Question about Microsoft Xbox 360 Console
Our xbox won't connect to xbox live even though we have wireless internet. so we can't go on xbox live. Why is this
  • 61 Answers
Maybe your account has expired :)
Posted on Dec 28, 2010
Hi, i cant connect to my wireless internet connection on my xbox 360 super slim, i have xbox live gold though, how can i connect? it gives the same warning over and over again. I'm sure i have the right...
Depending on your router, it may or may not have a MAC Filter, which will prevent you from connecting your Xbox to the internet even though the Network Password is correct. If you have access to your router, add your Xbox MAC ID to your router's MAC Filter and then restart your router.
Oct 02, 2013 | Microsoft Xbox 360 Console
Tip
How to set up WiFi on XBOX
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
Save your settings and verify the network is functional.
On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
On the Xbox 360, use the "Test Xbox Live Connection" option instead. Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
on Feb 07, 2010 | Video Game Consoles & Games
How do u connect an an xbox 360 to xbox live
You need either a blue Ethernet cable to connect the Xbox to an internet outlet or a wireless router. If you use the wireless router, hook it up to your computer so it broadcasts a signal, then, depending on what Xbox you have, if its the new 360 slim you won't need a wireless adapter, you search for the signal, then connect it. If you don't have the 360 slim, then you need to buy a wireless adapter and it plugs into the back of the Xbox.
Aug 24, 2011 | Microsoft Xbox 360 Console
It says it cant connect to xbox live even though i have a ethernet cable hooked up to my lab top running to the back of my xbox 360.
Depending upon your Internet setup connecting your XBox cannot give you Internet access to XBox Live.
For a least complicated method, you need to connect the XBox to a DSL or cable modem that has Internet connection via your Internet Service Provider.
How is your laptop connected to the Internet?
This information would assist me to help you.
Jan 25, 2011 | Office Equipment & Supplies
How to hookup wireless internet
My son's new Xbox Live cannot / will not connect with our wireless router, even though it recognizes it. I have a Belkin 802.11b
1) Get connected to belkin's wireless network or wired network
2) Once you get connected, it may not be able to go online on XBox Live
3) Go to any computer that is going online with the router
4) Type in 192.168.2.1 in the address bar of your Internet explorer
5) This will open up router interface(here we have to do some settings)
6) In the left hand side column, click on FIREWALL.
7) Leave the password blank in login page and disable the FIREWALL. Click on Apply Changes.
8) Under FIREWALL(in the left hand side column), click on DMZ
9) Make a "check" on enable and under Private IP: 192.168.2.25. Click on Apply Changes.
10) Now go to Xbox, under network settings, choose IP settings, and select manual configuration
IP: 192.168.2.25
Subnet: 255.255.255.0
Router: 192.168.2.1
11) Now select manual configuration for DNS settings.
Primary DNS: 4.2.2.2
Secondary DNS: 4.2.2.1
12) Restart both Belkin and Xbox
13) It should connect to XBox Live now...
Jan 17, 2010 | Belkin (F5D8231-4) Wireless Router...
Cant get xbox live connected
You have to make sure that your xbox knows your ip address and if your using wireless, your wep key. Your wep key should be on the back of your wireless router and you can make your xbox recieve your ip address automatically by editing the settings. you can edit settings by testing your connection. If your xbox does does not have your ip address, next to ip address it will say failed and next to that it says edit settings.
Nov 28, 2008 | Microsoft Xbox 360 Console
I am trying to set up xbox live for my son but when i try to go live on the xbox dashboard it says that wireless network not connected but i have a wireless network running in my house and need to know how...
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
What You Need:
  • Active Xbox Live subscription (to access services)
Source: About.com
Sep 29, 2008 | Computers & Internet
Problem with streaming from my laptop to my xbox 360 wirelessly
Call microsoft for a solution, they will most likely know in a few minutes. Even though you get punjab from india.
Mar 02, 2008 | Microsoft Wireless Network Adapter Xbox...
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
