Question about Kenmore 74602 Gas Dryer
Gas dryer runs but no heat. Wondering if an ignighter is to blame and how to check that
    President:
  • 1,194 Answers
When the dryer won't heat it is the thermostat/thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset.
Hope this will help....
Posted on Jan 01, 2011
Maytag Gas Dryer. Gas on. Ignighter kicks on. no heat aftrer running along time. Set idle and retried with no heat... Has ran fine for years... gas source has not been off for years... thanks
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101ooo
Aug 18, 2011 | Dryers
Wont heat checked thermo fuse and ignighter both ok
heatman101';
Jul 31, 2011 | Roper RGX4634KQ Gas Dryer
The dryer does not heat up when we turn it on, was wondering if their is a pilot light to ignight?
That must be a gas dryer. Check if you are getting 120 V to the burner assembly. If you do check the ignitor. It is grey and sits next to where the gas comes out. It needs to get red hot to ignite the gas
May 20, 2011 | Kenmore Dryers
Ge dryer after first cycle ignighter glows but burner will not light
heatman101
May 04, 2011 | General Electric Dryers
My problem is when i start my dryer it ignights and runs till it heats up and the the flame goes out till it cools off and then ignights and so on
Hi- Sound like the high temp. thermostat is tripping. You may try running it without the vent attached and see if it will run that way. I have had this happen when the vent is too obstructed and the heat cant get out fast enough. Otherwise have someone out to look at it. Hope that helps a little.
Sep 24, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My gas dryer whirlpool lgn2000jq2 starts ignights the gas and then goes out no heat
my lgn2000jq2 gas dryer starts up, but no heat. i checked the element, its good. checked for 120 volts at element plug, no power there.
May 09, 2010 | Whirlpool LER8648P Electric Dryer
Dryer wont heat up. It runs fine but no heat. Replaced the Thermal fuse"flat white with 2 wire terminals.
gas or electric ok gas replace gas coils check glow bar ignighter,check thermostates,,,,,,electric check power to both sides of wall outlet you need 220 volts and it will start and timer will advance on 110 vts second check second fuse looks like a thermostate normally located at top of heater coil call if you need to http://www.washerwizzards.com
Dec 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't heat up. Replaced ignighter, still
I would suspect faulty gas valve coils. These electrical coils are right above the gas valves and when energized these solenoids open the gas valves to permit gas flow to the burner. It's recommended that if any are suspected of being faulty that both (all) be replaced at the same time. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 11, 2009 | Kenmore Elite HE4 Electric Dryer
Whirlpool ultimate care gas dryer
the glow bar on the gas ignighter
Mar 15, 2008 | Dryers
Kenmore 74602 Gas Dryer Logo
49 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
