Question about Ariens 34 In. Zoom Series Riding Mower
I have a craftsman snowblower that runs and the auger will turn but seems that the wheels want to turn but dont. I took off the bottom plate and seen that the wheels are chain driven. When I press the hanmdle to engage the wheels the just **** a little bit. Any suggestiosn
    Novelist:
  • 171 Answers
The most common cause of this is the drive belt is worn. Sometimes the drive cable stretches (from the handle to the trans)
To check the belts and tension you remove the cover (usually plastic) in the middle of the snow thrower to look at the belts. Your operator's manual will show you how to remove the cover and check/change the belts.
If you don't have a copy you can get the manual through managemyhome.com You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side) The model number looks like 247.123456.
The belt closest to the engine drives the transmission. With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears. They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Posted on Jan 13, 2011
How do I fix my snowblower when the wheels won,t move ahead or back
Sounds like gear on axle shaft broke shear bolt or key. Take bottom plate off base of snowblower.It is ok to tip snowblown up on front end so wheels are in air. After plate is off turn wheels and see if drive gear is moving with axle. If not key way or bolt has broken off, replace and will be back in motion.
Feb 18, 2015 | Craftsman Snow Blower / Snowblower Bottom...
How to take auger out of snowblower
this is easy job look at it , it will show you how it is done , just look good at it you do not need anything to do this couple of hand tools
Feb 15, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Auger clutch cable breaks at hook
find out why it is binding at that point they should not break that easy , do not force it , that is what is happeing find out what the problem is
Feb 14, 2014 | Craftsman Snow Blower / Snowblower Bottom...
I have a 8/26 mastercraft snowblower Model No.
Have you checked all belts and belt tensioners? If so, you will have to tip unit up and take bottom plate off of unit. The drive system consists of a rubber lined wheel that makes contact with a friction plate once handle is depressed for drive. As you change gears you can see rubber drive wheel changes position in relation to friction disc to change speed. If belts are good, I would look in this area for problem. These rubber lined dive wheels do wear out and are replaceable. Also, on some models you can adjust further. Hope this helped. Happy wrenching!
Sep 09, 2013 | Garden
Auger in snowblower blower does not turn
Check to see if cable is still ok and not broken. Also adjusted.
Feb 10, 2013 | Craftsman Snow Blower / Snowblower Bottom...
My 9hp sears snowblower doesnt through snow anymore and the belts are fine. I have tried tightening the cable for the auger lever with no success. Is there a friction plate to change ??
Usually on the bottom of those there is a scraper plate on the bottom behind the auger this is made to wear out check to see if needs replacing.
Mar 09, 2011 | Craftsman Garden
Auger blades won't turn
You need what they call a "friction wheel" replaced.
Oct 31, 2009 | Garden
Ariens 34 In. Zoom Series Riding Mower Logo
354 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
