Question about Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725
Will not run after plugging in - Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725
I want microsoft office 2007 standard product key
Posted on Dec 28, 2010
Kegerator not cooling
which fan , inside or out.. if outside condensor fan is running then it has a bad 175 capacitor or if the compressor is running then it is low on refrigerant. if the cond fan is not running then check thermostat.. you can do this by connecting the two wires together.. another way to check the compressor, cond fan is to reach under and unplug the wires going to comptessor and plug into a 12ga extention cord.
Nov 17, 2013 | True Direct Draw Systems: Kegerator...
The fridge isn't getting cold. It has been close to 48 hours since I plugged it in.
You haven't said if you could hear the compressor running. If so then either the compressor is shot or there is a refrigerant leak. If it's not running it could be a bad cold control or the compressor starter. Oh and check to see that you have power at the receptacle that it's plugged into, I've been to calls of the refrigerator not working only to find out the it wasn't plugged in or the power was off at the receptacle.
Nov 02, 2013 | Midea HS-65LB Refrigerator
OLDER G&e UPRIGHT FREEZER PLUGGED IN RUNNING BUT
replace the ptc overload/relay on the compressor and it will cool again
Sep 11, 2011 | GE Freezers
Chest freezer power light on, run light off and all my food is defrosted. How do I fix it
Take off the service panel and check for the compressor running. Can you place your hand on
it or is it too hot. If it is you might change the relay to the compressor.Take your model no. to your local parts store and they will help you look at the part and exactly where it is located (on the compressor) Easy change out.
If the compressor is not running at all then remove the two wires to the thermostat and plug them
together (They will plug together if you turn one backwards and plug it into the other.)
Make sure you have unplugged the freezer while you are doing this.
Now you have routed around the thermostat.
If it runs then replace the thermostat and youre done!
If not after the relay and thermostat check it wont run then you have a bad compressor.
On the relay ask for a hard start relay for a freezer or ref. at the parts store. They know exactly
what it is. Its even easier to install. Don't be shy to repair this. You can do it or condemn it
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Magic Chef Freezers
Unit has been un-plugged for about a year, I plugged it in today it started right up and was cooling fine, it made a snap and the blower and compressor both quit running. The inside and door lights are...
Just in case, leave it plugged in for another 60 minutes, its quite possible it went into the defrost cycle, in which case no motors will run. If it continues to remain silent, re post your problem.
Sep 30, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Hi There, My freezer is less than 3 years old. (MQU1656BEW) It seems to be tripping the GFI plug in our garage. (It is not plugged into this plug, but is on the same circuit.) I have plugged it into an...
Refrigerators and freezers should not be run on a GFI outlet the it will weaken and start tripping.Most manufacturers now print this in the owners manual.
Aug 17, 2009 | Maytag 15.6 cu. ft. Upright Freezer...
Freezer Just Stop Working
You should not run your freezer from a strip plug, only from a wall outlet. It is OK for a small spark to occur since the freezer is trying to start the compressor as you plug it in. If there is a big spark that kicks out the circuit breaker if you plug it into a wall socket, then there is a short in the compressor or light circuit in the freezer. A strip plug in probably will not have the capacity to run the freezer. Plug it into the wall socket and try that. If you have a circuit breaker kick out, then it's your appliance. Hope this helps you, Rick
Apr 25, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer light on but not running
try tapping on the thermostat, it may be stuck open.
Nov 01, 2008 | Kenmore Freezers
Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725 Logo
43 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
