Question about Sony Battery Charger for PSP
Camera problem my psp says that i should "connect a camera that is compatible with the PSP system to the usb connector.(80108D50). pls help me thanks!
  • centepede_sh May 19, 2009
    i have a problem bout my PSP cam.. i already put my cam on the USB connector then my PSP wont recognize it..(8010D50) before i change my system software in v5.50 this camera that i use is working.. although my system software is v5.00 what is the possible solution to his problem?
  • 98 Answers
This is cuz you need a camera that will work with it,
Posted on Nov 26, 2008
How to download a psp games for free??????????
1. CONNECT YOUR PSP TO PC
The PSP can function as a USB Memory Stick Duo reader. Using this functionality, you can copy pictures, audio, and other content to and from your Memory Stick Duo. To access the Memory Stick Duo in your PSP from your PC, you'll need a USB cable that has a "Mini-B" connector (common for digital cameras) and a "Standard-A" connector (common for printers, etc). Plug the Mini-B side into the top of your PSP and the Standard-A side into your PC. From the PSP software, navigate to the top of the settings list and select "USB Connection." Your PC (Windows/Mac/Linux) should detect a new "Removable Disk Drive" that you can then access.
2. TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
Just copy the folder you have just extracted, and paste it into the PSP's "SAVEDATA" folder. But, BEWARE!, to any folder overwrite warnings! Because the PSP save game folders use the same names for the same games, copying folders into these locations could lead to lost data. For this reason, we recommend that you backup your old save games before overwriting them. For Example, I would simply rename a folder like "ULPS0004" to "ULPS0004_backup."
3. EXIT USB MODE
Because your PSP has been in USB Mode throughout this process, just push X to exit. Then you can safely disconnect your PSP from your PC.
download the games here as many as you can for free
http://www.pspmaniaonline.com/
Say "Thanks" by clicking the thumb icon in the post that helped you. Please click "YES" in solution that solves your problem as "was this helpful?"
Apr 19, 2011 | Sony PlayStation Portable (PSP) Console
I what to dowuload game form pc to my pspgame so how can i do it pls
Here are the steps to follow:
1) Insert a Memory Stick into the Memory Stick slot in the left side of the PSP. Depending on how many files you want it to hold, you may need to get a larger one than the stick that came with your system.
2) Turn on the PSP.
3) Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
4) Scroll to the "Settings" icon on the home menu of your PSP.
5) Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
6) Create a folder called "PSP" on the PSP Memory Stick (if there isn't one already) -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac). There should also be a folder called "MP_ROOT" (not inside the "PSP" folder).
7) If they aren't there already, create folders called "PHOTO" and "MUSIC" inside the "PSP" folder. There also should be a folder called "100MNV01" inside the "MP_ROOT" folder.
8) Drag and drop files into the folders just as you would save files in another folder on your computer. Image files go in the "PHOTO" folder, audio files go in the "MUSIC" folder, and video files go in the "100MNV01" folder.
9) Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.
This should help you to move those files.
Mar 10, 2011 | Sony PlayStation Portable (PSP) Console
Laptop will not recognize psp
Hi lawolf77,
If your laptop wont recognize your PSP there might be a connection problem between the two. So you need to check what's causing the problem. There are several ways to check if PSP and your computer are properly connected, one good example is by checking the connectors and the device setting.
If you want to check some configuration on how to connect your PSP to your PC please try to follow these steps:
1. First, connect your PSP to your PC using a usb cable.
- please make sure both ends are properly intact.
2. Using the left and right directional button find "Setting", then scroll down or up to find the "USB CONNECTION".
3. USB CONNECTION will display after you pressed the x button.
4. Please wait until computer detects the USB connection. After that it will show the drive for your PSP. usually F: or G:
5. Click on your PSP drive letter.
6. Now you can determine if your PC recognizes the PSP, just access the root folder and try to put some files on it.
Hope it helps.
Thank you for using FixYa.
Feb 08, 2011 | Sony PlayStation Portable (PSP) Console
My psp go has run out of batterie and no longer charges pls help
There are two possible causes for this, one your charger is broken, in which case you will need to buy a new one. Hopefully thats the problem, because the only other possibility is that the Charging port is broken, in which case you will have to send it to Sony to repair. However, there is a work around to the second problem. My psp has the ability to charge via its USB port, if you have a compatible USB cable, connect your psp to your computer and see if that will work.
Aug 20, 2010 | Sony PlayStation Portable (PSP) Console
How to use a usb cable for the psp
After that you can now transfer file from PSP to computer and vice versa...
Hope that helps..............
Sep 12, 2008 | Computers & Internet
Connecting a psp to our unit?
The USB port is only compatible with flash memory drives and some card readers.
Jan 03, 2008 | Philips HTS-6500/37 System
PSP sound ouput
I'm pretty sure the USB port is only for transferring media files. I've searched my PSP head to toe and never heard of anything like that. I've found out you can use the USB connector on the white PSP to charge the battery. (I haven't tried that out yet.)
Dec 28, 2007 | Sony PlayStation Portable (PSP) Console
Psp camera
This can depend on the firmware you are running. PSP's firmware version 3.0 and up supports the camera. Have a wi-fi network that you can access close by, make sure your battery is charged and select network update.
Aug 03, 2007 | Sony PlayStation Portable (PSP) Console
Sony Battery Charger for PSP Logo
821 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
