Question about Kenmore Oasis HE 27082 Top Load Washer
What does Code LD mean? When it is supposed to spin out, It stops and I get a code LD.
  • 57 Answers
LD is a long drain code usually mean something is in the drain line or pump area. Check thes areas first. If nothing blocking them then the pump is going out.
Posted on Dec 28, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My washer will not drain or spin and I get the code ld but if u mess with the motor it will run again
check the wires going to the motor they could be broken or the plug for the motor could be loose
Mar 19, 2014 | Whirlpool WTW6400SW Cabrio Washer
Won,t spin
A LD (Long Drain) error code means that (more or less), the drain pump is failing.
May 11, 2012 | Bosch Washing Machines
Gets to 8 minutes but wont go into spin cycle code ld comes up
  1. ld means long drain. If it takes too long to drain it won't go into spin or other cycles. It's possible that you have a blockage in your drain hose or pump, or your pump has gone out. Remove pump and check for any blockages. Replace your Drain pump if it is found to be bad.
  2. Also, some washing machines have a pressure sensor that can fail causing the ld code to come up.
  3. Last but not least, if the drain pump was replaced, and hoses were unclogged, and you still have the same problem, your control board may have failed.
Feb 25, 2011 | Whirlpool Washing Machines
Ld code on Bravo washer what does it mean
The "LD" code or "long drain" indicates a pump/drain related issue. Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Make sure nothing is clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure the impeller has no broken/missing blades and that it spins freely. If any blades are missing/broken or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or jammed impeller. Sorry for your trouble and I hope this helped. Best wishes.
Sep 14, 2009 | Maytag Bravos MTW6600T Top Load Washer
Giving ld code and won't spin
Hello Friend, (ld) means long drain. If it takes too long to drain it won't go into spin or other cycles. It's possible that you have a blockage in your drain hose or pump. Remove pump and check. I hope this info was helpful. Tim
Jul 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Stops between rinse and spin cycles giving a ld code..
ld sure sounds like lid switch problems. Suprised to see this so soon, but I did see one come apart on a fairly new Whirlpool. Luckily, it should be easy to check. Unplug the machine first.
Apr 29, 2009 | Washing Machines
What does LD and OB mean on my washer
I'm not sure what the codes mean but here is a site that may help with your problem..not sure but do try it if you like..
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Ld and ob codes
LD code means your pump is cloged with lint or small piece of clothing such as a sock. I had the same code on my washer and sure enough i found my pump cloged with lint from a blanket my wife washed. hope this helps. sorry I cant help on the other code.
Jan 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
HELP? ob & ld codes
Ld means long drain you probally have a bad water pump.Those models have a seperate motor for pump, the shaft on the motor is a star type and has probally stripped out the pump.Replace your water pump
Kenmore Oasis HE 27082 Top Load Washer Logo
767 people viewed this question
Sal De
fordexpert
Robert Rankin
