Question about Microsoft Wireless Mobile Mouse 3000
Wireless mobile mouse 3000 not recognized anymore. ALL troubleshooting procedures completed. How do I get 'er done?
  • 61 Answers
Try to look for a small button on the receiver and the mouse. press the one on the receiver first then on the mouse :)
Posted on Dec 28, 2010
  • Teke Dec 28, 2010
    try looking for a small button on the receiver and the mouse. press the button on the receiver and then on the mouse :)
Microsoft mobile mouse 3000 device unknown on usb driver . Code 43 .was working lastnight . Now want work . Works on other computer
I suggest that you run the Windows 7 Hardware Troubleshooter on the computer and check to make sure that the mouse is ok.
1. Click Start.
2. Type in Troubleshooting in the Start Search.
3. Click on Hardware and Sound.
4. Click on Hardware Devices.
Now check if that fixes the issue or not.
If the issue still persists, then I suggest that you install the latest drivers manually from the link and install the same and check.
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Refer the link for more information: Troubleshoot a wireless mouse that does not function correctly: http://support.microsoft.com/kb/321122
Troubleshoot failure to find new mouse connected to your USB port: http://support.microsoft.com/kb/223256
I also suggest that you check if the batteries are full of charge.
Hope this response helps you out.
Best of luck!
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time
to provide me with a favorable rating. Thanks so much!
Jun 22, 2011 | Microsoft Wireless Mobile Mouse 3000
Wireless mouse 3000 is not connecting with computer
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 20, 2011 | Microsoft Wireless Mobile Mouse 3000
The mouse does not work
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Nov 10, 2010 | Microsoft Wireless Mobile Mouse 3000
Microsoft Wireless Mobile Mouse 3000 can't connect!!
well doae the mouse run on batteris if thas the case then you just new batteris
Feb 15, 2010 | Microsoft Wireless Mobile Mouse 3000
Computer does not recognize mouse
Take a normal wired mouse and then boot up into windows with it. After you get into windows then hook up the wireless mouse and see if its recognized. If not then make sure new batteries are installed in it.
If it still isn't recognized, go into the device manager and see if the wireless mouse is showing up in there. If you see if with a yellow question mark then that means you need to install the software for it.
If nothing shows up then that means the wireless mouse is bad and would need to be replaced.
Dec 17, 2009 | Microsoft Wireless Mobile Mouse 3000
How to connect micro soft wireless mobile mouse 3000?
You must have received drivers CD in the mouse package, you will need to install it.
Normally your system must recognize your mouse if you have connected its infrared device properly to your system.
Sep 11, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft mouse 3000 doesn't work
I email you idiots to fix a problem not to buy another product. Why should I buy a premium plan from you. With any luck it probably won't work either. Yes I did fix the problem. I threw the worthless mircosoft wireless mouse 3000 away. Problem solved
Aug 24, 2009 | Microsoft Wireless Mobile Mouse 3000
Microsoft Wireless Mobile Mouse 3000 shuts down my computer
This is the sign that mouse if faulty because if the laptop detects a threat from the USB ports, usually power related, to protect the parts, it turs off.
Advise to change the mouse...
Mar 11, 2009 | Microsoft Wireless Mobile Mouse 3000
I have a new microsoft wireless mobile mouse 3000 blue
you have to hit the connect button on the bottom of the usb then it will blink when its blinking hit the connect button on the bottom of the mouse
Feb 20, 2009 | Microsoft Wireless Mobile Mouse 3000
Microsoft Wireless Notebook Optical Mouse 3000 not working
Most devices last a long time. Have you tried re-installing the software for the keyboard & Mouse> Also go to microsoft download center and get the latest drivers for you setup. Make sure when you do, choose the right Operating System driver for your Keyboard & Mouse. Hope this helps. Bud
Dec 30, 2008 | Microsoft Wireless Optical Mouse
Microsoft  Wireless Mobile Mouse 3000  Logo
105 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
