Why cant i get on internet threw my wirless linksys rangeplus wireless notebook adapter even though it says i have 100 per cent connectivity there is a window poping up saying this connection has limited or no connectivity
Well first u have to config the wireless..making sure it has full internet access...or the ap to the internet needs to be checked and enabled, it must be shared.
Posted on Dec 28, 2010
Ok i have a linksys wireless-b 2.4ghz and i was woundering if you could use it to pick up from anothe router in the area or like at an internet hot spot or something
you can, but it depends on the wireless standard that the hot spot is using. if the wireless network that you are connecting to only uses a standard, you will not be able to connect. newer wirless routers uses a/b/g and draft n standard for their wireless.
Feb 20, 2010 | Linksys 2.4 GHz 802.11b Wireless - B...
Linksys Wireless Adapter that will not find the internet
I think you might be using the Linksys utility.
you can switch over to windows utility if it is XP or VISTA.
that will resolve the problem.
make sure that it will be connected to the network and should have proper IP address
Click Here for more info about wireless network set up
Oct 12, 2009 | Linksys Ultra RangePlus Dual-Band...
HOW DO I SETUP WIRELESS ADAPTER MODEL WPC 100 RANGEPLUS
run the software first it will tell you when to install the card into your PCI slot. It is pretty straight forward, follow the directions given.
you'll need a profil (the name of your network...assigned by the software or you choose yourself.
your internet password
your wep/wpa number ...wep is 10 digitd wpa in stronger security but a little harder to work with.
After you have the hardware and software...I recommend you call your ISP like Verizon, Comcast or whatever and let the take over your computer and make the settings chages. They are great at this. And too you are paying for it as part of your service .
Good Fortune...pleas leave a rating...thank you kindly...
Apr 25, 2009 | Linksys Rangeplus Wireless Pc Adapter
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
Linksys Rangeplus works fine for short periods
improve your PC's cooling system and your wireless adapter will work fine. you can attach a USB cooling fan to do the trick.
Jan 25, 2009 | Linksys Rangeplus Wireless Pc Adapter
Internet connection shows good bars but can't connect to web
first, can you please tell me if what OS are you using?
: if its VISTA or XP, please remove the network profile in your laptop ...
then search again for the network ... by the way what router are you using ? if its linksys please update this thread so that i can assist you if there is a need to reconfigure.
goodluck
Nov 25, 2008 | Linksys WUSB100 Wireless Adapter
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Network Adapter
time to upgrade the card to linksys wirless n ok those so old they lose conetcion allot in now days feild ok
Feb 04, 2008 | Compaq Armada M700 Notebook
Computers & Internet Logo
197 people viewed this question
David Payne
David Payne
