Question about Microsoft Streets & Trips 2009 Full Version for PC
A LICENSING INITIALIZATION ERROR HAS OCCURRED. PLEASE CONTACT CUSTOMER SUPPORT FOR MORE ASSISTANCE.
What is the 59 CO error?
59.C0 Developer motor rotation error
1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
2. If the problem continues, contact HP Customer Support Center for technical assistance
Sep 09, 2014 | HP CC377AABU Color Laserjet Cp1515n...
Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
E7 error on display for hp laserjet m 1136 mfp printer
From the manual E7 indicates "A fatal error has occurred from which the unit cannot recover.
Turn power off/unplug. Wait 30 seconds, then plug in/turn on. Allow unit to initialize. If problem persists, contact HP customer support"
Aug 23, 2014 | Office Equipment & Supplies
Quickbooks error 3371
When you register or open QuickBooks, you see one of these error messages:
  • Could not initialize license properties. Error 3371: QuickBooks could not load the license data. This may be caused by missing or damaged files.
  • Could not initialize license properties. [Error 3371, Status Code -11118] QuickBooks could not load the license data. This may be caused by missing or damaged files.
  • Could not initialize license properties. [Error: 3371, Status Code -1] QuickBooks could not load the license data. This may be caused by missing or damaged files.
Important: This issue can occur if your product is hosted by Right Networks and you access QuickBooks with WebConnect and then select to open the file without saving. If you use QuickBooks Enterprise and your product is hosted by Right Networks, you must save the file and then import it.
How to fix it:
Before proceeding, ensure that your copy of Microsoft Windows is up to date.
If the latest Windows updates are not installed, the QuickBooks installation can fail or become damaged. To install the latest updates in Windows, click the Windows Start or Logo button, choose All Programs > Windows Update. Once started be sure to install any updates marked critical.
You may need to re-install your software. Have your license number and product number for your version of QuickBooks ready.
Try these steps in the order shown. If the first one fixes the problem, you do not need to do the other steps.
Re-create damaged EntitlementDataStore.ecml
  1. Close QuickBooks if it's open.
  2. Open the entitlement data folder for your operating system and version of QuickBooks.
    1. On your keyboard, press Windows + R to open the Run window.
    2. Enter (or copy and paste) the following information, and then press Enter
      • QuickBooks 2014 and Enterprise 14.0: C:\ProgramData\Intuit\Entitlement Client\v8
      • QuickBooks 2013 and Enterprise 13.0: C:\ProgramData\Intuit\Entitlement Client\v8
      • QuickBooks 2012 and Enterprise 12.0: C:\ProgramData\Intuit\Entitlement Client\v6.0
      • QuickBooks 2011 and Enterprise 11.0: C:\ProgramData\Intuit\Entitlement Client\v6.0
      • QuickBooks 2010 and Enterprise 10.0 : C:\ProgramData\Intuit\Entitlement Client\v6.0
      • QuickBooks 2009 and Enterprise 9.0: C:\ProgramData\Intuit\Entitlement Client\v5
      • QuickBooks 2008 and Enterprise 8.0: C:\ProgramData\Intuit\Entitlement Client\v5
      • QuickBooks 2007 and Enterprise 7.0: C:\ProgramData\Intuit\Entitlement Client\v3
  3. Right-click the EntitlementDataStore.ecml file and select Delete.
  4. Click Yes to confirm you want to delete the file.
  5. Open QuickBooks, open your company file, and follow the instructions to register the application.
Jan 30, 2014 | Computers & Internet
Need satzo 2.4 license key
Contact the software manufactures or distributors customer support and they will assist you, otherwise the keys are normally provided with the paperwork for the software when you purchased it.
Mar 18, 2013 | SATO Label Gallery TruePro Full Version...
""an internal error occurred in the initialization
Hi! Welcome to www.fixya.com.
You can go to this website and follow the instructions
http://support.microsoft.com/kb/929135
Thanks for contacting Fixya. Bye for now.
Jul 23, 2011 | Lenovo G460 Laptop Computer 06774CU Intel...
The error, LaunchEmptyResponse, occurred when trying to connect to Yahoo! Mail
It is a server error; every place I have researched has the same answer, except this one give you a place to contact and complain:
Yahoo URL / Contact Yahoo! Customer Care
"If you are having issues with your own Yahoo! Mail account, please click here for assistance and select whichever Mail interface you are using"
http://help.yahoo.com/l/us/yahoo/mail/postmaster/forms_index.html
Some people have been down for as short as two days, others have not been able to access their accounts for two weeks.
I hope this helps....
Thank You For Choosing FixYa~!
Mar 20, 2011 | Yahoo Mail
Ihave hp 2600n printer error 55.1 & i turn it off and open with out soved pls help me thank
DescriptionDC controller error. The device has experienced an internal hardware error. Action
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information. 55.xx PRINTER ERROR alternates with CYCLE POWER TO CONTINUE An internal communications error occurred. The page containing the error will automatically be reprinted. 1. Check the power at the customer’s location. 2. Replace the formatter and/or firmware DIMM. 4. Replace the engine controller board. 5. Replace the formatter board. On the 5si, 8000, 8100 this could be a fuser problem. Try replacing the fuser.
