Question about Logitech X-530 Computer Speakers
X-530 The Woofer and 2 side speakers work only???
  • Richard Roberts May 11, 2010
    What type computer are you using? Laptop?
I am using a Desktop, Windows Vista Premium.
Posted on Jul 20, 2008
4 Suggested Answers
  • 1043 Answers
SOURCE: When connecting the leads to the sound card do i
There are leads that need to be connected to your computer for the Front, Rear, and Subwoofer speakers Not all motherboards have all of these connections Your Logitech manual shows how to connect the speakers correctly if you do not have all of the connections on your motherboard
Posted on Sep 14, 2009
bronk50
  • 27725 Answers
SOURCE: hi, only 2 speakers work and the sub woofer also
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 22, 2011
Only have the sub itself, Can I still use it and if so how?
Unfortunately you will not be able to use the sub-woofer by itself because the input for the Logitech X-530 has a special cable to connect to the sub-woofer. You could always try looking on eBay or Craigslist for replacement parts.
Aug 18, 2011 | Logitech X-530 Computer Speakers
Only 2 speakers work and the woofer...and i cant open your manual for the schematic
in xp sound setting set 5.1 channel not 2.1. and in vista tick sorround mode.
Jun 12, 2011 | Logitech X-530 Computer Speakers
My logitechh x-530 speaker system just quit, all of it. i moved my computor location from across the room and it no longer worked. i have connected and re-connected but no luck.
Just try testing the fuse in the 3 pin plug first, off chance it may have gone. Then, if that shows as OK, and you feel confident, remove the back of the Woofer and make sure that the AC wires have not come loose (can't remember if there is an inline or separate fuse in the woofer, if there is, i'd check that
Dec 29, 2010 | Logitech X-530 Computer Speakers
Only 2/5 of the speakers are working and the sub woofer is also working
You`ve connected only the green jack from the system,you need to connect all the tree of them using the adapter you got in the package
Aug 08, 2010 | Logitech X-530 Computer Speakers
Could you tell me what plug in ports i need for X540 or 530- on my desktop
You need three ports in order to use all the speakers 5.1 sound. They are all headphone jacks but they are front speakers, rear speakers, and sub/center
http://www.newegg.com/Product/ImageGallery.aspx?CurImage=36-121-006-S04&SCList=36-121-006-S01%2c36-121-006-S02%2c36-121-006-S03%2c36-121-006-S04%2c36-121-006-S05%2c36-121-006-S06%2c36-121-006-S07%2c36-121-006-S08%2c36-121-006-S09%2c36-121-006-S10%2c36-121-006-S11&S7ImageFlag=2&Item=N82E16836121006&Depa=0&WaterMark=1&Description=Logitech%20X-540%2070%20watts%205.1%20Speakers
8th pic
Apr 06, 2010 | Logitech X-530 Computer Speakers
Can find driver for logitech 5.1 x-530 speekers
eBay you might type in major brand on eBay you can get a 5.25 Polk woofer for super cheap may not be logitech but iv done it and to me it sounded good. about to buy a logitech x 530 speaker set for my z 640 surround its compatible if you want the sub woofer than email me if not you can eBay your system and get a busted one to pull pars from.
Mar 12, 2010 | Logitech Audio Players & Recorders
X-530 logitech surround speakers how do I install please
coming from the speaker with volume control, there is a cable with 3 jacks, connect them while your computer is running, yellow to pink, green to green, black to blue. a window should open asking what you connected. green is front, yellow is center/sub, black is rear
Dec 27, 2009 | Logitech X-530 Computer Speakers
When connecting the leads to the sound card do i plug one into the pc. and should all the speakers work straight away,I only have thee woofer and the centre speaker working.. LOGITECH X-530
Sep 14, 2009 | Logitech X-530 Computer Speakers
Woofer and two front speakers work, nothing else.
Did you configure your computer to use theother speakers. Go to control Panel and then Sound and you should be able to configure it there. it also depends on what type of sound card your computer has.
Jun 13, 2009 | Logitech X-530 Computer Speakers
Speakers not working correctly
pls swap the spk pin in to your sound card jack socket . bye
Sep 22, 2007 | Logitech X-530 Computer Speakers
Logitech X-530 Computer Speakers Logo
37 people viewed this question
Top Logitech Audio Players & Recorders Experts
sonic boom...
sonic boom...
masterwest
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
