Question about HP Pavilion a1410n (ER890AA) PC Desktop
Delete folder I MAKE A NEW FOLDER WITHOUT NAME IN WINDOWS VISTA. NOW HE NOT DELETE FOR ME . SO YOU HELP ME
  • 340 Answers
Hi muraripcs,
Logon as Administrator and delete the protected folder.
You logon as Administrator like this:
Open the command prompt with Administrative privileges by opening the Start Menu, and typing cmd in the search box, and then press Ctrl+Shift+Enter
Type the following in the command prompt:
net user administrator /active:yes
Press Enter
Restart your computer and logon as Administrator.
Note: You might want to set a password for the administrator’s account for at least a little protection.
Warning: Running as Administrator in Windows Vista bypasses all security and is NOT recommended.
If you decide to use the Administrator account don’t complain when you start having problems :-).
Regards
Teis
Posted on Dec 20, 2008
How can I Fix Google Chrome Error 0xa0430721 ?
Try this:
Step1: Open your Application Data Folder.
For Windows XP: %USERPROFILE%\Application Data\Local
For Windows Vista/7: %USERPROFILE%\AppData\Local
Step2: Delete Google Folder (If you have other Google Applications, open the folder and delete "Chrome").
Step3: Open Task Manager>Processes (If running on Windows Vista/7, select "Show Processes From All Users" and click "Allow")
Click on "Description" (on top where you see Image Name, User Name etc..)
Scroll Down until you see anything with the Description "Google".
End each process 1 by 1.
Click on "Image Name" (on top where you see Image Name, User Name etc..)
Scroll Down until you see anything with the Image Name "Google"
Step 4: Go to http://www.google.com/chrome/
and install Google Chrome.
Nov 13, 2017 | Google Computers & Internet
Tip
How to Delete Protected Folders from a Memory Sticks
<p>Folder on the removable media used both FAT32 and NTFS file systems in Windows operating system. Some of these attributes in the rule of the people (name, size, creation date, and time) can be seen, others have explicit measures to ensure Windows. Among the latter are "read only" (if set, the folder cannot be erased) and "hidden" (if set, the folder does not appear in the parent directory.) A folder is set with one of these protected attributes clear. With a few extra steps, but you can secure a folder from a memory stick.<br /> <p> <br /> <p>1. Connect the memory stick for your computer. Windows will recognize it automatically and make your content accessible.<br /> <p><br /> <p>2. Click the "Start" and "run" (without quotation marks) into the search box. Click the "Run" link, type "cmd" and press Enter. A command window opens.<br /> <p><br /> <p>3. Type the following commands in the command window:<br /> <p> <br /> <p>E:<br /> <p>cd "\ myfiles \ projects"<br /> <p>Replace "E:"with the drive letter for the Memory Stick and replace "\ myfiles \ projects" with the full path to the folder containing the folder you want to delete protected. Press Enter after typing each line.<br /> <p>4. Type the following command to remove the attributes currently prevents you from deleting the folder:<br /> <p>attrib -r -h folderName /e<br /> <p>"Folder Name" Substitute the name of the folder you want to delete. Press "Enter ".<br /> <p><br /> <p>5. Delete the folder by clicking "Start", then "Computer". Navigate to the folder you want to delete, click once and press Shift-Delete. "Windows will erase a protected folder from memory stick.<br />
on Jun 21, 2011 | Computers & Internet
Picasa wants a password to unlock folders
Which operating system ????....
Windows XP
  1. Exit Picasa.
  2. Confirm that you can view hidden files and folders .
  3. Open the folder C:\Documents and Settings\[USER]\Local Settings\Application Data\Google\Picasa2\db3 (where [USER] is your username).
  4. Delete the catdata_info.pmp file.
  5. Restart Picasa.
Note: Although you may be running a newer version of Picasa, rest assured the correct folder name is indeed Picasa2.
Windows Vista
  1. Exit Picasa.
  3. Open the folder C:\Users\[USER]\AppData\Local\Google\Picasa2\db3 (where [USER] is your username).
  5. Restart Picasa.
Windows 7
  1. Exit Picasa.
  5. Restart Picasa.
OS X
  1. Exit Picasa.
  2. Open Finder.
  3. Under your username, open Library > Application Support > Google.
  4. Click Picasa3 > db3.
  5. Delete the catdata_info.pmp file.
  6. Restart Picasa.
Oct 13, 2011 | Compaq Computers & Internet
I am trying to unistall elibrary software and i am getting an error message 1324 the path sony reader contains an invalid character
Hi!
You can try to manually remove the software and reinstall, BTW there is no operation system detailed. But here's a solution for windows XP, Vista and 7
Windows XP:
Open My Computer .
In the My Computer window, go to the following path
C:\Documents and Settings\All Users\Application Data\
Delete the folder called "kinoma"
Then go to the following path:
C:\Documents and Settings\"your user name"\Local Settings\Application Data \
Delete the "Sony Corporation" folder
Windows Vista® and Windows® 7 operating system operating systems:
Open Computer on your Desktop
Go to the following path:
C:\ProgramData\
Now go to this path:
C:\Users\"your username"\AppData folder\Local\
Delete the folder called "Sony Corporation"
GoodLuck!
eBookBoy
http://digialreader.freeforums.org/
Jul 18, 2011 | Sony PRS-505 eBook Reader
Error 7 i cant open facebook
This error is most likely due to a problem with the Application folder on your computer during the installation process.
