Question about Kenmore Washing Machines
The tub won't drain and the agitator will not turn. Motor having a tough time.
  • 57 Answers
What model of machine is this ?
Posted on Dec 28, 2010
If it fills with water but won't wash, is it the timer
hi mary,i just wrote and asked you for the model number,if this is a regular top load washer it could be the timer as long as you don't hear the motor running,if you do hear the motor running you could have a broken motor coupling because the drain pump is on the motor shaft so it will drain,
http://www.youtube.com/watch?v=9K1KHEogf3c
if you don't hear the motor it could be the timer,when it should agitate try tapping on the timer and see if it works,it has points in it and they can get stuck together or burn out and have no contact like you're saying but it's just a guess without seeing it but if the timer is advancing through with no agitation it could be the timer,did you try any other cycles
Apr 02, 2013 | Washing Machines
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
The machine doesn't spin properly and doesn't drain the water
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
My 110 20862990 kenmore washer doesn't spin, the motor runs, it drains, and the coupling is in good shape. On another DIY page it asked to turn the drive side of the coupling one way to see if the...
My washer was doing the same thing. I had a magic marker on the bottom of the plastic tub below the inner tub. The agitation cam could not release for spin. I remove the magic marker and she took off.
This video shows how to get the inner tub out:
More here
More here
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
Washing machine won't drain but it will spin.
sounds like a motor problem, the motor turns 1 way to agitate and the other way to drain and spin
Feb 16, 2010 | Kenmore Washing Machines
KENMORE WASHING MACHINE MODEL#110. 254872300 WONT SPIN
if your sure it will agitate?[because the pump is on the other side of the motor and will drain,but if coupler broken ,wont agitate or spin although it makes noise like its working.so if will truely agitate drive coupler fine and its going to be the clutch or that area unless somthing[clothing] is between the two tubs creating anough resistance to stop the tub from taking off.clutch pads will just slip on drive plate.hope that helps>God bless ,tom
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Tub will not drain or spin
Dear customer,
i recommend you to kindly check the following parts of the washer..
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
    • Inspect the agitator
    • Inspect under the washer for soot (clutch)
    • Test the motor
    • Inspect the pulley
    • Test the transmission
    • Inspect the pump coupling
    hope u find it useful. thank you.
    Jul 06, 2008 | Admiral AW22 Top Load Washer
    Kenmore 22956 top loader quit running after agite cycle
    If the timer cycles your lid switch is ok.
    most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
    It is probably cost efficient to replace the unit rather than trowing parts at it .
    AB
    Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
    Washing Machines Logo
    14 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
