Question about Black & Decker Saws
Skill saw, worm drive #7395, 13 amp. sounds like a bearing out on inside, growls and wobbles. Where can I get it fixed in the Sun City Az. area?????
    Scholar:
  • 127 Answers
Here is the link for B&D service centers. Just enter your zip code and it will give you the neareest service center location
http://www.blackanddecker.com/Service-centers.aspx
Posted on Dec 28, 2010
CitiBank location near Sun City, Az
The following web page will allow you to find all the Citi locations across the US.
https://online.citi.com/US/GCL/citilocator/flow.action
Hope that helps!
Jul 11, 2016 | citibank.com
Saw is making noise like the bearings is going when I let of the trigger of the saw, how can I fix this peoblem
Best choice Lubrication of armature gear > ( renolit paragon ep 2 or amblygon ta15) if bearings are have to much looseness replace them. armature/geardrive can very fast become worn if too long was used without timely the use of some lubrication.
May 24, 2016 | Skil Shd77m 15 Amp 7-1/4-inch Mag Worm...
Growling sound wobbling
Sounds like a wheel bearing. Very bad if its wobbling. Take it to a mech. Possible its a bad tire snake / slipped belt. Look for warped lumpy tire.
May 11, 2011 | Oldsmobile Alero Cars & Trucks
When i use my worm drive Skill saw sparkes shoot out of the rear vents?
Check the brush spring tension. If the brushes become bound in their slides due to carbon/dirt/sawdust, the brushes will tend to arc and when they do, they create extra heat which tends to collapse the springs. Pull each brush out noting the wear pattern on the end so that it returns with the same orientation, clean the slide out with a small round brush so that the brush moves smoothly, check the spring (it will be bright brass if ok, but discolored if overheated), then replace the brush. Do the other one similarly. This usually fixes this problem, but will reoccur over time. Hope this helps!
May 10, 2010 | Saws
Blade hit the ground and bent. Now getting a growling sound from blade bearing housings and mower stalls after five minutes or so.I did replace the blades...
I have a feeling that the bearings were damaged when they hit. The new blades are ok, but the bearings are growling and I don't know what is causing the engine to shut off. I would pull the deck off, check out the bearings, replace them if needed, just wobble the blade back and forth, it shouldn't move, should be tight, Take off the belt and spin the blade by hand, and see if it growls. It could be the drive pulley bearings that went, check them out too. hope this helps.
Apr 27, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Strange wobble noise
your bearings. thats what it sounds like to me. if it almost sounds like you have a big rock just jumbling around in your tire thats most likely your bearings. its pricey but its worth it to get it fixed. if thats not it check into your transfer case and your shocks
Feb 23, 2010 | 2000 Chevrolet Blazer
Blade stops going once it hits the metal to be cut.
inside the motor/arbor section of the saw, there is a helical gear and worm drive on the motor. the front of the motor is supported by a bearing in the aluminum arbor section. sounds like most of the bearing balls are disintegrated and the worm disengages when a load is put on it but spins when there is no load. I would check and replace the front bearing.
Oct 24, 2009 | Ryobi Saws
My rigded worm drive saw vibrates alot when cutting any answers what part is bad.
sounds like a bearing has gone bad , does the blade wobble any~then bad bearing there, if not then you need to check the worm drive gears and bearings
Apr 25, 2009 | Saws
2001 intrepid cv joint removal and replacement
bearings make growling noises and axles cv joints make a flutter vibration when accelerating or decelerating
Oct 07, 2008 | 2001 Dodge Intrepid
Saws Logo
190 people viewed this question
Top Black & Decker Saws Experts
Jason
Mike Carew
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
