Keep getting an error #3528. It says to do something with the back access panel and I can't find an access panel!
    Problem Solver:
  • 8 Answers
Look at the rear of printer there is a area in the middle of the printer at back side turn the knob and the rollers will be exposed..clean them with water if you have nothing else. put the cover back on correctly ..make sure it is on correctlly.....
Posted on Dec 28, 2010
How do I clear kodak esp 2170 error 3528
To resolve the error:
  1. Press the On/Off button on the printer control panel to turn off your printer.
  2. Wait 30 seconds.
  3. Press the On/Off button to turn on your printer.
Jul 28, 2014 | Kodak ESP 2170 All-In-One InkJet Printer
Error code 3528
Look at the back of the printer, you will find 2 latches at the back of the printer, you need to press those latches to open the rear access door. once the rear access door is open you can take the paper that is stuck inside the printer.
Jun 26, 2014 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak 3.2 ESP has an error clear all paper code 3528 but there is nothing there
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Feb 04, 2013 | Kodak ESP 3 Multifunction Printer/ Copier/...
Esp 5250 error code 3528
Hello Shaheen,
Try this:
  2. Wait 30 seconds.
If the error continues, double-check that all paper and foreign objects are removed from inside your printer.
NOTE: Even if you do not physically see a paper jam, you will need to follow the paper jam link to solve the error.
Paper Jam Error
Oct 19, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer keeps displaying error 3528 there is no paper in it and has never been any please help
Hello, Welcome to FixYa!
Error 3528 in Kodak Printer is mostly because of paper jam. their may be small bit paper jam in side. There are some "micro-sensors" that detect a paper jam. To solve it
Try taking off the roller access panel in the back and make sure that the printer has not picked up a sheet of paper somewhere in the path.Also make sure that sure that really there is no piece of paper paper, dust or foreign objects.If you have seen and you are sure that there is no any paper or foreign object then Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air. Turn the printer On and check. If you still face this error then try a trick may be it can resolve the issue.
Press the On,Off button on the printer and turn off your printer. Now wait for 30 seconds.Press On button to turn your printer On and try printing.
If still there is an error then then probably your Kodak ESP 3 Multifunction Printer/ Copier/ Scanner is in need of servicing by a service professional.
I hope this solution helps you.
Thank you for using FixYa!
Sep 13, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I've just bought a new kodak printer ESP3250 last week, and installed everything and got it set up fine. It was printing fine after I installed it but suddenly stopped after I had printed a few sheets. The...
Sounds like there is a sheet of paper jammed in it. Try taking off the roller access panel in the back (not the access panel by the cartridges). Make sure to only use clean sheets with proper humidity level to avoid jams. Also fan the sheets before feeding to disperse any static.
Mar 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My kodak esp5210 printer is showing paper jam remove rear access cover. clear all papper. attach cover. press ok to continue. (code 3533). ive followed the instructions but nothing changes. there never...
I've got exactly the same situation/circumstances and error code, the thing different is that my code changes between 3533 and 3528? sorry I;m no help right now but I'll be back if I solve it. Martin. (Banksy100@hotmail.com)
Feb 11, 2011 | Office Equipment & Supplies
Error code 3528 keeps coming up,telling me to remove back cover and remove paper jam then replace back cover.there is no paper jam,checked printer heads no paper anywhere?
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Sep 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
114 people viewed this question
jasbo
jasbo