To resolve this issue, delete the Application folder, then try installing again. Follow these steps (for Windows):
  1. Go to the Start menu > Run.
  2. Enter one of the following commands in the text field, depending on your operating system.
    • Windows XP: %USERPROFILE%\Local Settings\Application Data\Google\Chrome
    • Windows Vista: %USERPROFILE%\AppData\Local\Google\Chrome
  3. Click OK.
  4. Delete the Application folder. If you're having difficulty deleting this folder, check for active Google Chrome processes on your computer and end them. Here are a few ways to locate and shut down these processes:
    • Press Ctrl+Alt+Delete on your keyboard and click Task Manager. Click the Processes tab and end every process that includes "google" or "chrome" in its name.
    • Download a third-party program called Process Explorer at http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx. Use its Find menu to search for "Chrome/Application," then end all resulting processes.
    Now try deleting the Application folder again.
  5. Once the Application folder is deleted, try installing Google Chrome again.
Well, I am new to fixya, so please don't forget to appreciate the solution.
Thanks.
Jan 27, 2011 | Google Chrome
Where can I find directions for removing 2 Windows 7 installations. This is because the installation did not go well, and in each attempt, Windows tried to install. I now have 2 working and a partial...
Did you install to a separate "partition" of the disk-space, or just to a different "folder" on the 'C:' drive. For comparison, Windows NT installed to the 'C:\WINNT' folder, and, by default, Windows XP/Vista/7 install to the 'C:\WINDOWS' folder.
If you installed to a different folder, open My Computer.
Open the 'C:' drive.
Click on that folder-name.
Hold down the SHIFT key and press the DELETE key.
Say 'yes' to confirm that you want to delete the folder, thereby_bypassing_ moving the folder into your 'Recycle Bin'.
If you installed to a different partition, open "Disk Management (local)",
select the partition, and either DELETE or FORMAT the partition.
Nov 11, 2010 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
I'm using Microsoft Outlook. I have 2 messages in the outbox that have a huge attachment using power point. The attachment is too large to send. MS Outlook will not delete the two messages. It ignores...
Open the outlook, disable the lan connection or you can set the Outlook to Offline (click File > Work Offline, but don't forget to re-set it online after you are done). After you are done, right-click the file to be deleted while you press the Shift Key on the keyboard and select "Delete".
If the first step doesn't work, then move it to another folder (create a new folder) and delete the folder after you are done. (don't forget to do this in Offline mode or with disabled lan).
Again, you can try deleting the file directly from the folder. Open My computer, go to C drive as shown below (Note: User Name = Your current username on your computer):
Close the outlook and do this;
1. Windows xp:
C:\Documents and Settings\User Name\Local Settings\Application Data\Microsoft\Outlook
2. Windows Vista/7
C:\C:\Users\User Name\AppData\Local\Microsoft\Outlook
Locate the file name "outlook", must be the largest file, delete it and open your outlook. All the inbox will re-sync with your email, but your problem will be fixed.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 05, 2010 | Microsoft Office Outlook 2007: Windows
Windows live messenger login but contacts cannot list
First i should say, this had to be a paid solution lol
  1. On the taskbar, right-click Start, and then click Explore.
  2. Click Tools, and then select Folder Options.
  3. Click the View tab.
  4. In the Advanced Settings list, select Show hidden files and folders, make sure Hide extensions for known file types is not selected, and then click OK.
  5. In the Windows Explorer window, click View, select Explorer Bar, and then verify that Folders is checked.
then
  2. Navigate to the folder C:\Documents and Settings\Your Windows logon name\Contacts\Your Messenger e-mail address.
  3. Delete all of the files in the folder.
  4. Navigate to the folder C:\Documents and Settings\Your Windows logon name\Local Settings\Application Data\Microsoft\Windows Live Contacts\Your Messenger e-mail address.
  5. Delete all of the folders and hidden folders in the Your Messenger e-mail address folder.
  6. Close Windows Explorer, and then try to sign in to Messenger again.
Try this for windows xp.
for vista
  2. Click Organize, and then click Folder and Search Options.
  5. Click Organize.
  6. Under the Layout menu, verify that Navigation Pane is selected.
then
  2. Navigate to the folder C:\Users\Your Windows logon name\Contacts\Your Messenger e-mail address.
  4. Navigate to the folder C:\Users\Your Windows logon name\AppData\Local\Microsoft\Windows Live Contacts\Your Messenger e-mail address.
A bit big, ryt?
Apr 01, 2009 | Microsoft Windows Live Messanger
Contact List
then
for vista
  5. Click Organize.
then
A bit big, ryt?
Mar 30, 2009 | Microsoft Windows Live Messanger
Rename user folder
You cannot rename the user folder because it is a system folder.
You can go to user accounts in control panel and rename the user account from the 'old name' to new name'. Unfortunately this will be purely cosmetic, the account will still be seen by the system with 'old name'.
The only efficient solution is going into control panel/accounts and creating an new account with 'new name'. Then you transfer all data to 'new name' account and delete the old account.
Jul 15, 2008 | Microsoft Windows Vista Ultimate Edition
HP Pavilion a1410n (ER890AA) PC Desktop Logo
142 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