Apr 11, 2010 | HP Color LaserJet 2600n Printer
Hp color laserjet printer gives 55.1 error
  1. Follow these steps to ensure proper reinstallment.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.If the same error message occurs, reinstall the driver that came with your printer, or go to hewlett packards' website for the driver there.If you have done all of these steps and no help go to step number 3.
Nov 25, 2008 | HP Color LaserJet 2600n Printer
Unlock code
SIM Cards and Unlocking your Phone What is a SIM?
Subscriber Identity Module (SIM): A smart card containing the telephone number of the customer, encoded network identification details such as: Call Forwarding, Caller ID, etc., the PIN, and other user data such as the phone book. T-Mobile customers can move their SIM card from any T-Mobile branded phone to any other T-Mobile branded phone without the need to contact Customer Service to activate the new phone. Your rate plan and phone number will follow your SIM to the new phone.
SIM Error Messages:
  • Invalid SIM: This error means that the SIM you have inserted into your phone is either inactive or is not compatible with our service. You may purchase a new SIM card from a T-Mobile retail location. Locate a T-Mobile retail store near you.
  • Insert SIM: Your SIM is either not inserted in your phone or is inserted improperly. Please remove and re-insert your SIM card. If you continue to receive this error message, your SIM card or phone may be defective. You may take your phone and SIM to a T-Mobile retail store for further assistance and a free SIM card replacement if necessary. Locate a T-Mobile retail store near you.
  • Unregistered SIM: This error may occur if your SIM card is not fully activated or if the SIM card registered to your account is different than the SIM you have in your phone. For assistance with this issue, please contact Customer Service.
  • SIM Not Ready: This error occurs when you have just powered your phone and is due to the phone not being fully initialized. Please wait a few moments before accessing your phonebook or placing a call.
  • OTA OK: This message is displayed when your phone receives a network update, phonebook download, or an Over-The-Air t-zones or Picture Messaging configuration. NOTE: These messages are free of charge and will not be billed to your account or pulled from any text message bucket.
  • Enter PUK: These errors can occur if you have entered your SIM PIN three times incorrectly. If you receive this error message, please contact Customer Service for a PIN Unblocking Key (PUK) to restore access to your phone.
  • Check card, Card Blocked See Supplier, Blocked, SIM Blocked, or Contact Card/Service Provider: These errors may occur if you have entered your PUK ten times incorrectly. If these errors display your SIM is unusable and you will need to purchase a new SIM card. You may purchase a new SIM card from a T-Mobile retail location. Locate a T-Mobile retail store near you.
SIM PIN:
A SIM PIN can be used to prevent access to your phone. When enabled, your phone will prompt you for the SIM PIN when the phone is powered on. Entering the wrong PIN will prevent you from making or receiving calls. SIM PINs are different from a Security Code that your phone may use to secure other phone functions. Please check your phone’s manual for further security details.
T-Mobile SIM PIN numbers are set to default values before purchase. If you change your SIM PIN, it is recommended that you keep record of the new PIN in a safe location. T-Mobile cannot retrieve a lost or forgotten SIM PINs.
  • SIM PIN1: 1234
  • SIM PIN2: 5678 (Only available on select phones)
SIM Unlock:
T-Mobile branded phones operating on the T-Mobile network may only use T-Mobile SIM cards. To use a T-Mobile branded phone on another wireless carrier's network with a non-T-Mobile SIM card, you must first request a "SIM Unlock" code from T-Mobile. Conversely, if you have a phone from another North American wireless carrier, you may need to request a "SIM Unlock" code from that carrier before being able to use a T-Mobile SIM card on the T-Mobile network.
SIM Unlock Requests:
T-Mobile customers must meet the following eligibility requirements before contacting Customer Service to request your SIM Unlock code.
The following restrictions apply to all account types:
  • T-Mobile can provide SIM Unlock Codes only for handsets sold by T-Mobile USA, with the exception of Danger Sidekick devices. T-Mobile can obtain SIM Unlock Codes for companies acquired by t-Mobile USA (VoiceStream, Aerial, Omnipoint, SOL, Digiph, PCS One, and Powertel).
  • SIM Unlock Codes will only be provided after your account has been active for 90 days. Only one unlock code may be provided per customer every 90 days.
  • No SIM Unlock Codes will be provided within the 14-Day Buyer's Remorse period. Customers who purchase phones in CA California or via Amazon.com are granted a 30-Day Buyer's Remorse Period.
  • SIM Unlock Codes are not always available from the Manufacturer. However, T-Mobile will make a dedicated effort to obtain the SIM Unlock code. Note: Other restrictions may apply depending on account type.
Goodluck
Jan 10, 2008 | T-Mobile Wing™ Smartphone
Microsoft Streets & Trips 2009 Full Version for PC  Logo
684 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
