Question about DekCell EasyCap USB 20 Video Capture Adapter with Video Editor Software (CPA1280) Video Capture
Hi, I have bought the Easy CAP USB 2.0 with aim to recorder my old Hi 8 mm and audio MP. But the system does not recognized the USB key. Even after running everything as recommended and mentioned the system cannot still recognize the key USB. I din´ t find no way how to resolve this problem. The included CD/ rom doesn´t help anymore. Can somebody help? Where can I get the Driver for running the system. By the way, I am using the Microsoft 2003 and WindXP. Thanks for helping. Simon
    Guru:
  • 124 Answers
I believe we have the same video capture adapter. If you need the driver please go check this link:
http://www.cdrking.com/index.php?mod=products&type=view&sid=498&main=75
I've used this without any problem. Hope the driver helps.
Posted on Dec 28, 2010
Hi, I have mp3 player teac mp 114 with 4 gb. It is stuck on TEAC logo when I turn it on and it doesn't get recognized when connected to PC
Pull up the memory card and try to connect it without your memory card if that works tried different memory card
Jan 12, 2018 | Teac Audio Players & Recorders
How do you extract audio from Maxell Hi8 tape?
easy: locate a local audio/video transfer place or videography studio that you can hand these off to. Request mp3 format on CD as the mode of delivery. Usually they have the equipment needed and it isn't very expensive. Some will even clean up the sound for you.
Slightly more difficult: locate a hi-8 player, buy a $30 conversion cable that goes from the hi-8 camera or hi-8 deck to your computer (type of cable will depend on the type of camera you get and type of computer you have), download video editing software and capture the tapes. Once the files are in the computer you can export as mp3 and burn a disc.
Apr 04, 2013 | Electronics - Others
Windows 8 easycap drivers 64 bit
Check out this driver for the Easy Cap USB Video Adapter for Windows 7/8 x86/x64source: http://fbappointments.com/index.php/consumer-products/computers/windows
Jan 06, 2013 | Universal EasyCAP USB 2.0 Audio/Video...
Can you give me technical specs for LCD TV TH-L32E3A. Thanks
The proof copy of the Owner's manual includes the specs for the TH-L32EA and is available from: http://www.panasonic.com.au/Support/Customer+support/Downloads+and+documentation . Enter the model number under keywords and then click search (do not use the drop down menus).
Specifications
Power
Power rating AC 220 - 240 V, 50 / 60 Hz 0.33 A
Normal (Home) mode 42 W
Standby condition 0.2 W
Display
panel
Aspect Ratio 16:9
Visible screen size 80 cm (diagonal)
698 mm (W) × 393 mm (H)
Number of pixels 2,073,600 (1,920 (W) × 1,080 (H))
Sound
Speaker 160 mm × 42 mm × 2, 8 Ohms
Audio Output 20 W (10 W + 10 W )
Headphones M3 (3.5 mm) stereo mini Jack × 1
PC signals
VGA, SVGA, WVGA, XGA
SXGA, WXGA ······ (compressed)
Horizontal scanning frequency 31 - 69 kHz
Vertical scanning frequency 59 - 86 Hz
Receiving Systems /
Band name
PAL B/G Reception of Off air broadcasts
Digital TV 7 MHz VHF / UHF (Australia) free-to-air TV broadcast reception
PAL 60 Hz
M.NTSC
NTSC
Playback of NTSC tape from some PAL Video recorders (VCR)
Playback from M. NTSC Video recorders (VCR)
Playback from NTSC Video recorders (VCR)
Aerial - Rear Standard Belling & Lee connector
Operating Conditions Temperature : 0 °C - 35 °C
Humidity : 20 % - 80 % RH (non-condensing)
Connection Terminals
AV1
Input
AUDIO L - R RCA PIN Type × 2 0.5 V[rms]
VIDEO RCA PIN Type × 1 1.0 V[p-p] (75 Ohms)
COMPONENT Y 1.0 V[p-p] (including synchronisation)
PB/CB, PR/CR ±0.35 V[p-p]
AV2
Input
AV3
Input
Audio
Output AUDIO L - R RCA PIN Type × 2 0.5 V[rms] (high impedance)
Others
HDMI1 - 3
Input TYPE A Connectors • This TV supports "HDAVI control 5" function.
