Question about Lands Phones
Calling Vectone mobile help desk support for vectone is noghtmare... it goes option after options and finally you cant talk anyone to explain internet access/setup problem as there is no option there in voice Menu... It is really horrible and dont know how people in UK survive with this.... I am unable to connect to internet using my Samsung Guru mobile phone. I am using Vectone mobile and they say 10MB/day is free. Not able to connect to internet.. To call helpdesk no such option intheir menu... customer care number is 111.
SOURCE: Unable to access most functions....
Hi !! If you dont plug park brake and light switch, some options will be blank. Turn off power supply conect those plugs (im advice you to do not conect speed cable). Turn on them reset the unit.
P.S. The park brake cable can be conected with tre ground. This way you can watch dvd with the car in moviment...
Go to the panasonic web and download the last update for your unit !! http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/Mobile-Navigation/model.CN-NVD905U
I hope it helps yous... sorry my english....
Posted on Nov 27, 2007
SOURCE: Caller ID Stopped Working - Think the phone needs to be reset?
Not sure why this worked, but I went to the Menu and the Set Area Code selection. The area code setting was blank, so I entered my area code and saved it. Caller ID started to work again. As a test, I went back to the Set Area Code selection and deleted the area code and saved it. It is currently still working. Seems really odd, but it worked for me.
Posted on Feb 24, 2008
SOURCE: samsung mobile phone r410
Goto this link if you want to learn how to add mp3 ringtones to your phone and connect to your pc or laptop
Brahmaleo,
http://www.youtube.com/watch?v=iO2Elp870bE
Posted on May 13, 2008
SOURCE: can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
Posted on May 13, 2009
  • 8 Answers
SOURCE: access the menu options manually
Press the set's Volume (+) and (-) buttons simultaneously to activate the Menu display. Use the Channel Down button to scroll to the desired menu item, then use Volume (+) or (-) to change that item, or to activate a sub-menu if any. (If in a sub-menu, again use Channel Down to reach the desired item, then Volume (+) or (-) to change its setting or value.) When finished, press Volume (+) and (-) simultaneously as needed to "back out" of the menu.
Not all set functions can be reached this way, especially a few involving numeric entry; but this will get you started. Good luck!
Posted on May 22, 2009
Whats vectone sim card puk?
For details to obtain the PUK code, please click on thislink and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
Aug 30, 2011 | Samsung Cell Phones
I want to change my mobil sim usage from vodafone to vectone.
Contact vectone and they will tell you if it is possible. If it is they should help you change it.
Apr 08, 2011 | Cell Phones
I have an SciPhone i68 4G. It is a dual sim phone. I tried putting my T-Mobile sim card in with a Vectone sim card and I found that I was having trouble with the battery. It would turn off even when I was...
TO SEXYBABE008 -I HAD THE SAME PROBLEM YOU ARE HAVING. THERE ARE TWO SLOTS FOR THE SIMS CARD- THEY ARE ON TOP OF EACH OTHER- IF YOU ARE ONLY USING ONE SIMS CARD- PUT IT ON THE TOP SPOT WHEN INSERTING IT- THIS WORKED FOR ME- THE BATTERY HAD NIOTHING TO DO WITH.
Mar 01, 2011 | Cell Phones
Want My Vectone Mobile PUC Code........07550216342
If you mean the PUK code of your phone, it is found in the Sim pack. It is the 8 digits code that you find on the Sim card carrier. Phones do not require PUK code, the Sim card does.
Check on the Sim cards pack, you will see the Sim card carrier where you broke the Sim card out of, there are some codes on it. You will see your number, the pin code and a 8 digit code, then you will see the bar code at the bottom of the card, it is the 8 digit code that is the PUK for your Vectone mobile.
If you do not have your pack anymore, what you have to do is to contact the Vectones customer care center, so they will be able to give you your PUK code, but the y will ask you for some security informations, which are easy to answer, after providing the answers, they will give you your PUK code.
Hope this helped.
Jan 07, 2011 | Cell Phones
My vectone mobile sim card is lock i need puk code for 07574149168
my vectone mobile sim card is lock i need puk code for 07574594312
Oct 31, 2010 | Health & Beauty
I need internet setting for my vectone mobile
The best thing to do is call your network supplier.Explain the situation and they will put you right.Plus its free!
Hope i`ve helped!
Jan 03, 2010 | Nokia 2730 Cell Phone
I have a vectone sim card, i had also provided a pin code so that next time i switch on my mobile it will prompt me for a pin to enter, but i have forgotten my pin how to knoe the pin code which i used...
you just enter pin code for three times so it will ask for puk code....You can call to your network provider customer care service and ask for puk code. They will give to you Such that your pin code will get reset..Hope this will help you....Thank you....
Nov 06, 2009 | Computers & Internet
Lands Phones Logo
177 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
