Question about Bose Lifestyle 20 System
My Bose 'lifestyle model 20 music centre' is not playin or ejecting any of the cds inside. It is also the noise of the disk changing yet nothing is happening.
5 Suggested Answers
SOURCE: Lifestyle 48 locked up
Just got off phone with Bose support with this very problem during install of a VS-2 software updtae to an older LS48 system. (Bose support personnel were very helpful on phone - and walked me through procedure to solve). I presume you unplugged and replugged power supply with no resolution. In that case, unplug power supply, wait 30 seconds and while holding down the "open/close button" and the "store" button (on media center) plug the power supply back in. Continue holding until the "Bose Lifestyle" message disappears. I presume this puts the system into a diagnostic mode, as the next steps in my case were to press and hold the "erase" button while scrolling through a menu of options using the "volume up" button. I believe it was the third "volume up" press that brought me to "FLASH" on the system screen. At that point I was told to release the "erase" button and press the enter button. The system rebooted and my VS-2 install went smoothly after that.
I'd recomend calling Bose support (800-905-2138) since your lockup occured during a CD load vs a software update (just to be on the safe side) - I was talking to a live tech support person in less than 15 seconds... a pleasant surprise.
Posted on Feb 05, 2008
SOURCE: Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Posted on Jan 15, 2009
taran_2005
  • 10515 Answers
SOURCE: bose lifestyle 48 says format unsupported for audio cds
Hi Johnxxlt,
According to Bose, the message that you have is due to dust in the system ....
They have offered 3 ways :-
Try cleaning the CD or DVD, as follows:
  • Use a soft, dry, lint-free cloth to remove stains or fingerprints from the disc surface
  • Wipe in straight movements from the center of the disc to the outside
  • Do not use any chemical cleaning products. They can damage the disc.
If the above will not fix the problem, you need to call them to repair the system.
I know its frustrating, However, we cannot play more with Bose as it might void the warranty if any.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Posted on Apr 17, 2009
Everytime I want to play an audio cd, it says format unsupported. This is happening very often. And I have also cleaned the cds,but still there is no difference. What is the solution?
Posted on Jan 12, 2011
Eject cd magazine
At downside of the music center, right corner, there is a "manual eject system" indicator. just push inside slide to upward with a thin screw driver and your magazine will be ejected..
Jul 03, 2013 | Bose Lifestyle 25 System
The laser is defective on my Bose Lifestyle 20 Musice System and Bose no longer repairs it because the laser for that model is no longer available. Doo you have any suggestions? Is there a Bose player...
Hi
do you know for sure that the laser is defective did a technican check it if yes and its defective i have parts for Bose
i will check and let you know maybe i have the part
let me know if you still want to fix the Bose
ecrdn@yahoo.com
Jack
Oct 21, 2010 | Bose Lifestyle 20 Shelf System
I have a BOSE Lifestyle 48 without sound
Not sure if this is the same problem, but I lost audio from the Stored, TV, Radio and my external speakers, but still had audio for the CD/DVD. I contacted Bose (Australia) support and they talked me through a solution that worked for me.
Remove the power cord from the Media centre, then while holding down the 'All Off' and 'Vol down' buttons on the Media Centre, reconnect the power (and continue to hold the buttons down). After 10 secs, release the buttons and turn the Media centre on. Everything worked fine for me after doing this.
Full marks to Bose for the phone support. I hope this helps someone else.
Jun 24, 2009 | Bose Lifestyle 48 System
No sound from speakers ( lifestyle 20 )
remove the screws that hold the amplifier block to the speaker.the fuses are in the amplifier inside
Jun 14, 2009 | Bose Lifestyle 20 System
Question
Hi, Underneath the unit you will see a small slot and "manual cd eject" embossed on the case , a jewelers screwdriver or darning needle or anything stiff and thin to pull down the wire lever inside the slot should do it.
Dec 28, 2008 | Audio Players & Recorders
Can't eject cd from cd changer
hi check and see if there is 12 volt to the cd changer or blown fuse.
Oct 26, 2008 | Bose Lifestyle 20 System
Bose Lifestyle CD not eject
There are some repair instructions available at www.AnyoneCanFixIt.com in the electronics section that will show you how to release the CD magazine and fix the problem where the unit will not play the CDs (you will hear a buzzing, buzzing, buzzing, and nothing will load or play).
Oct 11, 2008 | Bose Lifestyle 20 Shelf System
Bose Lifestyle 48 Series IV
hate to stae the obvious and painfull answer, but that nees to go back to the shop where if the sales guy cant get it sorted for you it could be a firmware crash and tus a warranty replacement, i know the manual is not that good in this specif area. and a non warranty reset may cost money, if warranty does not cover this specific area of adventure as it is possible they could blame the content of the media being corrupted in some way, could be ahrd one.
however you could try remoing the disk and resetting the system according to manual frist.
good luck ;-)
Dec 09, 2007 | BOSE48 - Lifestyle 48 Home Entertainment...
Bose Lifestyle 20 System Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
