Question about Canon PIXMA iP1800 InkJet Printer
Ink cartridge installed wrong
I had to change both ink cartridges, I keep getting warning flag, ink cartridge installed wrong, I've from the 30/31 to the 40/41 and back to the30/31. Same problem, I download manufacture driver twice.
  • Anonymous Mar 12, 2014
    it says that i have the wrong ink cartridge installed
Brought another printer.
Posted on Jul 07, 2008
HP psc 2210 all-in-one printer
hold down the "Setup" button while pressing the "Options" button and the message will go away
Jun 26, 2008 | HP PSC 2210 All-In-One InkJet Printer
Keeps saying install c
When the printer says "install C" it is referring to the Cyan (blue) ink cartridge. If this is not a new cartridge, you might have to replace it. If this is a new cartridge, try following these steps.
1. Unplug the power cable.
2. Remove all 4 ink cartridges.
3. Close the ink cover
4. Plug the power back in.
5. Wait for the machine to warm up and tell you that the ink is empty.
6. Reinsert all 4 ink cartridges.
If you keep getting the same message you should try another cartridge. You can put the yellow cartridge in the blue spot to see if you get the same message. If you get the same message then the machine is broken. If you get a new message then the cyan cartridge needs to be changed.
Thanks,
Pat
Nov 09, 2010 | Brother DCP 130C All-In-One InkJet Printer
My dell 924 printer shows right cartridge incorrect and I just had both cartridges refilled what is wrong?
I purchased remanufactured ink cartridges through amazon.com. I got 4 for the price of 1 through Dell. After installing the first cartridge, it printed for a few days and then I got the same message "left cartridge incorrect". Unfortunately, I did not read the piece of paper that came with my cartridge that says "STOP" read this before you install the cartridge.
I had to throw out the cartridge that I had just installed and put in a new one and follow these steps:
1. If you recieve a pop-up message indicating that the cartridge has been depleted or a low ink level warning, please disregard.
2. Check "Don't display this dialog again" and click "ok" or "continue printing" if necessary.
3. In the printer status window, since you have already ordered ink, do not click the "order ink online" button. If you have the option, check "I have ordered my ink, please don't remind me again." If not, close the window and continue printing.
I'm not sure why, but these instructions were vital to getting my remanufactured cartridges to work.
I am posting this reply to hopefully help out the next person that has this problem. Unfortunately, I lost a perfectly good ink cartridge because I failed to read the instructions the first time. But the next one worked just fine when I followed the instructions. Good luck!
Mar 09, 2010 | Dell 924 All-in-One InkJet Printer
Office jet 5510 keeps saying wrong black cartridge.
Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
Jan 30, 2010 | Office Equipment & Supplies
It keeps giving the alert wrong cartridge and wont print.I installed for the 1st time ink power cartridge instead of canon's and it won't do nothing........... these cartridge are half price but look...
Wrong cartridge refers to the printhead and not the inks. This machine, when the printhead goes bad gives that error. A new printhead is around $60.00 for that machine. QY6-0064-000.
Nov 04, 2009 | Canon SmartBase MP730 All-In-One InkJet...
Check cartridge
Lets try this first:
01. Verify that the unit is switched on.
02. Remove the power cable from the back of the machine.
03. Wait for 1 Minute.
04. Press and hold the POWER button on the front panel.
05. Reinsert the power cable in the backside of the unit.
06. Print a test page. If the problem persists, replace the cartridge.
What causes these symptoms?
These printers have a cartridge check feature. If it detects cartridge contact problems such as dirt, dust or oil on a contact, it will give warnings so the user can correct them by properly seating the cartridge and / or cleaning the contacts.
When a problem is detected, a software 'flag" is set within the printer that should be reset when the user corrects the contact problem.
Due to a firmware error, the 'flag' does not reset until the power is cycled to the printer and repeated warnings are delivered. Power cycling resets the 'flag' and eliminates the warnings.
HP has for years now stated the problem was corrected.
All the BEST
Jul 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
Epson Stylus photo 2100
Highly possible that the "compatable" cartridges are not really compatable or that Epson has updated software or firmware to keep them from working. Try replacing with Epson cartridges or see if the non-OEM brand seller has a resetting device so the printer sees those cartridges as full.
Dec 06, 2007 | Epson Stylus Photo 2100 InkJet Printer
No cartridge found error
One or more ink carts aredodgy, fit gen new brother inks (x4)
On inks carts there is a flag inside them that normally floats, when it sits down due to ink level being low it blocks a photocell to stop machine from working, it needs to do this to stop any air getting in ink lines, so inks may appear to have ink in them but will not work, on some refill/aftermarket carts flag gets stuck
Oct 27, 2007 | Brother MFC-3240C All-In-One InkJet...
Canon PIXMA iP1800 InkJet Printer Logo
98 people viewed this question
old marine
old marine
