Question about Kenmore Elite 45986 Front Load Washer
Water pump not running, (code f02) bad pump ? bad relay ? how to tell witch is bad
  • 57 Answers
If the pump is not running or pushing water out then more than likely the pump. I rarely have to replace anything other than pump in this situation. It could also just be jammed, you will not know until you open up the machine and look in the pump impeller area. Make sure you unplug the machine and bail out all the water before opening up the pump. Or you will have a big mess. Shop vacs work the best in this situation of getting out all the water. Also call to make sure the closest parts store has a pump for your model on hand to get it just in case you need one.
Posted on Dec 28, 2010
My whirlpool duet washer had a F02 code now it won't pump water
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Aug 24, 2014 | Whirlpool Washing Machines
Whirlpool washer ghw9150pw0, error message f02. I have removed, cleaned and checked all drain lines and checked backflow ball. everything is good. May I assume the pump is bad.
HELLO THERE AND THANK YOU FOR CHOOSING FIXYA
The f02 error code is a long drain error meaning the following and here is what needs to be checked before replacing the pump
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Jun 06, 2011 | Washing Machines
F02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not wash complete load. flashed f02, water not draining
F02 stands for long drain
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
you can press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
you might want to check..
• If the above does not correct the problem most probably you will have to replace the pump
Jul 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F02 error
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Potential Causes
• If the above does not correct the problem replace the pump
Mar 25, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a kenmore elite h3 washer - Bad Water Pump?
HI. this code represents a Long Drain issue.
Potential Causes
• Check the drain pump filter for foreign objects(located, and mounted on the actual pump)
Nov 02, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet washer will not spin out water, shows F02, already checked the hose for kinks and/or clogs?
Potential Causes
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Model GHW9150PW0 shows code F02. The washer did nor complete the spin cycle and water was left in the tub. How do I get access to the pump. How do I remove the panels. Thank you
Potential Causes
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We get a F02 error relating to drain
F02 is the code for long drain. Your filter on your pump is probably clogged with lint and other stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Nov 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
HE3 Code F032
I remove the pump and found out that the impellor was worn , I have replaced the pump and the machine is working , no more F02 Codes .
Nov 14, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
