Question about Proform 560hr Treadmill Walking Belt
I have a Discovery 560HR Treadmill. I get a SI3 error message. I pick up the back of the treadmill a few inches off the floor and put it back down and it works. I turn it off and get the SI 3 error message again but as soon as I pick up the back and set it down it works again. My back has been fused and my neck so I can't keep doing that to use the treadmill. Do you know what is wrong with it?
2 Suggested Answers
SOURCE: I have a Discovery 560HR
http://www.treadmilldoctor.com/SI3-Error-Code-kf
Posted on Jan 05, 2011
Power outage caused my treadmill belt to stop working
9 times out of 10, this will be a damaged 'lower control board' - Ben Bass Service Technician Since 2001 Phone 0403 969 946 / 1300 496 967 #GYMWORKS #HealthEquip #TreadmillBelts.com.au
Jan 02, 2014 | Proform 560hr Treadmill Walking Belt
Repco rp300tm
1) reset the treadmil.2) adjust the speed sensor, see the diagram attached. 3) Run the software calibration for easy diagnostic and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button 31d332da-cd1c-4885-8ae4-393941ca1930.gif
Oct 18, 2013 | Proform Perspective Es Treadmill PFTL99806
PLO5 error message on Quinton Clubtrack treadmill
Try to clear the error message. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 2
  • 3
Jan 25, 2013 | Quinton Stairmaster Clubtrack 3.0 GymTough...
Please can anyone help me I bought a 560hr treadmill today second hand it was workin perfectly, until my son and grandson went on it ..it now will turn on but the belt will not go it trips the power switch...
12_7_2011_9_56_59_pm.gifSee the block diagram that I did for you. Now you will see how many elements or component has the treadmills. If the fuse or breaker are trips. you must inspect and test: 1) Power cord some internal wires is touching insider and produce short-circuit. 2)Capacitor in short 3) Coil or transformer in short 4) Main Motor in short 5) Main Controller Board.
Finally see for any wire is loose and touch the chassis from the machine in that case produce a BIG SHORT. sincerely.
Good luck, G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Apr 03, 2011 | Proform 560hr Treadmill Walking Belt
T60 treadmill came up with lift motor error so switched off. Now when I switch on it displays autocalibrating but never gets any further. Can you help?
power off, put in the key, press and hold down the stop button and incline up buttons, power on holding down the buttons for a few seconds - message clears
Jun 18, 2010 | Tunturi T60 Folding Treadmill
Will not move belt
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
May 27, 2010 | Proform 560hr Treadmill Walking Belt
Please help..Need manual for 1993 Roadmaster treadmill.
Check Workout warehouse. Should be able to search them online.
Jun 03, 2009 | Proform 560hr Treadmill Walking Belt
Proform 560hr Treadmill Walking Belt Logo
111 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
