Question about Uniden Radio Communications
Trouble transmitting & receiving on uhf.
When transmitting & receiving on uhf, it is very hard to make out the conversation, however when receiving on the police scanner band the transmition comes through very clear.
Any help.
model UHO95SX.
  • Uniden Master
  • 1,654 Answers
While there might be a multitude of answers to this question. The first would be the radio is in need of repair, or not programmed correctly.
Posted on Jul 07, 2008
I have a Uniden UHF CB Handheld Model # UH076SX-NB. Have had it for 3 years and only used a dozen times. Now I can receive but unable to transmit. Any solutions please?
How do you know that the radio does not transmit? The batteries need to be fully charged, or new to transmit. The radio is old, and the cost to repair it may be close to how much a new CB radio is.
Good luck.
Aug 25, 2016 | Uniden Radio Communications
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Apr 09, 2015 | Televison & Video
Mt mag one bpr40 uhf 450/470 will receive but will not transmit. green light is on all the time
It probably has "busy channel inhibit" turned on in the menus, and the squelch is open, thus making it think there is a signal on the channel you're trying to use.
Sep 01, 2013 | Motorola Mag One Bpr40 Uhf 4w 8 Channel...
GME TX3340 not transmitting
You may have a bad microphone, not uncommon problem.
Apr 18, 2012 | Computers & Internet
My shure receiver is stuck on channel 3 and it doesn't let me pair it with my transmiter, why is it doing that?
I suggest calling Shure. They can assist you with troubleshooting. Call 847-600-8440. Make certain you have the wireless system with you so that they can walk you through some possible solutions.
Sep 20, 2010 | Shure PGX-4 UHF Diversity Wireless...
I can't get FOX on my converter box--what is the channel # for FOX?
It could be your antenna. Some retailers sold consumers UHF-only outdoor antennas and not VHF/UHF combo antennas. Other outdoor antennas may not have a power boost included for the VHF antennas (rabbit ears). The new DTV signals from stations are now broadcasting in lower power signals than before June 12.
Outdoor Antenna
KMSP/FOX 9 and KARE 11 both broadcast on VHF signals. WCCO and KSTP broadcast on UHF signals. You will need a VHF/UHF outdoor antenna to pick up KMSP and KARE 11 and also get all the other channels.
Indoor Antenna
Check your antenna to make sure it's a UHF/VHF antenna. You may need an indoor antenna that has rabbit ears -- that is the best way to get KMSP/FOX 9 reception on your TV. Your antenna should have a power boost to amplify the VHF signal if you are having trouble getting FOX 9 or KARE 11.
What Antenna Is Right For You?
Need help locating the proper outdoor antenna to receive your local television broadcast channels? Based on geographical maps and signal strengths, locates the best antenna for you, whether it's a home satellite system, high-definition television (HDTV) or a traditional analog set.
Make sure you antenna is pointed toward Shoreview, where FOX 9 transmits from.
CALL FOX 9 FOR HELP: 952-944-9999
Apr 07, 2010 | Televison & Video
Digital conversion
You are in good shape; the specs state that your model has an ATSC compatible tuner so you can receive either analog or digital.
BTW, if you are receiving via an antenna and have decent UHF reception (chan.s 15-69) you won't have to do anything. If you are on cable or satellite dish, they may charge extra for HD reception and a replacement cable box. Otherwise you'll just continue to have those black bars left and right.
Mar 21, 2009 | Protron PLTV-32 Television
Conversion boxes-Do I need one with an outside atenna?
you will need a converter box if you do not have a digital ready television. If you have a digital television, then no you do not need one. make sure of the type antenna you have, as there are uhf only and vhf only and combined uhf/vhf. if you only have a uhf only antenna you may be missing out on channels.
Jan 23, 2009 | Televison & Video
Shure wireless UHF microphone
Make sure the microphone and the receiver are still broadcasting/receiving on the same channel.
Check that all of the appropriate connections are right from the receiver to the mixing board are connected as well.
I hope this helps!
God Bless you!
Oct 17, 2008 | Dual Pro2- WM795V Channel VHF Wireless...
Salutations tobusy2,
With the pending conversion to digital broadcasting on 2/17/2009; BestBuy™ stores are selling units with digital tuners as well as analog tuners. Standard analog tuners should still receive UHF and VHF stations, that is until the conversion when most of theses stations will stop broadcasting in UHF as well as VHF.
I hope this helps.
Go Ahead. Use Us.
Jun 18, 2008 | Audio Players & Recorders
Radio Communications Logo
268 people viewed this question
Top Uniden Radio Communications Experts
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
