Question about Breville SK500XL Stainless Steel Cordless Electric Kettle
There are rust-looking spots on the bottom of my kettle and the vinegar didn't amke a dent. What now?
How do i clean my glass kettle from lime scale
try vinegar neat white or brown its less corrosive than the branded descalers which do work quicker i admit but my kettle started to leak
because of these strong cleaners now i use vinegar its cheap.
place 500 ml to 1 litre in kettle switch on just warm vinegar and switch off leave in for 30 minutes swilling round empty and you can keep in a bottle and repeat every month if you wish or use in cleaning solution if you don't want to waste it look on internet 1,000 ways to use vinegar.
wash kettle with copious amounts of water inside and then use kettle cleaned and sparkling
Aug 06, 2014 | Kitchen Appliances - Others
Hi, i have a Bosch TDS2551GB steam generator iron. It needs descaling but I don't know how and there does not appear to be a descaling button. How do I proceed ?
Hi, Descaling is simply a process where the limestone that is deposited in any water cooking device is removed.
Have a look inside your electric kettle to see how much of a problem ypou have in your area.
If you have a serious problem & your kettle element is totally covered up with a whitish coating, I suggest you buy a can of commercial descaling agent.
If not, or iof you prefer home remedies, get a bottle of white vinegar.
Empty your kettle & pour a bit of vinegar onto the limestone. If it boils & foams, it is being dissolved. Replace the vinegar everytime it stops or slows down. Look at the results. You can speed it up by heating the kettle. Do not boil the kettle with vinegar. (Weak acid) Rather dilute it 50-50 I then boil. Or, just boi;l some water & throw it out. Then put the acid on. once you figuted out what process is suitable for getting rid of your areas's limestne, then applie your knowledge to your Bosh.
Just let the acid stand inside it overnight, or get more drastic if neccessary.
Sep 04, 2011 | Bosch Irons
How to clean my Braun electric kettle
Hi, follow the instruction below to clean it up...
Unplug the tea kettle from the wall outlet, and detach the plug from the kettle.
Pour 1/4 cup white vinegar into the kettle, and fill the kettle halfway with hot water.
Agitate the kettle so the vinegar mixture hits the sides of the kettle walls, and let the water sit for 20 minutes.
Discard the vinegar water, and scrub the interior of the kettle gently with a nylon sponge.
Rinse the kettle with hot water, and repeat as needed until all buildup is removed. Let the kettle air-dry before inserting the cord back into the kettle.
Apr 17, 2011 | Braun WK200 Cordless Electric Kettle
I just poured water from the electric kettle and discovered LOTS of lime deposits. Scrubbing didn't get all of it. What can I do to clear out the lime (I'm assuming that's what it is - looks like...
Fill it with vinegar and leave to soak overnight/for two nights if really bad.
Any parts which are impossible to fill with vinegar - lids/spouts, soak a cloth or tissue in vinegar and wrap/wedge into....and leave to soak overnight.
Dec 29, 2010 | Zojirushi CD-LCC50 Electric Kettle
Why does the metal in the bottom of the kettle turn green
Your water may have copper in it (or the heating element). When you boil the water you are left with the residue just like you are left with the lime scale. Vinegar should be able to remove both types of stains.
Jun 17, 2010 | Toastmaster (TMHP2) Electric Kettle
Dent in screen with black spot oin screen and
looks like u broke the colour crystals in ur ds screen. soz to say that dat cant b fixed.
Mar 05, 2010 | Nintendo DS Lite Console
HOW DO YOU REMOVE ALL OF THE BROWN RESIDUE FROM A BRAUN WK200 KETTLE?
There are comercial products that will do this look for it in houseware stores, maybe some big Ace Hardware stores, maybe even at your chain grocery stores.
Feb 26, 2009 | Braun WK200 Electronic Water Kettle...
Can kettle be cleaned and continue to be used.
I use a solution of vinegar and water (1:1) and boil it in the kettle, to remove mineral deposits from the metal heating surface (We do the same with the percolating coffee maker and run it through several times)... It seems to take any residual tastes out of the unit and possibly also cleans the plastic parts that it touches (I believe it does).
By the way... WHO thought it was a good idea to heat apple cider in an electric kettle. Sorry but WOW
Feb 24, 2009 | General (102105011) Electric Kettle
Rust coloured spots on insie of kettle
We buy DeBruce Polish at debruce polish.com, this stuff really works.
Mar 19, 2008 | Sunbeam 3211-2 Electric Kettle
Breville SK500XL Stainless Steel Cordless Electric Kettle Logo
187 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