PC Input HIGH-DENSITY D-SUB 15PIN R / G / B: 0.7 V[p-p] (75 Ohms)
HD / VD: TTL Level 2.0 - 5.0 V[p-p] (high impedance)
DIGITAL
AUDIO OUT PCM / Dolby Digital, Fiber optic
Card slot SD Card slot × 1
USB 1/2 USB 2.0 TYPE A Connectors DC 5 V, Max. 500 mA
ETHERNET 10BASE-T / 100BASE-TX
Dimensions (W × H × D) 769 mm × 514 mm × 207 mm (With Pedestal)
769 mm × 480 mm × 75 mm (TV only)
Mass 11.0 k Net (With Pedestal)
9.5 k Net (TV only)
(See page 73 of the manual for the specs as a table - I used Proof 2)
I hope this helps.
Apr 20, 2011 | Panasonic Kitchen Appliances - Others
Nokia 5130
General 2G Network GSM 850 / 900 / 1800 / 1900 Announced 2008, November Status Available. Released 2009, February Size Dimensions 107.5 x 46.7 x 14.8 mm, 65 cc Weight 88 g Display Type 256K colors Size 240 x 320 pixels, 2.0 inches Sound Alert types Vibration, MP3 ringtones Speakerphone Yes - 3.5 mm audio jack
- Dedicated music keys Memory Phonebook 2000 entries, Photocall Call records Yes Internal 30 MB Card slot microSD, up to 16GB (verified), 1GB included, Data GPRS Class 32 EDGE Class 32 3G No WLAN No Bluetooth Yes, v2.0 with A2DP Infrared port No USB Yes, v2.0 microUSB Camera Primary 2 MP, 1600x1200 pixels Video Yes, QCIF@15fps Secondary No Features Messaging SMS, MMS, Email Browser WAP 2.0/xHTML, HTML Radio Stereo FM radio with RDS Games Yes + downloadable Colors Red, Blue, White Aqua (T-Mobile exclusive) GPS No Java Yes, MIDP 2.1 - MP4/H.263/H.264 player
- MP3/WMA/eAAC+ player
- Organizer
- Flash Lite 3.0
- Voice memo
- T9 Battery Standard battery, Li-Ion 1020 mAh (BL-5C) Stand-by Up to 288 h Talk time Up to 6 h Music play Up to 21 h
Feb 05, 2010 | Nokia 5130 Cellular Phone
Alesis Multimix 8 USB won't be recognized
There are NO drivers to be installed for this device. Plug in the usb to the device, and the PC once the PC is running turn on the mixer. XP should inform you that a USB Audio Device has been found & installed. Any software you use for rec'ing will let you choose what sound device to use, select USB Audio Codec.
May 27, 2009 | Alesis Multimix 8 USB 8-Channel Mixer...
Boss br-8 digital recorder wont load up. powers up but no program
More than likely you experienced a short within the unit. Sounds like it might be a power surge, if nothing is function but you have power.
Unfortunately, this is not an easy fix, and I would suggest taking it to a service center for repair.
- OPTiC
DJ & Pro Audio Electronic Repairs
A DJ PRO AUDIO Co.
Dec 18, 2008 | Roland Vs2400CD Digital Workstation W/CD...
ION Audio VCR 2 PC USB VHS Video to Computer Converter it record
hi, friend, the aHisoft Video Converter is just prepared for you, It is a Total Video Converter that can convert video to MP4/MKV/WMV/AVI and other popular formats such as: AVC, FLV, MP-1, MP-2, 3GP, 3GPP, Mov, M4V, ASF, SWF, VOB, DV, Super VCD, VCD, DVD and HD video.
so i think it will be helpful, you can search it on google
or visit http://www.asharer.com/
Have a nice day, my friend!
Dec 15, 2008 | ION Audio VCR 2 PC USB VHS Video to...
I cannot access the turntable thru my USB hub.
I received an updated driver from Numark but that still did not solve my problem. It turned out to be some sort of incompatability with my USB 2 card. When I plugged the turntable into my old USB 1 slot, my computer recognized it immediately. The new Audacity and MixMeister programs that were sent as a fix from Numark are just burning programs and not drivers for the device. I can now convert my old vinyl with ease.
Mar 10, 2008 | Numark ttUSB Turntable
DekCell EasyCap USB 20 Video Capture Adapter with Video Editor Software (CPA1280) Video Capture Logo
656 people viewed this question
Top DekCell Televison & Video Experts
Robin Hill
Robin Hill
ka4iup
ka4iup
john smith
Are you a DekCell Televison and Video Expert? Answer questions, earn points and help others
