Question about Compaq Computers & Internet
Booting problem with compaq presario laptop v6608au
Whenever i boot my laptop ,a message appears on the screen ,it says "remove disks or other media ,press any key to restart"
what should i do? i use windows vista basic operating system ,i dont want to loose any data,is there any solution?????????
    Genius:
  • 2,785 Answers
Plz try by changing the hard disk cable
Posted on Jul 07, 2008
Can not get past the ''remove disks or other media'' screen.
put in the OS cd to you cd rom. power on the computer keep on tapping the F12 key until you reached to boot options. select your cd/dvd rom drive to boot up from your cdrom.
Mar 26, 2010 | Computers & Internet
PXE-E61 Media Test Failure Check Cable on compaq presario 2100
A PXE-61 error message is most likely a faulty hard disk.
Try reseating the hard drive first and if you still get this error message again then you need to replace the hard disk.
To boot up with the CD you maybe able to press the F12 function key when you power up the laptop, this will bring up the a menu option to select an alternate boot device. If this option is not available then go into the BIOS configuration and change the bootup order and make the CD as the first boot device and the hard disk as the second device. You can can it back later.
Sep 14, 2009 | Compaq Armada E500 Notebook
Reformat
(A) Try interrupting the boot sequence and telling the computer to boot using the last known good configuration. Here's how: 1) Turn the computer on, and press F8 repeatedly until the boot options menu appears (the menu items include "Start Windows Normally," "Use Last Known Good Configuration," etc.). Use the arrow keys to select "Last Known Good Configuration" and press ENTER. The computer should boot correctly.
if it dont this is the procedure given below to format the whole operating sys 1) Put the CD in the CD drive and turn the computer on. 2) As the computer begins to turn on, you should see the message "Press __ to enter setup" (it's usually F1, F2, or F4 - models vary). Press that key.
3) You should then see the Setup screen for the BIOS ("Built-In Operating System") - using the arrows, find the "boot disk priority" settings and select your CD Drive as the first priority.
4) Exit setup, saving changes (usually by pressing F10). The computer should then boot normally using the CD.
Jun 18, 2009 | HP Compaq Presario v3000z Notebook
PXE-E61
Your disk-drive has failed.
So, your computer tried to boot itself over the Ethernet network,
by "broadcasting" a request for booting. When either the network-cable was _NOT_ connected, or when _NO_ computer responded to the "broadcast" message, you get "PXE: media failure".
Take your computer to a qualified technician,
to remove the "dead" disk-drive,
to replace the disk-drive,
and to reinstall Windows.
May 26, 2009 | Compaq Presario-Notebook 700 Series, 2500...
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
Error message
What was your coworker doing on it? I would say you need to at least do a disk check. You can do this through windows repair console or in Vista you can boot to the disk and have it check boot up problems. Very easy.
Dec 05, 2008 | Compaq Presario Notebook
I have a black screen that says "missing operating system"
while booting press F2 or DEL to enter BIOS...there u can change boot device priority..there u can chenge the 1st boot device as the hard disk...
Nov 30, 2008 | Compaq Presario 700 470024-192 Notebook
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
124 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
