How i decode scrambling canals in eutelsat-w2
How to unlock scrambled channels on free to air decoder type super california
Feb 19, 2011 | Vacuums
I cant watch sabc 1,2,3.they are scrambled yet all my collegues watch them using other decoders models
You should not need a decoder for SABC 1,2,3, the signals are not encoded. If you are having problems with the picture quality you ar most likely using a UHF antenna where the SABC programs are broadcast in VHF at present. Fit an additional VHF antenna and a combiner box or change to a universal antenna.
Jan 17, 2011 | Garden
How to unlock e.tv in mytv decoder and how to open scrambled channels in DStv?
How to unlock etv and scrambled channels on Mystrong Decoder
Nov 15, 2010 | Televison & Video
KVH M7 track vision problem.Not tracking
as you move east and west on the Mediterranean, you must adjust the LNB, rotate it, see book.
Jul 25, 2009 | KVH 01 0277 01sl Tracvision A7 Mobile...
The movies channel and sports is scrambled
these units are not ment to be used as a cable converter for the more premium service ;just some of the basic ones , it sucks but sorry you'll need a regular cable decoder box also.
Apr 02, 2009 | Televison & Video
Cannot decode virgin channels
i have just moved house and took my V box with me but i just want the free ch but it witt not work at all is there a code that i can put in it to get it to work?
Dec 18, 2008 | Televison & Video
Toshiba 50h12-reception problem with ant 1 & 2
the tv has a built in decoder. if its scrambled it may be on the wrong setting. try resetting tv to factory settings and see if it sorts its self out. if not it may need the av board changing as it has a fault with the decoder chip.
May 23, 2017 | Toshiba 50H81 50" Rear Projection...
Hook up
Contact ur ISP, tell them to turn off interleaving
Interleaving definition: Where consecutive bits are interleaved amongst other bits in the bit-stream over a certain period of time to improve ruggedness of data., A process of scrambling the order of symbols to be transmitted over a channel in such a way that, when they are descrambled (at the receiver), any burst of channel errors will be spread out in time and thus appear as random errors to the decoder.A process of scrambling the order of symbols to be transmitted over a channel in such a way that, when they are descrambled (at the receiver), any burst of channel errors will be spread out in time and thus appear as random errors to the decoder.
Feb 24, 2008 | Belkin (F5D7230-4) Router (587009)
Codes tv canal fr sat hot-bird 13degre
keys tv tps and canal+ fr in the sat hot-bird 13 degre
Jan 29, 2008 | Televison & Video
Is it the DCT or the cable signal?
if you are getting signal of the proper strength and quality the cabling is good.the problem is the box trying to decode the signals.a lot of signals are encripted and have to be decoded by the box.if the box is not responding fast enough you will see bloches on the tv.if you see scrambled channel you are not payinfor that channel.and if you are paying for a channel and it comes up scrambled your box is not working correct.get your company to upgrade the box.
Jan 07, 2008 | Arris DCT6200 DTV Receiver
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
