Question about Cameras
Lumix DMC-FC7, the flash does not work. - Cameras
  • h56b456 Aug 11, 2008
    i had same problem.
    Scholar:
  • 83 Answers
Do you mean FX7? I understand that you've tried all usual tricks like resetting the camera to factory settings, setting the flash to "forced on" etc.
If so, then there's not a lot you can do apart from replacing the flash assembly. This is a fairly uncommon issue (out of some 100 lumix cameras I've played with I only saw 2 in which flash failed), so you should be able to find a nice donor camera on ebay which you could scavenge for the replacement flash assembly. Flash in FX7 is integrated with the top part of the camera (where power/shutter/zoom buttons are) - this is the bit you need. It's relatively easy to dismantle and put together.
Good luck,
Raf
Posted on Nov 05, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
Click on the right button of the arrow pulley block and change the icons of the flash until you see only a flash mark with our a crossed line on it
Posted on Jul 07, 2008
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
Panasonic DMC-Z28 - the flash button does not call up a flash setting menu and so the flash won't turn on.
Is your Z28 set up to do burst shooting as this will stop the flash working, click on the trash button and turn off the burst shooting. Hope this helps.
Feb 12, 2012 | Panasonic Lumix DMC-FZ28 Digital Camera
Hi bi currently have a Problem with my Panasonic Lumix DMC-TZ50 Digital Camera the Flash seems to have stopped working? any clues how i can fix it and will it cost much? Regards Pete
The flash of my Panasonic DMC-TZ1 camera has stopped working normally - it flashes but the image is dummy. Could it be its falshing lamp is reaching its recources after working 3 years? Can it be changed?
Jan 28, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
How to clean a panasonic lumix dmc ts1 lens. i get spots when i take pictures
If the spots appear on flash pics only and are in different places on each photo, then the spots are not on your lens. Those are dust particles reflecting the light from your flash. It's a common problem with point-and-shoot cameras.
Mar 31, 2010 | Panasonic Lumix DMC-TS1 / DMC-FT1 Digital...
I am going in search of the Northern Lights tonight and the tour company say we cannot use flash photography, I have got my Lumix DMC TX3 camera with me at work but the instructions are at home - how do I...
Press Left on the four-way selector to bring up the Flash menu. Navigate down to "FORCED OFF" and press "OK" to select it.
When you're done, don't forget to turn it back on.
Mar 09, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
The flash on my Panasonic Lumix DMC-FX33 is not working. I did not drop it or anything, but suddenly every picture that should have a flash doesn't. The little screen shows that the flash should go off but...
You camera may be in 'auto'flash' mode, meaning the camera decides if the flash is necessary, depending on the lighting situatioin. Try your flash setting on forced flash instead of automatic, or try it in the dark to see if the flash goes off.
Jun 15, 2009 | Panasonic Lumix DMC-FX33A Digital Camera
Flash not working
Hi there.
look in the camera's settings to see if the flash is turned on, if it is and the flash still does not work you will need to take it to a service center for them to replace the halogen bulb.
Good luck and thanks for using FixYa!!
Apr 23, 2009 | Panasonic Lumix DMC-LZ1 Digital Camera
Flash dont work
in the menu there is an option called conversion. this needs to be off for the flash to work. I had the same problem and this fixed it. good luck.
Apr 08, 2009 | Panasonic Lumix DMC-FZ8 Digital Camera
Panasonic Lumix DMC-FZ20
This happened to me after a day in the sun..
There seems to be some poor electrical contact so when the flash popped up I had to manually pull it up further to ensure that it was on.
Jan 06, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Cameras Logo
530 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
