Question about Whirlpool Refrigerators
New Whirlpool refigerator Model ED2KVEXVL01. Need to find out if the freezer shelves can be relocated from the postion they are in to another set of mounting slots?
Sea Breeze
  • 4654 Answers
SOURCE: My refrigerator leaks from the inside on the top
This happens when the defrost drain is blocked. Here a two links that may help explain the problem. Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
Posted on Jul 25, 2009
  • 63 Answers
SOURCE: ice maker not working
Usually when this happens the water line in the freezer is frozen. If this is the case, defrosting the freezer should free it up and all will work again.
Posted on Aug 02, 2009
davidpsr
  • 222 Answers
SOURCE: Our Kenmore Refigerator was purchased July 1992.
As a start, try cleaning the coils and fan under the refrigerator.
You would not believe how many refrigerators and freezers I've worked on which required nothing but a good coil cleaning. The dirtier these coils get, the less efficient the unit becomes until it reaches a point that it almost appears as if the refrigerant unit is not working at all when all it really needs is a good cleaning.
While you're under there, be sure the fan is running to pull air over the coils to cool and condense the freon inside them.
Posted on Sep 12, 2009
aasc
  • 1606 Answers
SOURCE: OUR TOP MOUNT WHIRLPOOL FRIG IS DRIPPING WATER
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on Sep 26, 2009
Testimonial: "THANK YOU VERY MUCH. YOUR SOLUTION WAS SPOT ON. I USED ONE OF THOSE COPPER GROUNDING WIRES TO PUT IN THE DRAIN HOLE AND WRAPPED END AROUND BLACK TUBE."
Sea Breeze
  • 4654 Answers
SOURCE: whirlpool refrigerator model WRX42R, drain
Hope this collection of links here and my Websites will help you. Begin Here and this is the same. Thes are notall my credits but place and reproduced to help you solve the leaking refrigerator.
There will be no magic answer for where and why refrigerators leak water into the fresh section or just on the floor around freezer or fresh food door. I also cannot take all credit for solutions in the area of refrigerators leaking water. Every person contributes their own experience so those that have should also be rewarded for their own efforts. I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Posted on Aug 10, 2011
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
Hi I have a Whirlpool Refigerator and it drips water from the frezzer into the refigerator thru the two opening up in the back middle opening from the frezzer to the refigerator. It does this off and on
sounds like the drain live from freezer to outside is clogged. the water isnt making it you the condensate pan but coming out in the refrigerator. try finding and cleaning the drain line.
Mar 02, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a fisher & paykel n325t fridge. can not get the correct temperature. not cold enough.what should te dial be set at?
if your refrigerator had 7 postions you would set it to 4 check this for me though remove the rear panel in your freezer and assure that you dont have a ice build up on the inside this happens when you start getting a defrost problem also assure when you remove that rear panel that the fan is working the fan blows the cold air into the refigerator side also if youor refrigerator had 4 postions you would set it on 2 send me your model number and check out to see if your starting to get a defrost problem and well go from there thanks again
Rick
if you have an ice build up use a hair dryer to melt the ice this is a temporary fix until we can solve if it does have have a defrost problem or not
Dec 15, 2010 | Refrigerators
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Purchased a used 13.4 cubic freezer from caigslist yesterday. Upright type. Freezer is set on 7 to cold setting. Shelves are the type where the shelve itself cools the food. No fan in this model and it is...
It takes a while for this type of freezer to pull down in temp. because there is not evaporator fan for air movement. I would watch it for at least 12 hrs .
Nov 07, 2009 | Heating & Cooling
Ice forms in on the back panel in the freezer; freezer stays cold but frig not as cold; we defrosted it, took everything out of the freezer and relocated so as to keep items away from fan. Plugged it back...
Make sure that when you have removed the ice you also cleaned out the unit especially the freezer and the drains. Clogging due to dirt is sometimes the cause of coils to freeze up. I would advise to have the thermistor checked. I am unsure if your unit has auto defrosting capabilities, if it has you may want to have the circuit checked out.
Sep 06, 2009 | Whirlpool Refrigeration 14.4 Cu. Ft....
Three year old Whirlpool Refigerator (ED5FHEXNB), water leaks from bottom of refigerator when outdoor garden hose water is turned on. Only leaks when outdoor garden hose is turned on. Water filter, Brita...
Hello it sounds like you have a leaking water hose which you need to find. maybe check first where it connects into the back of the unit.. Otherwise the fridge has a blocked drain in the freezer. cheers
May 15, 2009 | Refrigerators
Refrigerators Logo
149 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
