Question about Siemens Lands Phones
I am hearing impaired and need telecoil assistance for heraing aids on both ears.
At the moment I have a Siemens Hocom 100 telephone system with telephone points throughout the office and home. Any suugestions advice or assistance is greatly appreciated
SOURCE: How do I turn off the intercom to my phone
Hi Andrew,
Press [feature] [8] [8] to prevent your phone from receiving the intercom
Brian
Posted on May 13, 2008
Maanita
  • 1142 Answers
SOURCE: Where do you connect a External Paging Port on Nortel Key Telephone System NT5B05?
This will help you
http://assets.twacomm.com/assets/pdf/4230.pdf
Posted on Jul 03, 2008
Neoklassic1
  • 70 Answers
SOURCE: service was connected on Saturday
If the caller hears ringing after dialing the home but the not ring inside home. That means the number is active but the wiring inside home is faulty/ not properly connected. A phone rings /or works of a basic system. Two wires usually red/green as primary. If either one is broken or improperly connected the phone inside will not ring. That doesn't indicate a short. If it was a short the caller would not hear ringing at all. So the first thing you must do is the track the cause. Make sure home phone is plugged securely into phonejack. Still no dial tone check all other jacks inside home. If still no dial tone. Contact your service provider. They will need to send a technician to check the Demarcation point. Which simply means the connection point where the service provider wires , meets the customers house wires. They just need to verify this connection
Posted on Oct 13, 2008
SOURCE: Installation Manual for Siemens Hicom 150e office com system
i have the same problem
Could yoy help whith download an installation manual for the siemens hicom 150e office, thanks
Posted on Nov 12, 2008
  • 5 Answers
SOURCE: Can Siemens optiPoint 500 phone be used at home
An "Optipoint 500" phone can not be used at home!
It is a digital phone, specifically designed for Siemens digital phone systems. Do not plug it in at home. That could damage the phone or may knock your phone line off.
However you can use a "Optipoint 500 IP" phone at home for voice over IP calls. But this would be connected into your broadband router and would connect via the web to your companys Siemens phone system.
Posted on Aug 04, 2009
Siemens lotus hearing aid emits constant tone
Is the (acoustic) tube obstructed or partially blocked ? If the problem is inside the hard plastic flesh-coloured opaque part, you will need to take it a technician, return it to the manufacturer, or replace it. There are no user-serviceable parts inside.
Jan 14, 2014 | Select Products Hearing...
My liquid ear wax keeps making the hearing aid go in and out of hearing correctly. so I have to either take it out and clean it constantly or hold it in place or keep wiggling it or pulling it in and out.
he TEK CONNECT does not connect with the TEK transmitter that I bought in
As the old man had failed. Then connect the tek has not
more
connected with my phone. I brought the Tek by an operator
Amplifon
I said, unable to turn it on, connect it to the TEK
TRANSMITTER, that it was necessary to reprogram it. The TEK CONNECT works
well
with the five programs and hearing aids. If it is possible I would like to
know your opinion about the situation. On this occasion
I offer
Yours faithfully John Virgil.
Aug 13, 2013 | hi HealthInnovations hi BTE telecoil -...
How to set volume on Siemens Lotus 23 P
You may be able to adjust the sensitivity of the device iusing the small, partially recessed wheel on the back of the unit - in fact this is the largest of the controls !
Otherwise you need to take the unt and yourself to an audio technician for adjustment
Apr 16, 2013 | Select Products Hearing...
It's exactly like the guy says on the left: Siemens Pure 501 RIC Serial No RW52119 The above unit is in the right ear and periodically does not produce any sound. The RIC cord has been replaced once and...
The receiver, the piece you call the cord is either blocked with wax or dead. Check the very tip of the receiver for wax detrius, if there is some remove it and see if you can hear. If not you may need to get a new receiver.
Apr 20, 2011 | RTO 1 Siemens Pure 500 Open Fit Hearing...
Squealing at random when volume is at approx 50%
Take your hearing aid to your specialist. Check on wax in your ears. Also are you near a window when the feedback occurs? Due to the phase-cancellation in hearing aids sometimes the signal bounces back and thinks it's feedback.So the hearing aid sends out it's own frequency at 180 degrees and hits it to cancel it out. If this is a false reading however the hearing aid will create its own feedback
Rick
Apr 04, 2010 | Select Products Hearing...
Fit & Squeal
Sounds like a custom mold may be the right solution for you. Ask your dispenser about this
Jan 27, 2010 | RTO 2 Siemens Pure 700 Open Fit Hearing...
Can come out when i remove glsses or take off jumper or hat
Hi Jan3630,
The instruments you show in the picture appear to be ear inserts rather than custom ear mold. Customs can also be small.
You may consider having a local Hearing Health Care Professional advise you as to the feasibility of replacing your sound tubes and inserts with Custom ear-molds.
These will have a better chance of staying in the ear when you are doing the activities you described. Please advise if you find info helpful. Thanks for contacting FixYa.com
Oct 27, 2009 | RTO 1 Siemens Pure 500 Open Fit Hearing...
Lands Phones Logo
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
