Question about Fuji FinePix A360 Digital Camera
I can't format a new picture card on my camera!
  • 2,386 Answers
Hello
If you are not able to format new card from camera then you may try format card through computer by using card reader,
if the card is new and not formating then you have option to avail warranty and replace this one.
hope this helps, if so do rate the solution
good luck
Posted on Dec 28, 2010
Camera says that 16GB scandisk card is full when I try to take picture
Try formating the SD card before you start taking photos. Go to the camera's Menu and scroll through the settings to Format memory card.
Jun 17, 2012 | Cameras
Format xd card error I bought new Fugifilm xD-Picture card, 1 GB, and putit in camera. Brought up format screen and attempted to format. All I got was "card error!". I thought the problem might be the...
Try formatting the card on your pc, connect the card to a card reader, open my computer find the card, right click format, try standard fat first and format. if that doesn't work try Fat 32.
Jul 16, 2008 | Olympus Camedia C-350 Digital Camera
When i turn on my camera it says the memory card needs formatting i follow the instructions but it doesnt work and keeps saying to format the memory card. this happens over and over and i cannot take...
To understand the photo loss situation, consider a scenario: You format a memory card in Digital Camera, and start to capture some pictures. However, while capturing pictures, your camera shuts down due to low battery. Now, after recharging battery, when you try to access those photograph on the card, you receive the following error message on camera screen:
The Card requires formatting: Additionally, the camera is unable to capture any new photographs.
The main cause for the above error message is corruption of memory card due to conking of battery while a read/write operation was running.
These memory card needs to be formatted before you save any new pictures. It is always a good practice to take backup of card and format it before use. This enables you to fight with any damage done to the memory card and to erase the old data saved on the card. However, the probability of card getting corrupted again (after you have saved new data) still exists.
First try formating with an external SD Card reader connected at PC and test it.
Oct 13, 2011 | Kodak EasyShare C143 Digital Camera
Card error or camra on or of problem
If the camera was working properly while taking the pictures on this card then the problem lies with the card. Format the memory card, formatting the memory card cleans previously taken pictures and allows for new pictures to be made. Even if you are using a "new" card it needs to be formatted to the camera it's being used in. Your camera dates back to 2004 so a problem I recently ran into with my own camera was I needed to update the "firmware" when I tried to use a memory card larger then 2gig. If you have just purchase a new card and it is larger then what you have been using this might be the case as well. The card error message may also be caused by removing the memory card from the computer without "ejecting" or "safely remove" which shuts off the connection to the card then disconnect. Another reason is if the user constantly deletes pictures and doesn't format.
Hope this was helpful not not confusing.
Dec 22, 2010 | Fuji FinePix S7000 Digital Camera
I put a new card in my camera because my last one was full. Then I took several pictures. All of the sudden i get a message saying "memory card needs formatting." I pressed "ok" format. It deleted all of...
First of all, do you know you're supposed to download the pics from your full card to your computer and then format the card in the camera? Keeping them on the card is risky since the cards are not made for long term storage. The pics can degrade over time. Formatting completely erases a card and that's what happened with your new card. All new cards should be formatted in the camera before using....that's what your camera was trying to tell you.
Jun 23, 2010 | Kodak EasyShare CX4310 Digital Camera
We took our 512 mb SD Card out of our camera to download some of the pictures to a digital picture frame. When we return the SD Card to the camera amessage appears "memory card requires formatting. I know...
You can either use a separate card reader to download to your computer, or , take the card to a Walmart store and insert the card into a Kodak Picture Kiosk machine and print the pics or make a cd of them. Then, format the card in the camera.
Apr 22, 2010 | Kodak EasyShare CD40 Digital Camera
I have a new canon power shot a580 and have used a kodak 2gb memory card. I started with an empty card, took approx 30 pictures and then "memory card error" shows up on my little screen. I can't retrieve...
Did you format the card in the camera first to initialize it? Use a card reader to download any pictures on the card to a folder you create on your desktop. Then, format the card in the camera.
Oct 13, 2009 | Canon PowerShot A580 Digital Camera
Memory Full
What size is the memory card. What picture size has the camera been set to? Check out your Manual for the images sizes viz a vis memory card capacity - and come back
Jul 13, 2007 | Casio Exilim EX-Z57 Digital Camera
Formating Smart Media cards
I would say that the card is starting to wear out. If you want to try to salvage the pictures, try something like "Smart Recovery" from Convar and then get a new card as the problem is likely to get worse: -
Sep 06, 2005 | Olympus D-320L Digital Camera
"Memory card cannot be read"
My camera used to do the same thing--once I got the pictures off my card, I left it in the card reader, right clicked on removable media (my computer + removable storage) chose to "format" and formatted it on my computer. It seems to have fixed the problem, and my camera now reads it fine. I tried to format it on the camera before, but it didnt work.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Fuji FinePix A360 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
