Question about Fender 2232200000 Blues Deluxe Reissue Guitar Amp
Unable to activate reverb and drive channel with either cabinet switches or footswitch. Brand new out of the box so it must be something I am doing.
  • Fender Master
  • 5,603 Answers
Make sure you have the CORRECT foot switch pedal. Try unplugging the pedal and then try the cabinet switches to see if they work. The pedal for this one has a different circuit than some. I have the schematic and we can do further testing.
Posted on Dec 29, 2010
How do you use a four way footswitch
Need more info. What kind of foot switch and what are you hooking it up to. For guitar they are used for switching distortion to clean on 1 switch, one for reverb, one for chorus, and possibly 1 for bypass. All depending on the amp you use, and what effect the amp has built in it. Some amps only have clean and destortion which make the other channels on the footswitch useless. Hope this helps.
Dec 31, 2014 | Music
No reverb on my fender ps 160 Vocal amplifier
Here is a link to the schematic drawing
http://www.prowessamplifiers.com/schematics/fender/ps160.pdf
items to check are
1-the footswitch and plug
2-the reverb unit ,usually found at the bottom of the box
3-the reverb unit is plugged in to the amp
4-V6 a 7025 valve
5- the reverb switch is in the on position
Hope this helps
Len
Oct 14, 2014 | Music
Just got a new Marshall DSL40C. The reverb does not work on either gain control or with the footswitch. Why?
Nothing wrong with the amp. Google it- these amps have extremely weak reverb. All of them are the same. It's the one weak point about these amps. And I love mine. I mic it when we gig. Sounds awesome both clean and driven. But you'll have to get a separate reverb pedal if you want "girl crush" or "pipeline" reverb. Don't listen to the above posters. It's the way these amps are.
Nov 30, 2013 | Marshall Music
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
I have a Marshall mg100hdfx Head & Cab - The clean channel is on but when i hit the footswitch it is not changing to overdrive channel - please help
Sounds like either your "front-panel" switches are not set for channel switching or the footswitch's mechanical "Channel" switch is defective. According to the OM the "Channel Select Switch" on the front becomes inactive with the footswitch plugged in.
If disconnecting the footswitch causes this front-panel switch to operate properly then it has to be your mechanical switch in the footswitch. Repair of these footswitches are pretty simple provided you find a replacement and have soldering abilities.
Oct 25, 2012 | Music
Can I use a footswitch for the reverb, to allow me to switch it off when talking ON MY Behringer Xenyx 1202 FX
Sorry, the Xenyx1202FX does not have a footswitch input. I would suggest if this function is needed to use an external FX unit which has a footswitch input.
Apr 26, 2011 | Behringer Xenyx 1202 12-input 2-bus Mixer...
I've told my Frontman 65r has a real reverb tank (accutronics). But it's almost imperceptible, even with the reverb knob at 10. Is that normal? Also, mid scoop for the drive channel and treble/bass for the...
The reverb should be quite strong. I would first look at the reverb volume pot R42 which is a 50K pot. I would also check the voltages on the test points near U4 (TLO-72 op amp tp13 and tp14) which amplifies the signal coming out of the box. It is possible the box has low power levels as well.
The problem is going to be around that section of the board if it isn't a dirty or dead(ish) pot.
The reverb should be noticeable enough to be annoying ;-]
Mar 18, 2011 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Fender Hor Rod deville footswitch
If the footswitch is not switching correctly, open it up and check for any shorts or a defective switch. Sounds like it's a problem with the switch.
Aug 14, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Fender 2232200000 Blues Deluxe Reissue Guitar Amp Logo
97 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
