Question about Compaq Keyboard
What is the little rubber button in the middle of the keyboard called and how do you order more of them?
HOW DO I TAKE THE KEYBOARD APART
All the little screws on bottom, some may be hidden by a sticker or rubber pad, not much can go wrong, I take mine apart now and then to clean the buttons in the slink.
Feb 10, 2016 | Logitech S520 Desktop Wireless Multimedia...
Tip
How to repair Hinges on a HP ZV6000
<p>If a loose screen hinge screws <br /> <p>1. Turn off your computer and remove all components of the computer that sending an electrical current to the system, including power cables, peripherals and battery. <br /> <p><br /> <p>2. Close the display and turn off the computer base to cope with the hinge side of the computer to you. <br /> <p><br /> <p>3. Extract the four screws on the bottom border. <br /> <p><br /> <p>4. Remove the rubber plugs on the back of the hinges of the screen and the two screws underneath them. <br /> <p><br /> <p>5. Turn off the computer and open the screen, so they sit flat against your work. <br /> <p><br /> <p>6. Press the area marked on the right side of the keyboard cover (the plastic strip on the top of the keyboard) to it from the computer. Lift your right a little push and cover the central part of the keyboard to release it. Lift up the middle and let the left up to the keyboard cover for free from the computer. <br /> <p><br /> <p>7. Unzip, the four screws on the top of the keyboard and the keyboard on the fold of the palm rest with the buttons down. Disconnect the keyboard cable and remove the keyboard. <br /> <p><br /> <p>8. Loosen the two screws that secure each display hinge to the computer. <br /> <p><br /> <p>9. Attach the keyboard and the keyboard. Make sure all screws that secure each part to fix. <br /> <p><br /> <p>10. Place the screws on the back of the hinges of the screen and replace the rubber stopper. <br /> <p><br /> <p>11. Insert the battery, cables and components that you removed in step 1 to complete the process. <br /> <p><br /> <p>Broken so replace hinges <br /> <p>1. Turn off the computer and get rid of its power transmission components. <br /> <p><br /> <p>2. Turn off your computer and remove the four screws on the hinge side of the base of the keyboard. <br /> <p><br /> <p>3. Remove the rubber plugs on the back of each screen hinge, and pull the two screws in the hinges. <br /> <p><br /> <p>4. Unplug the computer and open the screen. Follow the instructions to step 6 of chapter 1 to the keyboard cover. <br /> <p><br /> <p>5. Remove the keyboard by following step 7 of Section 1 <br /> <p><br /> <p>6. Disconnect the cable from the connector on the computer screen right in the middle of the screen panel. <br /> <p><br /> <p>7. Disconnect and remove the two antenna cables from the mini-PCI wireless card in the middle left of the keyboard and cables in the guide, take it to the computer. <br /> <p><br /> <p>8. Unzip the two screws on each hinge and lift the computer screen. <br /> <p><br /> <p>9. Remove the six rubber pads on the front panel display, and remove the screws under them. <br /> <p><br /> <p>10. Remove the display. <br /> <p><br /> <p>11. Unzip the two screws on each screen, internal hinges and remove the hinges of the screen. <br /> <p><br /> <p>12. Follow the procedure in reverse, with hinges to the new computer installation. Make sure you remove all the screws, so everything is nice and tight as the computer is assembled. <br />
on Jun 22, 2011 | Computers & Internet
Sound stuttering
Hi, This and a lot of similar keyboards have gold flashed pads on the PCB and the keys press one or two rubber caps, with conductive pads in them, down.
Clean the pads with isopropanol, (and nothing else) and it will be cured 99% of the time. If a few notes do not work, especially after heavy use, then the rubber caps can be replaced.
Taking the keyboard apart is long winded because of the number of screws involved.
The job its self is simple enough, but take note of the order things go in and where the screws go.
Hope this helps, Chris.
Jan 09, 2014 | Casio Music
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
My keys are either not ttttttttttttttyping at aall or do like the t above. More pressure on keys helps.
I assume you have windows.
open start menu
all programs
accessories
ease of access (also called accessibility on xp)
select on-screen keyboard
its a bit slow but it will get you by until you can fix the problem or get a new keyboard. below are three possible alternative solutions:
1. If it is a wireless keyboard then try to change the channel its a little button on the bottom of the keyboard.
2. If its a wireless keyboard change the batteries.
3. If the above two solutions do not help then either carefully take apart the keyboard and clean everything (if you suspect something was spilled on the keyboard) or if its just an old keyboard then the contacts need cleaning they look like little round rubber dots on the bottom of the keys mashing little grid like symbols on the clear plastic sheets. I usually clean the clear plastic symbol parts with a rubber pencil eraser very gently and the black dots below the keys i clean with just a paper towel. I don't use cleaning solutions and try and keep it all dry. remember less scrubbing is more. Look at the unused keys like z to see how they are supposed to look. and good luck. but its easier just to buy a new one.
Aug 24, 2010 | Logitech Computers & Internet
Casio PX-120 Dead Key
Your on the right track. Check for grease on the contact. Clean the circuit board surface with alcohol and a q-tip and also the rubber/metalized switch.Wipe clean with other end of q-tip. Try the key again.
Aug 13, 2009 | Casio Portable Keyboard Touch Sensitive...
Key button got pluged off
You probably broke a little tab that connects the letter to the actual button.
Just get some of that thick (foam) double sided tape. regular double sided tape wont work.
good luck
May 20, 2009 | Acer NSK8458AN Keyboard
Onmydelllaptop,thespacebarwillnotspacenormove
The rubber plug below the spacebar button is faulty.The button needs to be removed gently and the rubber plug below it which touches the board below should be cleaned.If this does not solve the issue the rubber plug below the button needs to be replaced.Its a common problem.
thanks and please do not forget to rate the solution.keep updated.
May 19, 2009 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
About three of my number keys do no work. .you think this will require a new keyboard
there are little rubber buttons under your keys that wear down over time. that sounds like what has happend you should replace your keyboard.
Feb 27, 2009 | Gateway Solo 1400 (7003934) Keyboard
Emachine laptop Fn key locked
I think the only solution is to phisically remove the key from the keyboard - VERY gently, in order not to break or send flying the pieces to which the key is attached. The little rubber button underneath might be squished below those pieces.
Oct 27, 2008 | E-Machines eMachines Desktop PC
Compaq Keyboard Logo
263 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
