Question about Philips HD-5661
I have a Philips Quattro 5665 espresso maker/ It has worked fine for many years but now steam is escaping from lid of water compartment and steam wand will not produce foam. The force of the steam is weak. Are these pots repairable?
SOURCE: Philips HD-5661 How does Foam maker work?
I recently acquired the same model of espresso maker. I have found that you have to turn it on, and give the water time to heat up before attempting to use the steam function. If you turn on the steam knob too early, it will shoot out a stream of water, so you have to wait till the water is hot enough... probably 3 minutes or so. I'm assuming that you already know that you just place the steam spout into a mug of milk to both heat it up and create foam simultaneously. -Tim
Posted on Jan 02, 2008
SOURCE: Philips HD-7810 Espresso Machine - lid jam
Have just been saved by signing in & reading the 'solution'. Thank you. The vacuum did eventually release itself & hey-presto!
Posted on Oct 26, 2008
unclebuck521
SOURCE: water will not come through the steam wand
I had the same problem. I took the steam wand off, and checked for steam out of the unit. It was OK, so I stuck a thin wire up through the steam wand and dislodged what look like pieces of a green washer or O-ring.
In short...the wand was plugged.
Posted on Feb 03, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: can't get milk to foam
Place 1/3 part distilled white vinegar and 2/3 part water into the water reservoir. Turn the machine on and wait for the heat light to go off. Once the heat light goes off, turn the steam vs. water knob to the water drop icon, and turn the main function knob to steam/water. Make sure to have your frothing cup underneath the steam element ready to catch the water. The vinegar/water solution should clear out the calcium that clogs the steam element. Also, remove the cover to the steam element and dip it in a bowl with vinegar for about 5 minutes, and use something like a pipe cleaner to clean out that cover. Then apply vinegar and hot water to a rag and clean the calcium off the shaft of the steam element. Once you are all finished with this, run plain water through the espresso maker on the steam/water setting to clear out the bitter vinegar residue. Now, try again to make espresso and froth it.
Since milk contains calcium, the steam element has to be decalcified more often than a regular coffee maker. The EM-100 is a beautiful machine, but it is definitely high-maintenance - you will probably spend more time cleaning it than making cappuccino, etc.
-Tha Mp3 Doctor (is also a huge Cuisinart fan)
Posted on Feb 26, 2009
z34aga
  • 137 Answers
SOURCE: Water not coming through espresso side although steam wand works fine
you both can have same problem, solution is:
  1. low pressure of pump (or too fone grinded coffee)
  2. security valve of boiler openes to early and dont let the pump to rise pressure enough for good brewing( if it is this you can see water returning back to container if you have 2nd pipe in your machines reservoir)
Posted on Apr 02, 2009
Every few weeks, my 4-cup Starbucks Barista Quattro coffee maker overflows. It seems that the water either flows into the basket too rapidly or out of the basket too slowly. The basket overflows, and...
If your in a hard wayter area the basket overflow valve may be need cleaning. Fill with white vinegar and run a full cycle. Rinse by running 2 or 3 cycles with clean water. You may need to repeat the vinegar cycle if the problem persists.
Oct 16, 2010 | Starbucks Barista Quattro Coffee Maker
Steam escaping causing short in electronic display
You need to get this unit to a repairer asap as water will damage your control board.
Feb 10, 2010 | Gaggia Syncrony Compact Coffee...
After using steamer for milk frothing the red light comes on and cannot get esspresso to brew and no more steam or hot water comes out of the frothing nozzle, the water level is fine in reservior, beans in...
The tap valve is leaking inside the machine needs new seals.If moisture is escaped and hit the printed circuit card on the tap, the machine will stop you from doing other functions.
Feb 05, 2010 | Saeco Odea-Giro Espresso Machine
Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
May 23, 2009 | Gaggia Syncrony Compact Coffee...
General question about the Mr. Coffee Espresso ECM10
Greetings!
Put desired amount of water in resevoir (plus a little extra to be used to steam your milk for latte) and close up tightly.
Put espresso grind coffee in basket and tamp down with a tamper. If grounds are not packed, steam will seep through and will cause an erosion of sorts instead of just letting the steam hit the grounds.
Put the basket with handle group in recess rotating to the right as far as it will go.
Rotate the ON/OFF switch to the symbol for "Brew" until you get out the desired amount of espresso.
Then, take a caraf of milk and immerse it with the plastic black steam arm. Rotate switch to "STEAM" and froth milk. In the beginning, ensure that you have enough water for the espresso AND enough left to froth without having to shut off machine, refill with water, just to froth.
Be careful when you open the water resevoir cap after brewing because there is a vaccuum created and a burst of steam will shoot out the lid and may burn you.
The gasket above the grounds hopper eventually will deteriorate and more steam will escape than espresso is produced. There is no replacement parts for this machine since it was made in China according to a Mr. Coffee representative that I called this morning at 1-800-MR-COFFEE (800) 672-6333.
Good luck with your machine. Hope this helps! If you don't have a tamper for the grounds, I found one at Bed Bath and Beyond. It is stainless steel with 2 sizes. The smaller size works for this model.
Jan 17, 2009 | Coffee Makers & Espresso Machines
Water leaking from the base of the unit.
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Jul 17, 2008 | Cuisinart DGB-600 Coffee Maker
Sep 23, 2007 | Philips HD-5661
Philips HD-5661 Logo
349 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
Ross Keen
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
