the factory settings of Highway and Auto Mute-On will be set. They can be changed while the unit is in use as described in the following sections.
Assistance Muting An Alert
Your detector allows you to quickly turn Off an audio Alert by momentarily pressing the Mute button. If you press the Mute button a second time during the Alert, the audio Alert will be turned back On.
Auto Mute Mode Auto Mute will automatically reduce the audio volume of all alerts after four (4) seconds for as long as the signal is detected. The factory setting for Auto Mute is On.
Highway/City Mode Setting your detector to City mode delays all X band audio alerts at lower signal strength levels. (A single beep will sound when the signal is first Notice detected.) This will reduce false alerts while you are driving in, or near, urban areas where there are many sources for conflicting X band signals such as microwave towers and automatic door openers. To change settings, follow the procedure listed below, which indicates what you will see and hear as you complete each step. The factory setting is Highway mode.
Highway Mode City Mode
Mute Button Press and release
To Turn Auto Mute Off X Ka L S
City Button Press and release
Press and release the Mute button while no alert is occurring.
Jan 27, 2016 | ESD-8285 Radar Detector
I have a Dell Precision 450.I am getting a "Previous Voltage Failure" alert. How to turn of this power up aler?
If you are still getting it then either your CMOS battery has failed, or your computer power supply has failed,
Apr 15, 2013 | Computers & Internet
How do you turn off amber alert on a lg motion cell phone
Go to your text messages, message settings, and it's at the bottom. The Amber alert messages were driving me mad as well.
Mar 23, 2013 | Cell Phones
I have a dell and it said that i had a chassis intrusion I dont know what it means nor what to do help
That just means the case of the desktop was opened by someone.
http://phubner.eng.ua.edu/Files/Optiplex%20GX620/advfeat0.htm#wp1124663
Security Chassis Intrusion Detection note.gif NOTE: When the administrator password is enabled, you must know the administrator password before you can reset the Chassis Intrusion setting. This feature, if installed and enabled, detects that the chassis was opened and alerts the user. To change the Chassis Intrusion setting:
  1. Enter system setup.
  2. Press the down-arrow keys to move to the System Security option.
  3. Press <Enter> to access the System Security option's pop-up menu.
  4. Press the down-arrow key to move to the Chassis Intrusion setting.
  5. Press <Enter> to select an option setting.
  6. Press <Enter> again after you update the option setting.
  7. Exit and save system setup.
Option Settings
  • On - If the computer cover is opened, the setting changes to Detected, and the following alert message displays during the boot routine at the next computer start-up:
Alert! Cover was previously removed.
To reset the Detected setting, enter system setup. In the Chassis Intrusion option, press the left- or right-arrow key to select Reset, and then choose On, On-Silent, or Off.
  • On-Silent (default setting) - If the computer cover is opened, the setting changes to Detected. No alert message appears during the boot sequence at the next computer start-up.
  • Off - No intrusion monitoring occurs and no messages appear.
May 27, 2012 | Dell OptiPlex GX620n PC Desktop
Alert! Chipset Heatsink not detected. System halted! is the alert that comes up when I turn my computer. What can I do?
Hi scotteg71121...
The alert is caused by a loose chipset heat sink.
Dell has a self test that prevents further damage by halting the system and displaying the message Alert! Chipset heat sink not detected. System Halted.
The solder joint seems to fail from constant tension and heat.
If you find the missing clip inside the computer you can solder it back in place and reattach the chipset heat sink wire hook.
If you can't find the clip you can replace it by bending a thin piece of wire in a half circle.
You can see a picture of where the clip goes on your computer motherboard by following the link below.
Please take time to rate me
http://www.aplusperfect.com/articles/chipset-heatsink-not-detected
Sep 05, 2011 | Dell Dimension 4600C PC Desktop
When I try to upload a video to youtube using imovie 11 it immediately says "Alert Youtube has reported an unknown error" I have uploaded about 30 videos with imovie 11 before and they have never...
In the system settings, go figure the gmail account that has your YouTube credentials.
better yet, export the movie file and open it in into the default movie player, select 'share' from the toolbar and post to YouTube, or you can right click on the video file and share it.
Apr 21, 2011 | Apple iMovie
Led display shut down when the detector detect an alert
You have the unit in dark mode. Press the Dim/Dark button again to get the unit to full brightness. THe unit has 3 levels of DIM. First the unit is at its full brightness, pressing the dim/dark button will dim the display and the unit functions normally. Press the Dim/Dark button again will futher darken the display but when the unit alarms the display is turned off and remain off during the alert. After the alert is over the unit waits 20 seconds of no alert to turn the display back on.
Mar 09, 2011 | DE-1740 Radar Detector
I tried to install "Red Alert 2" on my PC. and
Hi, try installing your red alert 2 installer to another computer.If it works your computer might be the problem. Check if you have enough space for the game.Try changing the destination folder. If it does not work your installer might be the problem.
Feb 26, 2011 | West Wood Studios Command and Conquer Red...
How to change Message Alert tone
The msg alert tone depends on the current sound profile of your phone (like normal, silent, driving etc).
1. Go to main menu -> settings -> phone profiles. You should find all the profiles available in the phone. For example, we will change the msg alert tone for 'normal'.
2. Tap on the box with the double arrow (>>) symbol next to normal. You should enter a screen saying call alert type, voice call ringtone etc.
3. There is a drop down menu at the top right side of the screen. Tap that and select 'new messages'.
4. 'message alert type' should be melody or vibration & melody, depending on your preference.
5. now select 'message alert tone'. The phone has a number of tones already stored. Select one of these.
6. Or select 'sounds' at bottom right and browse to any file you want to set as message alert tone instead..
7. Save and exit !!
----pls rate if you find it useful-----
Jan 05, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Message alert
hi..you can turn off the message alert by going to
the settings.The settings will be available in the
menu.
try this out..
thank u..
kindly rate my response..
May 09, 2009 | Samsung SGH-U600 Cellular Phone
Computers & Internet Logo
564 people viewed this question
David Payne
David Payne
