Question about Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum
My power mate keeps losing power. As I am vacuuming, it surges off and on. The rest of the vacuum works perfectly fine. help!
Remove the wand from the telescoping pole, and look at the two holes in the wand where the electrical connection is made between the wand and the pole. You may see corrosion, which will cause the connection to be flaky and the power assist to surge on and off.
In any case, a good bet is that the wire harness in the wand needs replacing. It's about $15. (P/N KC37GBZTZV06) You'll have to take the wand apart - 3 screws and some judicious prying - to replace it.
Posted on Jan 16, 2011
I have a hoover floor mate hard floor cleaner and the brushes won't spin
Hi, it's Jeremy from Crucial Vacuum.
In the link below you will find the user manual for your Hoover Floor Mate vacuum:
http://hoover.com/file/597/
Here are a few repair tips to make fixing your vacuum easy. Your Hoover brush-roll is connected to the motor by two different sized geared belts. Over time, the belt's gears wear down and stretch out losing the grooves and tension that turn the roller. When this happens you will simply have to attach a new set of belts. Another reason why your brush is not spinning could be that there is debris stuck in the roller and/or bearings. You can either use a can of compressed air to remove the debris or simply remove it with your hand.
You can purchase direct your replacement Hoover Floor Mate parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/index/?manufacturer=37&q=floor+mate
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 06, 2014 | Vacuums
I have a kirby g4 vacuum. Recently had a power surge and the vacuum made a whining noise and then stopped working. Please can someone tell me what i need to do to fix it. Thanks
A power surge might have damaged the power switch and/or motor. I would suggest it be checked out by a qualified vacuum repair technician.
Oct 30, 2013 | Vacuums
Power mate brush motor not coming on and overload rest not doing anything
I don't believe that there's any penalty for using the proper amount of words to give us a fair idea of what's going on or not, with your machine." Power mate brush motor not coming on" only gives us a bare minimum of info. Does the vac motor run alone, does it still run when you slide the selector to vac & P.M. or does it quit, have you tried pushing the little red reset button down?
Oct 22, 2013 | Kenmore Sears electric vacuum hose models...
I have a Kenmore canister vacuum cleaner. The
check the reset button or the wire that goes into the powermate sometimes it frays and breaks
Dec 29, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Power mate cuts off after a few secs.
You have a short somewhere. They can be tricky to find. You might need to take it to a repairman.
Dec 14, 2009 | Vacuums
Central vacuum power head no work
Looks like a Beam central vacuum www.beamvac.com, and a Kenmore vacuum head.
Reply what problems you are experiencing and I will try to help.
Jan 23, 2009 | Vacuums
Vacuum losing power
Sound like you may have a faulty circut breaker or thermal overload in the vacuum motor itself. If you got this vacuum from a specialty vacuum store you may be best to take it in under warranty. If you bought it from Wal mart, they will tell you that you have to go through the manufacture of the machine to get warranty work done... You might be best to take it in and have it checked.
Jan 19, 2009 | Rowenta Vacuums
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Kenmore whispertone model 11620412003
I am getting suction to the power mate, but the mate doesn't
work. The belt seem fine, but the light and beater doesen.t
go on. Tried the reset - no result. Thanks
Dec 29, 2007 | Vacuums
Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum Logo
474 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
