Nec nw452 washing machine water level does not stop. It overflows even when I put it on low level load. I keep having to turn the machine off and bail the water out into the sink.
  • Anonymous Feb 22, 2009
    Same problem - machine keeps overfilling even on low water level (and then flooding out the laundry).
  • bradquinn Apr 17, 2009
    I have the same problem, and I am still fixing it (looks like the clear tube running down the rear left is blocked) but put your machine on spin cycle to empty the water, instead of the old bucket approach.
I have just fixed this issue on my machine. Empty the machine by using the program options to spin only. Turn off power. Remove the plastic back plate then the silver back plate. Looking at the rear of the machine bowl, right hand side is a plastic tube which runs to the top right hand side of the machine. This is the water level sensor tube. Check if it is broken or blocked. Mine was broken near the top of the machine. I removed the lid (becareful to take note how the spring fits in with the leid for when you replace it. Remove the control panel cover. I saw the water level sensor (looking from the rear of the machine) to the right. It is brown and has one connector which needs to be disconnected (red and white connectors). Then the water level sensor is removed from its housing by unclipping the two clips. Once removed I replaced the tube and then put it all back together.
Posted on May 06, 2010
  • beck5 Mar 27, 2011
    Thank you for posting this! We followed your detailed advice and this was our exact problem! My husband said that it may not be necessary to take the top panels off if the machine is blocked where the pipe plugs into the bowl. Thanks again!
  • jd99
    jd99 Jul 01, 2012
    Hi @dusty2010,
    Just signed up as I wanted to say thank-you as this was also my problem.
    I managed to buy 5m of tube for $5, so I also replaced the bubble pump hose as well, as a bit of preventative maintenance.
    Gladly, I won't have to pay a ridiculous amount for a service call-out.
  • 1,462 Answers
I don't know nec specifically but here is some guidance
water level is determined by a pressure stat which is located at the top of the machine so start by removing the worktop. the pressure stat is usually round and with up to 9 electrical terminals to it and a small diameter tube connected. this tube goes to an air chamber. check the tube is not blocked or split and that the air chamber is not blocked. blockage is the usual cause of this problem.
to check if the pressure stat is ok, get some tube of the same diameter, and fit in place of the existing tube. start the machine on fill and put pressure into the tube reasonably gently (ie from mouth). you should hear a click and the water should stop
Posted on Jul 07, 2008
Water level control switch not working. even i set water level to very low it just keeps filling and has overflowed. i am guessing that the switch needs to be replaced.
It depending on exactly what your seeing that will determine the problem.
Does your washer start agitating and keep filling?? if yes it does start agitating and the water continuies to fill try disconnectiing the power and if it keeps filling what would be wrong is that the water inlet valve is sticking open and it would need to replaced
If the washer continues to fill and does not start agaitating would be a defective water level switch as you suspect it may be.If ya disconnect the power and it STOPS filling replace the water level(pressure) switch.
Oct 02, 2011 | Kenmore 24032\24036 Top Load Washer
I have a hoover 500M which we moved to a new place for my daughter. It continues filling until it overflows. I tried turning the power off while it was filling and the water stopped flowing as soon as the...
There is a sensor that detects the water level in the is usually a pressure switch that has a vacuum tube coming off it going to the level may be defective or even more simply, the vacuum hose may have come off
Jul 10, 2011 | Washing Machines
Do water level is not working. It will over flow
change your pessure switch. Thats the switch that says
medium low or high loads
Jun 06, 2010 | Kenmore 22422 Top Load Washer
Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Nov 22, 2009 | Washing Machines
Washing machine is overflowing, even set at low water level.
sounds like your pressure tube is not functioning correctly.
Aug 22, 2009 | Kenmore 23822 Top Load Washer
GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Ge wbsr washer overflows...
Could it be ...this happens only when it is overloaded or the load is out of balance. Please clarify.
If this is not the case .. the water level hose running from the outside tank to the water level switch is likely not making a good seal (otherwise the water level switch itself is bad). Sometimes with age the hose forms a crack in it near or at the end where it connects. This could happen at either end of the hose. Also if you have removed the control panel recently (for any reason) you may have (not knowingly) pulled the water level hose loose from the water level switch. Just slide the hose back onto the tube of the switch before putting the control panel back in place and all will be fine after the first filling of the tub (it may take one filling cycle to build the needed vacuum back up in the hose). Unless of course in the process you have broken the tube off the switch where the hose goes on. In this case replace the switch.
Jun 05, 2017 | GE WBSR3140DW Top Load Washer
Estate washer, new, water will not stop, overflowing
you need to replace the inlet valve something is stuck in the valve not allowing it to shut.
Dec 23, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Water keeps filling!!
sphion effect while the water comes in the water goes out ..because you never said that it overflows,,,so just put your drain hose up the height of the machine before it can go down,,,drain hose to low...onthejob
Nov 16, 2008 | Frigidaire FTF530FS Front Load Washer
Help me ....
Yes ,simply replace the water valve (hot&cold)and your problem is gone.
May 26, 2008 | Avanti Top Load Washer W797
Washing Machines Logo
573 people viewed this question
Top Washing Machines Experts
