You will need to log into the voicemail system as you would to check your messages. There will then be a number to press (listen to the voice prompts) for voicemail options. Somewhere in there will be the option the change greeting/message. If you do not pay for a voicemail then you will have to live with the standard one your service provider uses, although you may be able to change "your call has been forwarded to the voicemail box of "JOHN DOE", is currently unavailable. This would be changed the same way I stated above.
Rylan
Check your Voicemail
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Best of luck!!
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
